Delete Options
#1673568
09/18/14 12:35 PM
09/18/14 12:35 PM
Posts: 5,106 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
G30 code Delete Mirrors. What mirrors are referred to in the deletion. Door outside mirrors? Could the inside rear view mirror ever get deleted? Is that a different code.
G35 code Delete standard outside mirror. What is the differences in this Codes and G30 Code.
Would these codes make it to the fender tag or just the build sheet.
I am referring to only the 1971 E Body build.
1971 HEMI E BODY REGISTRY
Re: Delete Options
[Re: cudaized]
#1673570
09/18/14 03:26 PM
09/18/14 03:26 PM
hemicar1971
Chicago Blackhawks
There are other codes I have wondered about. How the line worker would know how Chrysler would tell them to change the build. Things like optional rear ends or putting a HD transmission in a car that did not receive one. Did the Heater delete go on the Fender Tag or Broadcast sheet or both. I might have a fender tag or broadcast sheet copy around to take a look at but did the Heater delete make it on either copy. Things like an optional rear end, did it end up on the broad cast sheet and the fender tag and if it made it on to the fender tag was the standard option deleted or left blank.
If people in the know would like to keep this off the internet just email me on moparts with an answer from all your information. Just started to wonder about the builds and how Chrysler put out the information to the workers on what did or did not go on these 1971 E Bodies.
Re: Delete Options
[Re: Culvers]
#1673574
09/19/14 03:08 AM
09/19/14 03:08 AM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
Special order interiors for 1970 were 9999.
There is a '70 'Cuda out there with a "9999" interior code, it's a white 440 car with the Gran Coupe black/white hound's-tooth red piping interior in it.
Re: Delete Options
[Re: 6bblgt]
#1673575
09/19/14 03:27 AM
09/19/14 03:27 AM
Posts: 2,309 South, FL
cudaized
South, FL
Dan, I was just trying to find the pictures of that. I have to stop looking now. Time to go to work.
Can you post for me?
Re: Delete Options
[Re: 6bblgt]
#1673577
09/19/14 10:18 AM
09/19/14 10:18 AM
Posts: 11,022 Farmington, CT
KISSAlien
Farmington, CT
I can't find any pics of the 9999 interior'd 'Cuda
I've got them on my home pc. I'll post them this wekend if someone doesn't beat me to it. It was the P5X9 interior that later became available across the line if I remember correctly.
Re: Delete Options
[Re: 6bblgt]
#1673578
09/19/14 12:10 PM
09/19/14 12:10 PM
Posts: 2,632 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Is this the one you are talking about? It had a special sheet to tell them how to do the interior. I don't think I saved a copy of the build sheet or the special instructions.
2011 Drag Pak Challenger
Re: Delete Options
[Re: rickseeman]
#1673580
09/20/14 01:10 AM
09/20/14 01:10 AM
hemicar1971
Chicago Blackhawks
Trim and paint codes seem to be covered by a special order numbers that make it to the FT. 999
Has anyone seem a G30 Code on a broadcast sheet or fender tag. This is the Delete Mirrors code. Then there are axle codes that are not A codes, do these A codes get eliminated off the FT and BCS. The H25 Heater Delete code you would thing might make it to the FT and would make it to the broad cast sheet.
Re: Delete Options
[Re: KISSAlien]
#1673581
09/21/14 10:41 PM
09/21/14 10:41 PM
cudaized
South, FL
Found them...
