Taking off lug nut locks #1670295
09/12/14 02:53 PM
09/12/14 02:53 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang...
Going off the beaten path here that someone may have gone down this road. I just got this car but don't have the lug nut key for this lock nut........... I'm running out of ideas on how to get the bloody thing off....... Any suggestions?
I haven't been able to find this particular set of lug nut locks online...
Troy
Houston Mopar Connection Club
Re: Taking off lug nut locks [Re: hemi68charger] #1670296
09/12/14 02:53 PM
09/12/14 02:53 PM
Houston, Tx
Houston, Tx
Closer......
Troy
Re: Taking off lug nut locks [Re: hemi68charger] #1670297
09/12/14 02:58 PM
09/12/14 02:58 PM
dogdays Offline
dogdays  Offline
Screw-type EZ-out socket.
Sold by Sears.
R.
Re: Taking off lug nut locks [Re: hemi68charger] #1670298
09/12/14 03:00 PM
09/12/14 03:00 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Pound a snug fitting (beater) chrome 12 point deep well socket on it.
Re: Taking off lug nut locks [Re: hemi68charger] #1670299
09/12/14 03:02 PM
09/12/14 03:02 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Snap on and others make universal sockets to get locking lugs nuts off.
Re: Taking off lug nut locks [Re: buildanother] #1670300
09/12/14 03:03 PM
09/12/14 03:03 PM
Houston, Tx
Houston, Tx
That was my first try.. But nothing thus far....... May see about finding these sockets...
Troy
Re: Taking off lug nut locks [Re: dogdays] #1670301
09/12/14 03:12 PM
09/12/14 03:12 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Sold by Sears.
R.
I've got a set of this type. Works every time,,,,,as long as they are right hand threads.
Re: Taking off lug nut locks [Re: gtx6970] #1670302
09/12/14 03:19 PM
09/12/14 03:19 PM
Spring City , Pa.
SIKPUP Offline
SIKPUP  Offline
Spring City , Pa.
Air hammer and chisel bit in the direction to loosen lug... Put thick rags around the wheel and use caution.
Re: Taking off lug nut locks [Re: SIKPUP] #1670303
09/12/14 03:36 PM
09/12/14 03:36 PM
dogdays Offline
dogdays  Offline
Re: Taking off lug nut locks [Re: SIKPUP] #1670304
09/12/14 03:36 PM
09/12/14 03:36 PM
Andrewh Offline
Andrewh  Offline
maybe the picture is deceptive.
it looks like you could grab it with vice grips.
Re: Taking off lug nut locks [Re: hemi68charger] #1670305
09/12/14 03:57 PM
09/12/14 03:57 PM
Vicksburg, MI
coffeeman383 Offline
Vicksburg, MI
Grind off chrome, MIG weld on a nut?
Re: Taking off lug nut locks [Re: Andrewh] #1670306
09/12/14 04:00 PM
09/12/14 04:00 PM
Central TX
roe Offline
roe  Offline
Central TX
Any reputable tire shop can knock it out quick. Or you can buy what they use, I think they're called gator grip. They run across this all the time
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Taking off lug nut locks [Re: hemi68charger] #1670307
09/12/14 04:03 PM
09/12/14 04:03 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Looks like the locks they used to sell at the local parts stores back in the day... I may even have a set sitting in the garage yet. I usually do the air chisel route myself.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Taking off lug nut locks *DELETED* [Re: hemi68charger] #1670308
09/12/14 04:06 PM
09/12/14 04:06 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Post deleted by Grizzly
Mo' Farts
Moderated by "tbagger".
Re: Taking off lug nut locks [Re: Grizzly] #1670309
09/12/14 04:21 PM
09/12/14 04:21 PM
Houston, Tx
Houston, Tx
Thanks guys..
I was looking to see if there were any basic garage tools I could use..
1. Don't have an air chisel
2. don't want to beat it with a chisel and hammer and risk really messing up the wheel finish
3. I'm going to try
http://www.oreillyauto.com/site/c/detail/PFM0/M980/N1772.oap
Troy
Re: Taking off lug nut locks [Re: hemi68charger] #1670310
09/12/14 10:56 PM
09/12/14 10:56 PM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
Those look like the lugs on my truck I would try Discount tire.. if you were closer I would let you use mine to remove them..
Re: Taking off lug nut locks [Re: rumblebee4232] #1670311
09/12/14 11:45 PM
09/12/14 11:45 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
http://www.brandsport.com/gorewhloke.html
go here..i bought my sons key here also a 12 point key bought the car used..look close at the lock and compare
Re: Taking off lug nut locks [Re: AARCONV] #1670312
09/12/14 11:58 PM
09/12/14 11:58 PM
Raleigh, NC
Meangreen68 Offline
Meangreen68  Offline
Raleigh, NC
Access Tools also makes a tool for removing locking lugnuts. Google "aet-eo"
Re: Taking off lug nut locks [Re: hemi68charger] #1670313
09/13/14 11:20 AM
09/13/14 11:20 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
All you need:
The pins will likely slide in far enough to get to the cuts in the nuts.
- Stu Harmon
Re: Taking off lug nut locks [Re: hemi68charger] #1670314
09/13/14 03:15 PM
09/13/14 03:15 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
hemi the pic you posted is what I have.Used mine at work a bunch and they work.Its a bear to get the locks out of them sometimes though.I think mine were like 10 bucks when I got them.Rocky
Chrysler Firepower
