Page 1 of 3 1 2 3
Who's running a 543 Wedge in a Stock Block? #1671289
09/15/14 03:05 PM
09/15/14 03:05 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
How do you like it, and I am assuming your running a girdle as well. I have a 512 currently, and it is been awesome. I intend to build a spare short block this winter, and I was thinking of the 543 option this go around....Heck is 6.14's in the 1/8th are awesome on pump gas...I am sure a 543 will even be better...
Re: Who's running a 543 Wedge in a Stock Block? [Re: Dragula] #1671290
09/15/14 05:07 PM
09/15/14 05:07 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Watched you go down the track yesterday....I was up with Wafflebatter (Doug with the roadster)
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Who's running a 543 Wedge in a Stock Block? [Re: Eric] #1671291
09/15/14 06:25 PM
09/15/14 06:25 PM
Dragula Offline OP
Dragula  Offline OP
Attendance was very low yestarday....Sorry I didn't see you their. Stop over next time...I was kinda still hurting from surgey earlier in the week, and was just off a little....Cut a .500 light in first time trial though, followed by a couple of .470's.
Only to break out in first round with a 6.15...on a 6.16 dial when it rain a pair of 6.17's in time trials. I would have hit the brakes, but I got stuck in the left and it has the big bump at the end. I have to clear that before hitting the brakes hard. Oh well... Nothing broke, so it was a good day.
Re: Who's running a 543 Wedge in a Stock Block? [Re: Dragula] #1671292
09/15/14 11:22 PM
09/15/14 11:22 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Built mine in 2010
Was dialed 6.00 Friday night in soup air. 85% humidity
Would have gone a 5.96 or so if I didn't peddle for a round win.
Re: Who's running a 543 Wedge in a Stock Block? [Re: FastmOp] #1671293
09/15/14 11:32 PM
09/15/14 11:32 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Would this be in an RB or B block??
Re: Who's running a 543 Wedge in a Stock Block? [Re: mshred] #1671294
09/15/14 11:41 PM
09/15/14 11:41 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Mine is an RB block. 1977 casting
It has a little more in it but I don't run the car on the ragged edge. I'd rather keep a little off the edge for reliability. It Is a stock block lol my roller is under .700
I also have a tall fill in it and its a 541 since I'm .055 over.
No girdle, stock caps with ARP studs.
It's 440 source crank and pistons, I went with aluminum rods. And had it balanced locally.
Re: Who's running a 543 Wedge in a Stock Block? [Re: FastmOp] #1671295
09/16/14 12:16 AM
09/16/14 12:16 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
What do you keep your rpm,s limited and whats the comp? Nice numbers,
Re: Who's running a 543 Wedge in a Stock Block? [Re: Sport440] #1671296
09/16/14 01:06 AM
09/16/14 01:06 AM
Dragula Offline OP
Dragula  Offline OP
Launch at 2100 and shift at 6400...This would be an RB block and it would have a girdle....Current engine on pump gas is putting out right around 730...with the small carburator, and OOTB heads.
Re: Who's running a 543 Wedge in a Stock Block? [Re: Dragula] #1671297
09/16/14 04:07 AM
09/16/14 04:07 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I built one 4.5" sroke 440 a few years back for a egular street car. t had homeportd RPM heads, team G intake and a Scotto Brown specced mech roller cam. Worked great and made hue torque, the stock suspension 3600+ lbs car with 3.23 gears, powerglide and 275 M/T ET radial streets run 10.4 in the 1/4. For making power at highter rpm levels bigger port heads are a must!
Plynouth VIP '67 TT IC EFI
Re: Who's running a 543 Wedge in a Stock Block? [Re: Dragula] #1671298
09/16/14 05:08 AM
09/16/14 05:08 AM
Cab_Burge Online work
Cab_Burge  Online Work
If your talking about using a 4.500 stroke crank in a stock 440 block and race it when do you expect that grenade to explode? I wouldn't put that large of a load on the 440 main webs, even with a "girdle" and block filler Remember the designed strength of the B and RB type blocks is in the oil pan rail supports and block skirt, the main webs are not intended or designed to hold much above 700 HP. Sticking a set of main studs and using the oil pan bolts to hold a girdle on the bottom is not my idea of a good design, more like a poor bandiad
Save your money and buy a good block to start with
Re: Who's running a 543 Wedge in a Stock Block? [Re: Cab_Burge] #1671299
09/16/14 08:48 AM
09/16/14 08:48 AM
ill
dennismopar73 Offline
ill
Well , i do not run that stroker but I know of 2 that run very well deep into 9,30 with
410 geared cars , 3000# with pro comp full port max wedge heads,,
have been together for several years with just normal issues in refreshing after 2 years of campaining
How ever,,
I have seen those same cars run 9.40 with 500 stroked motors and stock out of
the box RPM heads
Finding the right combo , right mix of parts
Being able to tune a combo, tires gear converter
Is an age ole racers search as much as the fountain of
youth
Re: Who's running a 543 Wedge in a Stock Block? [Re: Dragula] #1671300
09/16/14 11:24 AM
09/16/14 11:24 AM
gregsdart Offline
gregsdart  Offline
I wouldn't plan a 4.5 stroke in a 440 block for anything beyond about 600 hp, and then only if I had a very light rotating assembly and / or a center weighted crank to help relieve stress on the bottom end combined with small port heads. I ran a 4.5 x 4.350 bore combo for a while, shifting at 5700 till I ran over the crank. It was cracked and only went about 300 passes. The block showed cap walk though.
Re: Who's running a 543 Wedge in a Stock Block? [Re: gregsdart] #1671301
09/16/14 02:43 PM
09/16/14 02:43 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I wouldn't plan a 4.5 stroke in a 440 block for anything beyond about 600 hp, and then only if I had a very light rotating assembly and / or a center weighted crank to help relieve stress on the bottom end combined with small port heads....
At that point, why bother with the long stroke if you're not going after a big HP number? Get a Megablock or other aftermarket block, let it eat, and sleep soundly.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Who's running a 543 Wedge in a Stock Block? [Re: DusterDave] #1671302
09/16/14 03:27 PM
09/16/14 03:27 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Re: Who's running a 543 Wedge in a Stock Block? [Re: DusterDave] #1671303
09/17/14 07:13 AM
09/17/14 07:13 AM
gregsdart Offline
gregsdart  Offline
The reasons are budget, what's on hand and the torque range desired.
Re: Who's running a 543 Wedge in a Stock Block? [Re: gregsdart] #1671304
09/17/14 07:38 AM
09/17/14 07:38 AM
Dragula Offline OP
Dragula  Offline OP
Some interesting replies....So nobody over +700hp stroker in a stock block? According to some on here, ours should have blown up 3 seasons ago...I have no doubt it will eventually let go, but I have a stock block sitting here, so I would like to build a spare.
Re: Who's running a 543 Wedge in a Stock Block? [Re: Dragula] #1671305
09/17/14 08:55 AM
09/17/14 08:55 AM
gregsdart Offline
gregsdart  Offline
If you are over 700 hp now, then you won't build any less on the next one, right? I would sell the stock block and go with a better one. I know that is not cheap, but when you figure the cost of a broken engine, and most likely a lost weekend and down time, and it gets a lot cheaper! On top of that, you would have options of a bigger bore. That almost always helps hp. Also You could buy the after market block, have everything but the bore and hone done to leave options open, and it wouldn't take long to put another together.
Re: Who's running a 543 Wedge in a Stock Block? [Re: gregsdart] #1671306
09/17/14 10:40 AM
09/17/14 10:40 AM
ill
ill
Stock blocks are cheap easy to come by
If a motor blows it doesnt matter if it is a 200$ block or a
5000$ block
If your paying attention to your motors pulling maintains and certain refresh methods
you can get alot of years of trouble free use out of stock block
As i stated before the 540 we have in our stable none have blown up
And been together for number of years now
You have to know the number of how long do you dare run any rod combo under
any race prepped motor
Engine builder and balancer is key as well as tune and damage done by inenvertant
Operator errors
Stock blocks do work will work is there a cap as to how much how far
Sure but that goes for any block any combo out there
I have seen so many high end blocks hurt beyond repair i just stay with
my stock blocks thank you
Re: Who's running a 543 Wedge in a Stock Block? [Re: dennismopar73] #1671307
09/17/14 01:05 PM
09/17/14 01:05 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The thing about a high HP stock block motor, is that you NEVER KNOW. You are using a 30-40 year old block that may be good or not, but was never intended to make more than about 600HP in any configuration. Its a crap shoot at best.
Just because so and so has a motor that has lasted fine is totally irrelevant. That's not your motor. Now, could you break a GOOD block........sure you could but the percentages go WAY down.
A high HP stock block may last 1000 runs, 100 runs or 10 runs........you just don't know. I have in the past had stock block motors that made over 1000hp on nitrous. Would I build that now??...............hell no, because I know it is a bomb waiting to go off and will most likely ruin everything when it does. I understand a budget, but what is cheaper, a block...........or a block, crank, rods, pistons, cam and potentially heads.
A girdle or any of that other crap you bolt on the bottom of one is NOT a fix, it is simply a weak bandaid for thinly cast main webs. It might help, but most likely not. So and so having a motor with a girdle that has lasted is not a sound argument, because you don't KNOW if it would be broken without it. I never ran one. I chose to run alum rods and alum caps to absorb some shock( which is what breaks blocks).
Bottom line...........stock block is a crap shoot. Proceed at your own risk
Monte
Re: Who's running a 543 Wedge in a Stock Block? [Re: Monte_Smith] #1671308
09/17/14 02:20 PM
09/17/14 02:20 PM
Bellevue, NE
Charger453 Offline
Charger453  Offline
Bellevue, NE
I just cracked my block above the #2 main. My motor had been a mid-11 second combo in a 3900# Charger for a few years, then became a mid-10 second car and I recently ran 6.27 @ 113+ in the same car. I wanted to do a gen 3 hemi but the cost for a complete swap is nuts.
Page 1 of 3 1 2 3
