Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results
[Re: Chuck@Best_Machine]
#1674547
09/20/14 07:38 PM
09/20/14 07:38 PM
Posts: 1,770 Pa
Wv68charger
Pa
Big tube headers graph
Definitely gotta look into a set of those....
[Re: Cab_Burge]
#1674550
09/20/14 08:46 PM
09/20/14 08:46 PM
Posts: 1,770 Pa
Wv68charger
Pa
What works on the dyno may not be the best for the track The motor did not reach peak on HP on either pull it looks like to me The torque graph does look a little flatter with the bigger pipes It would be a very good test at the track to find out which set makes the car go quicker and faster
True Cab, the small headers have to stay for right now Chuck and Pete made sure I spent my money on what was absolutely needed to get the results for what we wanted to do within my budget. The only thing I know is it idled like a dream, sounded like a beast and made exactly what they said it would. Testing will have to wait till next year as the car is still in the chassis shop.
[Re: Dunnuck Racing]
#1674552
09/20/14 09:32 PM
09/20/14 09:32 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
That Charger is going to Rock and Roll !! Great work !!
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: sunroofgtx]
#1674553
09/20/14 09:47 PM
09/20/14 09:47 PM
Posts: 1,770 Pa
Wv68charger
Pa
we have no expectations of any ET just want to get back to racing it's hard to believe it's been 2 years but it will be worth the wait for sure!
#1674554
09/20/14 10:00 PM
09/20/14 10:00 PM
Posts: 970 Farmington Hills, Mich
Chuck@Best_Machine
The big tubes lost quite a bit of torque for a few horsepower gain. I would say the smaller tubes are a better choice Keith
I agree, with the big tires the small tubes will work good. If it was on 10.5 s I would use the big ones
#1674558
09/21/14 01:14 AM
09/21/14 01:14 AM
Posts: 9,856 MI, usa
dvw
MI, usa
TTI Headers 2.125 x 3.5
I know it wasn't tested here, but you have had previous experience with the Indy cross ram. Whats your guess if this motor were equipped with the Indy cross ram as far as peak torque and overall power numbers?
#1674560
09/21/14 10:48 AM
09/21/14 10:48 AM
Posts: 16,928 NC
440Jim
NC
BMBBR5 Roller Cam 283 on a 115
Can you give us a little more info on that cam? LSA 115 (wider than I expected) Intake/Exhaust at 0.050" 283? Lift with the 1.6 ratio?
I bought your BMBB 3R from another racer for my 540 CID, 345CNC.
I liked the straight 2.125" headers. They made more torque and the horsepower pulled to the top of the pull (7400rpm). That surprised me with 572 CID. Perhaps the cam and 3X intake?
[Re: 440Jim]
#1674561
09/21/14 12:54 PM
09/21/14 12:54 PM
Posts: 877 ky
68roadrunner
ky
3x intake and a 2" spacer, thats alot of plenum
