How much more pwr will a hotter cam shaft give me? #1672398
09/16/14 07:59 PM
09/16/14 07:59 PM
Nanaimo, BC
N
NOrrTH Offline OP
NOrrTH  Offline OP
N
Nanaimo, BC
Eddy 800 AVS
CH4B (to fit under the Air Grabber)
30 over 440, 10:1
Stealth heads
Comp Cam 21-223-4 .477 268 Dur
TTi 1 7/8 into 2.5"
stock torque converter
3:55
It goes good, lots of torque, but doesn't set the world on fire with approximately 450hp. It spins the wheels easy so I don't think a high stall converter will make it pull harder...unless I'm mistaken.
I'm limited to the intake manifold due to height restriction with the Air Grabber (gotta keep the motor stock looking)
So, how much more power could I get with a hotter cam? More than 50hp? If not I'm not going to bother.
'71 GTX N96 auto 3:55 '74 Challenger 440+6 4spd 4:10 '71 Duster 340 auto 4:10
Re: How much more pwr will a hotter cam shaft give me? [Re: NOrrTH] #1672399
09/16/14 11:12 PM
09/16/14 11:12 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Your current intake will hold the HP back from what it could be. You could get 50 HP with a hotter cam, but it would be Worthless with your stock vert. You would have no power below 4000 RPM.
You cant go much bigger on the cam without changing the vert.
Define your ability to spin? Can you break them loose @ 40 MPH?
Or just break them loose from a near stop and then spin them at will. Once they are broke loose you don't need much power to spin them off the line.
Breaking them loose at a rolling MPH is different.
Re: How much more pwr will a hotter cam shaft give me? [Re: NOrrTH] #1672400
09/16/14 11:14 PM
09/16/14 11:14 PM
Central NC
gch Offline
gch  Offline
Central NC
Leave it alone.Doubt you will find 50hp in any cam.Look at other areas such as exhaust,ignition,or porting the heads for extra power.
A stall converter will help it accelerate a lot quicker provided you have traction.
Re: How much more pwr will a hotter cam shaft give me? [Re: gch] #1672401
09/16/14 11:35 PM
09/16/14 11:35 PM
IN
ahy Offline
ahy  Offline
IN
It sounds like you have a strong well matched setup as is. More cam will will give it more top end and more "personality" (rough idle, fuel smell at idle, less lower end torque). Without other changes, as posted above, maybe not more performance. Suggest you enjoy as is unless you want to make a number of other changes besides cam.
Re: How much more pwr will a hotter cam shaft give me? [Re: NOrrTH] #1672402
09/17/14 12:01 AM
09/17/14 12:01 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
A good torque convertor will help way more and not be a PITA.
Sheldon
Re: How much more pwr will a hotter cam shaft give me? [Re: NOrrTH] #1672403
09/17/14 12:16 AM
09/17/14 12:16 AM
OT I'd suggest dialing in the A/F ratio and dist subsystems
Re: How much more pwr will a hotter cam shaft give me? [Re: RapidRobert] #1672404
09/17/14 02:03 AM
09/17/14 02:03 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
50 HP from just a cam swap is possible, but it will cost you. A solid roller setup will take a $1500 bite out of your wallet but will gain you that 50 HP.
An alternative is a bigger, nice flat tappet hydraulic and a switch to a Holley Street Dominator intake. They are fairly low profile but deliver great performance. As mentioned, get the Air/Fuel in tune along with a good ignition system and you'll easily gain 50 HP.
One final option: Axle gearing. A switch to a 3.91 or 4.10 will make it feel like you gained HP but the tradeoff is a mpg loss.
Re: How much more pwr will a hotter cam shaft give me? [Re: NOrrTH] #1672405
09/17/14 01:29 PM
09/17/14 01:29 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Cam swap will get you 10-15 hp. Fifty hp from a cam swap is a pipe dream, unless something else about the present combination is just totally screwed up. No cam no the planet is going to get you 50 hp with what you have now.
Switching to a higher stall converter is only an improvement if your car doesn't respond by just spinning the tires more, rather than actually accelerating faster. If you don't have the grip to handle the higher launch rpm, it can slow down.
Porting heads could get you 30-50 hp, depending on what's done to make the work match the rest of your combination. That gets my vote.
Re: How much more pwr will a hotter cam shaft give me? [Re: PorkyPig] #1672406
09/17/14 04:12 PM
09/17/14 04:12 PM
dogdays Offline
dogdays  Offline
Porting and keep your other stuff the same.
Modern Cylinder Head has a good program for Stealth heads.
Also spend some time on a chassis dyno and get the tuneup right. There may actually be 50hp in the tuneup.
R.
Re: How much more pwr will a hotter cam shaft give me? [Re: dogdays] #1672407
09/17/14 04:46 PM
09/17/14 04:46 PM
Nanaimo, BC
N
NOrrTH Offline OP
NOrrTH  Offline OP
N
Nanaimo, BC
Fantastic information. Thanks guys!
Re: How much more pwr will a hotter cam shaft give me? [Re: NOrrTH] #1672408
09/17/14 06:26 PM
09/17/14 06:26 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
While I don't think the intake is holding you back as much the convert and gear are. Anything biger would require a stall and a taller gear otherwise it might be a pig out of the hole. You could add 1.6 roller rockers that would add some lift. A 4 hole 1/2" spacer might help as well if you have room.
Coming soon!!!!
Re: How much more pwr will a hotter cam shaft give me? [Re: PorkyPig] #1672409
09/17/14 11:05 PM
09/17/14 11:05 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
"Cam swap will get you 10-15 hp. Fifty hp from a cam swap is a pipe dream"
Porky has a right to his opinion, but....... The only people that think like him are those that run mild cams and never exceed 4500 rpms. Thats fine for them.
Look at any magazine article where they take a stock rebuilt 383, 440 or even a 340 and look at the results. The biggest gains are almost always after they switch to a bigger cam. Pathetic results like a 10-15 HP gain from a cam swap would be a huge waste of time for the expense. You'd get 10 HP just by switching to 0w20 synthetic oil.
Re: How much more pwr will a hotter cam shaft give me? [Re: Kern Dog] #1672410
09/18/14 12:41 AM
09/18/14 12:41 AM
P
PorkyPig Offline
PorkyPig  Offline
P
Please, tell me how fast your street car is, how big your cam is, and what RPM you shift and turn throgh the traps.
I suspect you have no idea what I think or how I build my car.
Re: How much more pwr will a hotter cam shaft give me? [Re: NOrrTH] #1672411
09/18/14 12:57 AM
09/18/14 12:57 AM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
How would you know? What evidence do you have that you have 450 hp now?
I'm with Porky and dogday. You could probably find 30 hp in the tune
Re: How much more pwr will a hotter cam shaft give me? [Re: BSB67] #1672412
09/18/14 10:00 AM
09/18/14 10:00 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I understand why you run the ch4b but it really isn't a good manifold. They are very low with sharp corners. If you want to close in on that 50hp a fine tuned six pack will get you part of the way there. You wouldn't have Air Grabber issues with it.
Re: How much more pwr will a hotter cam shaft give me? [Re: scatpacktom] #1672413
09/18/14 12:37 PM
09/18/14 12:37 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
A 50 horsepower gain would take some better intake setup and at least 245 degrees of duration, I.E. a big jump in cam size and 10-12 inches of idle vacuum. CNC ported heads will probably net you half of that if you prefer to not give up any street manners. I would agree that I don't think you will find 50 usable horsepower out of any cam without other changes.
Do you want more horsepower or do you want the car to go faster? As the others said there is probably alot in your tune up.
Re: How much more pwr will a hotter cam shaft give me? *DELETED* [Re: RUNCHARGER] #1672414
09/18/14 01:07 PM
09/18/14 01:07 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Sheldon
Agreed...people always seem to overlook the converter. Good ones aren't cheap, but they are worth it in an automatic car.
Re: How much more pwr will a hotter cam shaft give me? [Re: dustergirl340] #1672415
09/18/14 02:33 PM
09/18/14 02:33 PM
dogdays Offline
dogdays  Offline
FD, of course you can get 50 hp from a cam swap from factory stocker to better cam, but he's already done that. He's running a Comp XE268, which has 224/230 @ 50 with 110LSA. This is a proven street cam which should be good for 1hp/cubic inch with decent heads.
Gaining ANOTHER 50hp from a cam swap will put him out of the streetable range, PP is right. Power band will start at 3500rpm, the car will be an absolute dog around town.
R.
Re: How much more pwr will a hotter cam shaft give me? [Re: dogdays] #1672416
09/18/14 06:07 PM
09/18/14 06:07 PM
Nanaimo, BC
N
NOrrTH Offline OP
NOrrTH  Offline OP
N
Nanaimo, BC
The machine shop that built the motor said they designed it to be 1hp/ci and be a great torquey street motor to work with my set up (stock vert, 3.55s) I believe they achieved that.
However, I wanted something more radical and said how about a stroker? They said you don't need that, don't want to do that to your numbers motor and you should be happy with a torquey 440.
I should be happy but I'd like another 100hp plus at least the torque I already have. It sounds like I'd have to go to heroic efforts to do that though (512ci, convert and 3.91's). I want it to pull HARD. Right now it just pulls quite good.
The idea of the six pack has been on my mind. That, a cam, vert and 3.91s should make the car snapier
Re: How much more pwr will a hotter cam shaft give me? [Re: NOrrTH] #1672417
09/19/14 09:14 AM
09/19/14 09:14 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm running a Turbo action 3800 and 3.91's w/ my six pack. Swaping converters, gears and intake/carbs isn't an easy or quick task. Not to mention cost. I have less motor and I can tell you this car is not a ton of fun on the street. Runs and drives nice but it explodes the tires (even the ET Pros) without much effort.
