Re: indy aluminum block
[Re: robnbird]
#1670633
09/13/14 07:31 PM
09/13/14 07:31 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
the main stud torque is stamped on the bottom of the block in the corner. Head studs/bolts go by what you are using
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: rebel]
#1670635
09/13/14 09:58 PM
09/13/14 09:58 PM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
90lbs on the vertical caps, 80lbs on the horizontal. ARP head studs we do at 75lbs.
[Re: rebel]
#1670636
09/13/14 10:24 PM
09/13/14 10:24 PM
Posts: 16,928 NC
440Jim
NC
Do the head studs go into the block ~1" (like an iron block) or do you use other studs to get more threads in the aluminum block?
