Small Block - Bottom Feed Oil Pump Pick up #1669816
09/10/14 06:54 PM
09/10/14 06:54 PM
Australia
MisterBee Offline OP
Australia
Does anyone know where I can get a bottom feed oil pump pick up? It's for a little stroker build up I'm gathering parts for.
I've been reading up on the subject a bit, and they get a mention in Jim Szigalgyi's "How to Build a Big Inch Small Block" book (copy of reference attached).
They seem like a really simple, logical solution to both oil supply volume and clearancing for a stroker crank. But I cant find a supplier.
I've tried Moroso, Milodon and Canton (the last two say they used to make them but don't anymore).
Even if someone has a second hand one I could buy I'd like to hear from them!
Shannon
Re: Small Block - Bottom Feed Oil Pump Pick up [Re: MisterBee] #1669817
09/10/14 06:59 PM
09/10/14 06:59 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Kevco oil pans. They got em!
Re: Small Block - Bottom Feed Oil Pump Pick up [Re: J_BODY] #1669818
09/10/14 08:42 PM
09/10/14 08:42 PM
Australia
Australia
Thanks!
Re: Small Block - Bottom Feed Oil Pump Pick up [Re: MisterBee] #1669819
09/10/14 11:19 PM
09/10/14 11:19 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I might add that they are part numbers listed specifically for their pans. Believe they are made in house.
Re: Small Block - Bottom Feed Oil Pump Pick up [Re: J_BODY] #1669820
09/11/14 04:42 AM
09/11/14 04:42 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I have an old Direct connection cover that uses BB oil pump rotors. Wonder why no one makes them anymore, should be pretty easy with current CNC equipment?
Plynouth VIP '67 TT IC EFI
Re: Small Block - Bottom Feed Oil Pump Pick up [Re: jyrki] #1669821
09/11/14 08:12 AM
09/11/14 08:12 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I have though about it, but it would have to be something fairly generic due to all of the different oil pans out there. I make one of these pick ups for me own engine and it seems to work out fine.
Alan Jones
Re: Small Block - Bottom Feed Oil Pump Pick up [Re: MisterBee] #1669822
09/11/14 02:14 PM
09/11/14 02:14 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
The Milodon SS pan system uses that type of cover.
Re: Small Block - Bottom Feed Oil Pump Pick up [Re: Leigh] #1669823
09/11/14 08:34 PM
09/11/14 08:34 PM
Australia
Australia
I rang Milodon and they were fairly unhelpful to be honest.
The bloke I spoke to gave fairly short answers like "we don't make that anymore", "that's not possible" etc. I certainly wont be rushing back to buy any of their products.
The other thing that surprises me, is that it's very clear from my reading of "How to Build Big Inch Small Blocks" is Jim Szilagyi's comments regarding the use of HV oil pumps with anything other than this type of pick up, is pretty much a waste of time because there's insufficient capacity in the standard inlet location to flow the volume of oil that most HV pumps pull (+25%). Even the thin wall larger diameter tubes don't.
It appears to me this type of pick up should be used in most performance applications...I must be missing something!
Shannon
Re: Small Block - Bottom Feed Oil Pump Pick up [Re: MisterBee] #1669824
09/11/14 09:32 PM
09/11/14 09:32 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
My gut feeling , and it has developed and changed over the years , is that the HV pump is not necessary on a tight motor at all.
And with looser clearances or wear is only a band aid.
I used the pick up that came with my pan ( Stef's ) and a HV pump on my thing , but clearances are on the high end of things and I have capacity and an accusump to ensure that there is oil to be picked up.
When I primed the motor on the stand , I was fairly surprised at how much oil sits up stairs in this ........ not so much in the heads , but the valley will hold quite a bit. ( R-3 block )
Even after doing a couple things to help with drain back.
If I go down this road again , it will be a dry sump.
If I am doing a milder deal , it will be standard volume.
But for most builds I think the standard volume pump is up to the task.
Re: Small Block - Bottom Feed Oil Pump Pick up [Re: tubtar] #1669825
09/11/14 09:47 PM
09/11/14 09:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I made up my own pick up that I use with the HV pump...
I have a lot of built in leaks and the standard pump
wouldnt give me the pressure I wanted... it is a thinner
wall tube that I bent up to fit my pan(I built the
pan also).. when I primed the oil system with the
standard it barely hit 60# and the HV pump did hit
70# which is basically the opening point of the by-pass
when using a drill motor... I didnt use the bottom
feed style and stayed with the original inlet on the pump
(this is on my 416)
Re: Small Block - Bottom Feed Oil Pump Pick up [Re: MR_P_BODY] #1669826
09/15/14 07:43 PM
09/15/14 07:43 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
I make the pump mounted pick-ups. I think I have one non anodized one left in stock. Mine are designed to fit either an early hemi pump or the late SBM pump, that is why the bolt holes are slotted.
If I get enough interest via email, I will do another run of these. info@trwaters.com
Re: Small Block - Bottom Feed Oil Pump Pick up [Re: TrWaters] #1669827
09/16/14 01:53 AM
09/16/14 01:53 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Email sent, very interested.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
