vinyl top and glass install #1675829
09/22/14 07:37 PM
09/22/14 07:37 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
I had a new vinyl top installed on my 74 Scamp. I am putting in a new windshield and back glass. how far should the vinyl go under the windshield gasket??
Re: vinyl top and glass install [Re: mopfried] #1675830
09/22/14 10:42 PM
09/22/14 10:42 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
no one? Should it go under the windshield gasket at all?
Re: vinyl top and glass install [Re: mopfried] #1675831
09/22/14 11:32 PM
09/22/14 11:32 PM
Crofton, MD
bri440 Offline
bri440  Offline
Crofton, MD
I'm no expert - I've installed one vinyl top. I ran mine down the vertical edge of the frame and stopped there. Cut out for the welded trim clips. Some clips use screws, so add some sealant to the screws. The horizontal surface stayed clean for the window gasket to seal.
Good luck.
Re: vinyl top and glass install [Re: bri440] #1675832
09/22/14 11:36 PM
09/22/14 11:36 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
thanks? I didn't pay attention... how are the factory ones done?
Re: vinyl top and glass install [Re: mopfried] #1675833
09/23/14 09:38 PM
09/23/14 09:38 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Pretty much the same as he's describing other than the factory used metal staples in some areas to hold the top on..They wanted to make sure it was secured the fast and easy way..
