Locating and mounting '71 RR chin spoilers? #1671811
09/16/14 12:22 AM
09/16/14 12:22 AM
Houston, Texas
Slant6pak Offline OP
Houston, Texas
Hey guys,
I totally don't need them right now, but I purchased a repop set of chin spoilers for my '71 Roadrunner clone.
They were made by First Place Auto Products, which IIRC are the best reproductions out there. There are molded plastic, not fiberglass.
Anyway, they didn't come with any mounting instructions, somebody wouldn't happen to have a nifty diagram for getting them in right place, would they?
Also, for those that have used them before? Any advice? Did you leave them bare plastic or paint them, etc?
Thanks in advance.
2016 Challenger Scat Pack Shaker smile
1000 ci Brass Era Speedster project
Re: Locating and mounting '71 RR chin spoilers? [Re: Slant6pak] #1671812
09/16/14 01:49 AM
09/16/14 01:49 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I used the 'line' between the valance, and the fender as a horizontal reference...
Use your eye to 'center'...
Mine are ABS; no paint...
Mounted 'em using SS hardware...(Bolts, flats, locks, nuts)..
They look the same as they did when they went on 20 years ago...
(Might catch a few bugs, if'n you're gonna drive)...
Re: Locating and mounting '71 RR chin spoilers? [Re: RSNOMO] #1671813
09/16/14 02:17 AM
09/16/14 02:17 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Yup.
Sheldon
Re: Locating and mounting '71 RR chin spoilers? [Re: Slant6pak] #1671814
09/16/14 10:48 AM
09/16/14 10:48 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Leave them unpainted, they will look better. The reason there wasn't any instructions is that there never was any instructions. They came in the trunk, and the dealer installed them where ever they thought was right. I even know of one car that has them on backwards.
Re: Locating and mounting '71 RR chin spoilers? [Re: 71birdJ68] #1671815
09/17/14 12:24 PM
09/17/14 12:24 PM
Houston, Texas
Houston, Texas
Thanks for the pics guys,
I'll save those for future reference. Two quick question, did you guy dress down the rough molded edges on the spoilers?
And what is the correct way to fasten them to the fenders? I have the hardware kit, do the nuts go inside the fender with the bolts and washers on the outside?
