Can a bad Tach cause ignition problems? #1672776
09/17/14 06:51 PM
09/17/14 06:51 PM
Canada
CTD5.9 Offline OP
CTD5.9  Offline OP
Canada
After 4 years of running like a champ, my 440 PowerWagon mud bogging truck decided to give me a giant backfire through the carb, enough to explode the air cleaner. Rev's to the moon in neutral but pops out the carb and stalls with any load.
I have changed plugs, wires, coil, distributor, ecu, ballast, ignition wiring loom, cap and rotor. Changed out the 750 Holley to a Thermoquad then an edelbrock 750.
I noticed during all this my autometer 5" in dash tach started acting weird when cranking bouncing everywhere. A friend suggested I unhook it, and it seemed to "fix" the issue although part of me thinks its just waiting to mess with me again and that that a tach wouldn't cause this.
Re: Can a bad Tach cause ignition problems? [Re: CTD5.9] #1672777
09/17/14 07:08 PM
09/17/14 07:08 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Yes, they have been known to cause the problem you are describing.
Re: Can a bad Tach cause ignition problems? [Re: scatpacktom] #1672778
09/17/14 08:32 PM
09/17/14 08:32 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
The tach connects to the coil and will ground out the coil if it goes bad. Because of the light wire to the tach its not a good ground so the car tries to run. Check all the wires around the coil, dizzy, and control box. Disconnect the tach and go mudding. Best bet is to put on a MSD 6AL, the tach connects to that and will not ground out the coil, but, I would not hook up your tach to anything except maybe a ford till I was sure it wouldn't cause the problem again. It just maybe the wire from the coil to the tach is shorting out somewhere..
Re: Can a bad Tach cause ignition problems? [Re: CTD5.9] #1672779
09/17/14 10:04 PM
09/17/14 10:04 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Internally...
A tach like any other electronic device can go bad...
If it develops a short..
It can act strange and may cause the ignition system to fail.
Just my $0.02...
Re: Can a bad Tach cause ignition problems? [Re: CTD5.9] #1672780
09/17/14 11:07 PM
09/17/14 11:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
If it runs well with the tach disconnected I think you have found your problem. Hook it back up, if symptoms retrun, disconnect again REPEAT until you are comfortable with the diagnosis, Don't OVER THINK IT
MY
Re: Can a bad Tach cause ignition problems? [Re: CTD5.9] #1672781
09/18/14 12:16 AM
09/18/14 12:16 AM
central il.
second 70 Offline
second 70  Offline
central il.
Yes! I chased a problem in my hemi cuda for a month. It would work sometimes and other times it acted as if it was dumping the floats and flooding the engine. Happened to see the tach jump one day and disconnected it problem gone. Turns out it was bad and screwing up the msd 6al-2signal. Replaced tach and all problems are gone.
Re: Can a bad Tach cause ignition problems? [Re: second 70] #1672782
09/18/14 05:17 AM
09/18/14 05:17 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Would it help to put a diode in the tach signal line to eliminate a potential shorting out?
Re: Can a bad Tach cause ignition problems? [Re: TJP] #1672783
09/18/14 12:20 PM
09/18/14 12:20 PM
Canada
CTD5.9 Offline OP
CTD5.9  Offline OP
Canada
MY
It's hard not to over think it! twice now I have thought it was fixed, trailered the truck to an event only to have it die on me. Once I barely made it off the trailer.
I did however hook the tach back up last night and it came back, so I repeated it 2-3 times with the dame results, works without and backfires with. So hopefully it will survive its's last outing of the year.
Re: Can a bad Tach cause ignition problems? [Re: CTD5.9] #1672784
09/18/14 03:37 PM
09/18/14 03:37 PM
God's Country Maryland
GODSCOUNTRY340 Offline
I had an Auto Meter tach go bad in the late 70's. Engine was missing, popping and the tach needle was jumping all over the place. I thought the jumping needle was being caused by an electrical problem in the ignition circuit and started changing parts. After replacing everything I could I disconnected the tach and the problem was cured.
