Driveshaft Upgrade - What do I need #1668689
09/07/14 10:47 PM
09/07/14 10:47 PM
Lake Orion, MI
goldduster318 Offline OP
Lake Orion, MI
I have a 1970 Duster with a 340 4-speed and an 8 3/4. Engine made 470hp and 455 lb-ft. I currently have a stock driveshaft that's about 2 1/2" diameter with the 7260 U-joints. This factory driveshaft seems to have some jump-rope effect going on, and also makes me a bit nervous with this amount of power.
I see that there are a lot of options out there. At what power level would you need chromemoly tubing, forged weld yokes, etc. Please make a recommendation. I would like to go for 1350 U-joints.
Also, it seems that I always have to measure the driveshafts- you'd think the measurements for this application would already be available...
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Driveshaft Upgrade - What do I need [Re: goldduster318] #1668690
09/07/14 10:59 PM
09/07/14 10:59 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
If I were having a new shaft made I wouldn't do anything less than 1350 joints Plenty of room to grow in the future and you have more joint than you need for now.
Gus
64 Plymouth Savoy
Dana 60
Re: Driveshaft Upgrade - What do I need [Re: fourgearsavoy] #1668691
09/07/14 11:24 PM
09/07/14 11:24 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
on the 1350 joints especially with a stick. Then you can put a set of slicks on and test out your 8 3/4.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Driveshaft Upgrade - What do I need [Re: 71yelladustr] #1668692
09/07/14 11:36 PM
09/07/14 11:36 PM
Lake Orion, MI
Lake Orion, MI
Yep - 1350's it is.
What about the material for the tube and weld yokes?
Re: Driveshaft Upgrade - What do I need [Re: goldduster318] #1668693
09/07/14 11:47 PM
09/07/14 11:47 PM
Missouri U.S.A.
Missouri U.S.A.
Forged yokes with u bolts instead of straps. Chrome moly shaft a little overkill for your application IMHO. Id say we are close in power output and beat on mine pretty hard.I don't have a chrome moly tube in mine and is holding up just fine.
10.02@134
Re: Driveshaft Upgrade - What do I need [Re: goldduster318] #1668694
09/08/14 01:58 AM
09/08/14 01:58 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Strange Engineering has a heck of a deal on custom drive shafts with forged ends and the rest of the parts.
I'm calling Dr Diff and he'll have the stuff drop shipped from them. I like hearing his advice and rely on his wisdom regarding drivelines, plus he's great to deal with.
Re: Driveshaft Upgrade - What do I need [Re: goldduster318] #1668695
09/08/14 02:32 AM
09/08/14 02:32 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I recommend DoctorDiff/Strange 1350 driveshaft assy:
Strange Engineering street/strip driveshaft with Spicer slip yoke, Spicer U-joints, Spicer Weld yokes and 3" cr-mo tube
DoctorDiff forged steel 1350 pinion yoke includes U-bolts
http://www.doctordiff.com/strange-engineering-driveshaft.html
Re: Driveshaft Upgrade - What do I need [Re: DoctorDiff] #1668696
09/08/14 09:21 PM
09/08/14 09:21 PM
Lake Orion, MI
Lake Orion, MI
Seems reasonable.
Now with the measuring part. I'd have to measure for the driveshaft with a 7260 yoke installed when I'd really be using a 1350 yoke. Will this throw it off? It's not easy to get under the car at ride height. Guess I'll throw some jackstands under the rear axle.
I just can't believe that there isn't a known measurement for a 108" WB A-body with an A-833 (or 904 for that matter).
Re: Driveshaft Upgrade - What do I need [Re: goldduster318] #1668697
09/08/14 09:26 PM
09/08/14 09:26 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
A 340 at 470 hp and an 8.75 and considering 1350's IMO is a good candidate for an ALUM DS.
Re: Driveshaft Upgrade - What do I need [Re: goldduster318] #1668698
09/08/14 10:40 PM
09/08/14 10:40 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Seems reasonable.
There is a known measurement (assuming you mean the original/factory length), the Chrysler parts book as well as the FSM has that info. When I get home I will post the length if nobody else has by then.
There used to be a chart in the tech archives here on Moparts. I took a quick look but did not see it.
Re: Driveshaft Upgrade - What do I need [Re: goldduster318] #1668699
09/08/14 11:37 PM
09/08/14 11:37 PM
I'd find out if the 1350 and the 7260 front yokes are the same (for distance) & if not then I'd get it in hand (or borrow one) & install it with the front and rear (axle) up on stands (vehicle fairly level) & butt the yoke all the way in the trans & get an exact C to C distance then subtract 3/4-7/8" from that dimention but go with what Doc says, he's the man but (just me) I would not go with a "known A body shaft measurement"
Re: Driveshaft Upgrade - What do I need [Re: goldduster318] #1668700
09/09/14 01:05 AM
09/09/14 01:05 AM
smyrna,tn
draginmopars Offline
smyrna,tn
Seems reasonable.
We searched for the tech specs, in order to have a shaft built,but couldn't find the exact measurement differences of the 7260 vs 1350
So, we ended up just getting the yokes and joints for the Dart and Satellite (Thanks Dr.Diff)
and having our local drive shaft man, tube them for us.
Here are some pics of the shaft yokes
the (727)trans yoke is .650" longer with the joint cups centered as best I could eye ball it
the shaft yoke appears .500" longer
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Driveshaft Upgrade - What do I need [Re: goldduster318] #1668701
09/09/14 02:42 AM
09/09/14 02:42 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You can measure off the 7290 pinion yoke, but the 1350 slip yoke dimension is totally different.
Re: Driveshaft Upgrade - What do I need [Re: DoctorDiff] #1668702
09/09/14 03:00 AM
09/09/14 03:00 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If I did not have the right yoke I usually borrowed one as I always measured any cars driveshaft I was having made even if I had what the readings were supposed to be. Always do a center to center reading and have the shaft made the right size the first time. Ron
Re: Driveshaft Upgrade - What do I need [Re: DoctorDiff] #1668703
09/09/14 07:27 PM
09/09/14 07:27 PM
Lake Orion, MI
Lake Orion, MI
I have the 7260 yoke on the diff still (will replace it with the 1350 of course). Is that still okay to measure with?
Also, when I look at the photo
It shows dimension "A" to be basically from the edge of the yoke at the diff when the directions say the center line of the U-joint. I can pretty easily get the A and B dimensions I think.
Thanks again.
Re: Driveshaft Upgrade - What do I need [Re: goldduster318] #1668704
09/10/14 01:21 AM
09/10/14 01:21 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes, the measurement will be the same.
