Can a bad Tach cause ignition problems?
#1672776
09/17/14 06:51 PM
09/17/14 06:51 PM
Posts: 760 Canada
CTD5.9
Canada
After 4 years of running like a champ, my 440 PowerWagon mud bogging truck decided to give me a giant backfire through the carb, enough to explode the air cleaner. Rev's to the moon in neutral but pops out the carb and stalls with any load. I have changed plugs, wires, coil, distributor, ecu, ballast, ignition wiring loom, cap and rotor. Changed out the 750 Holley to a Thermoquad then an edelbrock 750.
I noticed during all this my autometer 5" in dash tach started acting weird when cranking bouncing everywhere. A friend suggested I unhook it, and it seemed to "fix" the issue although part of me thinks its just waiting to mess with me again and that that a tach wouldn't cause this.
Re: Can a bad Tach cause ignition problems?
[Re: CTD5.9]
#1672779
09/17/14 10:04 PM
09/17/14 10:04 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Internally... A tach like any other electronic device can go bad... If it develops a short.. It can act strange and may cause the ignition system to fail. Just my $0.02...
[Re: TJP]
#1672783
09/18/14 12:20 PM
09/18/14 12:20 PM
Posts: 760 Canada
CTD5.9
Canada
If it runs well with the tach disconnected I think you have found your problem. Hook it back up, if symptoms retrun, disconnect again REPEAT until you are comfortable with the diagnosis, Don't OVER THINK IT MY
It's hard not to over think it! twice now I have thought it was fixed, trailered the truck to an event only to have it die on me. Once I barely made it off the trailer.
I did however hook the tach back up last night and it came back, so I repeated it 2-3 times with the dame results, works without and backfires with. So hopefully it will survive its's last outing of the year.
[Re: CTD5.9]
#1672784
09/18/14 03:37 PM
09/18/14 03:37 PM
Posts: 2,522 God's Country Maryland
GODSCOUNTRY340
I had an Auto Meter tach go bad in the late 70's. Engine was missing, popping and the tach needle was jumping all over the place. I thought the jumping needle was being caused by an electrical problem in the ignition circuit and started changing parts. After replacing everything I could I disconnected the tach and the problem was cured.
