Manual Disc Master Cylinder Questions/Problem #1672494
09/17/14 01:20 AM
09/17/14 01:20 AM
Toronto, Ontario, Canada
plazomat Offline OP
plazomat  Offline OP
OK so I have a Cardone select 13-1822 master cylinder (85 Diplomat) I wanted to use in my 69 Belvedere disc o tech conversion..
Problem is it doesn't have a machined area to lock in the push rod..power brake only master.
There are exactly zero masters available locally - and if I can't see it I won't know if the detail is there. I am thinking I need to order another from the US but which brand? Is this luck of the draw or are some more likely to have the manual or power piston in the MC?
Any way to secure the manual push rod in the power Master ?
Plazomat
Re: Manual Disc Master Cylinder Questions/Problem [Re: plazomat] #1672495
09/17/14 01:33 AM
09/17/14 01:33 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
put the pushrod in...fill recessed area with rtv...
Tony
70 AARCuda Vitamin C
Re: Manual Disc Master Cylinder Questions/Problem [Re: plazomat] #1672496
09/17/14 01:57 AM
09/17/14 01:57 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
What about using a 73-76 Dart/Duster/Valiant 4 bolt manual MC? They do fit.
Re: Manual Disc Master Cylinder Questions/Problem [Re: 70AARcuda] #1672497
09/17/14 10:05 AM
09/17/14 10:05 AM
plazomat Offline OP
plazomat  Offline OP
I have heard/read about the RTV method - anyone know anyone who has done this and lived to tell about it?
It is a manual pushrod if that makes a diff?
Will look into the a-body MC availability - over the last 10 years or so the old stuff has become impossible to find here in Toronto - dam ricers..
Plaz
Re: Manual Disc Master Cylinder Questions/Problem [Re: plazomat] #1672498
09/17/14 11:12 AM
09/17/14 11:12 AM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
Rock Auto will have what you need
Re: Manual Disc Master Cylinder Questions/Problem [Re: can.al] #1672499
09/17/14 11:36 AM
09/17/14 11:36 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Does your m/c have the dimple for the pushrod ?? If so, a small piece of rubber tubing on the pushrod usually works.
Re: Manual Disc Master Cylinder Questions/Problem [Re: plazomat] #1672500
09/17/14 11:40 AM
09/17/14 11:40 AM
At first blush I'd be leery of it but way back Eberg recommended it as a safe fix & if he's OK with it then I'm OK with it
Re: Manual Disc Master Cylinder Questions/Problem [Re: plazomat] #1672501
09/17/14 12:21 PM
09/17/14 12:21 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
We run 70 C body masters on conversions.Even with all drums thats what I use.Never a problem.Rocky
Chrysler Firepower
Re: Manual Disc Master Cylinder Questions/Problem [Re: therocks] #1672502
09/17/14 09:20 PM
09/17/14 09:20 PM
plazomat Offline OP
plazomat  Offline OP
I don't see a dimple in the bore either. I think the 80 volare might be the answer that I was looking for, I will look around for that one.
Plaz
Re: Manual Disc Master Cylinder Questions/Problem [Re: plazomat] #1672503
09/17/14 09:39 PM
09/17/14 09:39 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
You need the little rubber grommet. I have a package of those if you need one. You can get them through Magnum.
Re: Manual Disc Master Cylinder Questions/Problem [Re: dart4forte] #1672504
09/17/14 10:05 PM
09/17/14 10:05 PM
BDW Offline
BDW  Offline
Copied this from Dr Diff
Re: Manual Disc Master Cylinder Questions/Problem [Re: BDW] #1672505
09/18/14 12:43 AM
09/18/14 12:43 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
For your application the 1-1/32" bore is recommended. The photo I posted is supposedly the m/c you currently have as that's what came up from Cardone when I punched in your p/n.
I'd pull the back clip and measure the piston. Could be the wrong part in the box.
You could do a search on Autozone or Advanced in the Niagara Falls / Buffalo area and just scoot down and grab one there - at half the cost of the unit up here !!!
Re: Manual Disc Master Cylinder Questions/Problem [Re: Stanton] #1672506
09/18/14 12:53 AM
09/18/14 12:53 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
My 70 e body had manual disc brakes and it was a 4 bolt. They are a common mc. Not sure if this info helped or not
Re: Manual Disc Master Cylinder Questions/Problem [Re: plazomat] #1672507
09/18/14 12:56 AM
09/18/14 12:56 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
'80 Volare shows the same part number you currently have.
Re: Manual Disc Master Cylinder Questions/Problem [Re: Stanton] #1672508
09/18/14 01:35 AM
09/18/14 01:35 AM
plazomat Offline OP
plazomat  Offline OP
I did pull the clip and the piston measures less than 1 inch in diameter - I guess that means its a 15/16 unit..I thought it was supposed to be a 1-1/32 - uh oh....
Thanks gents - at least I know what likely went wrong and I have some more shelf weight..
Plaz
Re: Manual Disc Master Cylinder Questions/Problem [Re: plazomat] #1672509
09/18/14 01:54 AM
09/18/14 01:54 AM
plazomat Offline OP
plazomat  Offline OP
Looks like the port sizes are wrong too-both at 3/8-24 - wrong part in box for sure....damm cardone.
Plaz
Re: Manual Disc Master Cylinder Questions/Problem [Re: plazomat] #1672510
09/18/14 11:29 AM
09/18/14 11:29 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The ports won't match originals on any of the m/c's.
Re: Manual Disc Master Cylinder Questions/Problem [Re: Stanton] #1672511
09/18/14 11:34 AM
09/18/14 11:34 AM
BDW Offline
BDW  Offline
What? Thought it was a direct bolt in for the lines?
