Driveshaft Upgrade - What do I need
#1668689
09/07/14 10:47 PM
09/07/14 10:47 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
I have a 1970 Duster with a 340 4-speed and an 8 3/4. Engine made 470hp and 455 lb-ft. I currently have a stock driveshaft that's about 2 1/2" diameter with the 7260 U-joints. This factory driveshaft seems to have some jump-rope effect going on, and also makes me a bit nervous with this amount of power.
I see that there are a lot of options out there. At what power level would you need chromemoly tubing, forged weld yokes, etc. Please make a recommendation. I would like to go for 1350 U-joints.
Also, it seems that I always have to measure the driveshafts- you'd think the measurements for this application would already be available...
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Driveshaft Upgrade - What do I need
[Re: goldduster318]
#1668690
09/07/14 10:59 PM
09/07/14 10:59 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
If I were having a new shaft made I wouldn't do anything less than 1350 joints Plenty of room to grow in the future and you have more joint than you need for now. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 71yelladustr]
#1668692
09/07/14 11:36 PM
09/07/14 11:36 PM
goldduster318
Lake Orion, MI
Yep - 1350's it is.
What about the material for the tube and weld yokes?
[Re: goldduster318]
#1668694
09/08/14 01:58 AM
09/08/14 01:58 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Strange Engineering has a heck of a deal on custom drive shafts with forged ends and the rest of the parts.
I'm calling Dr Diff and he'll have the stuff drop shipped from them. I like hearing his advice and rely on his wisdom regarding drivelines, plus he's great to deal with.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: DoctorDiff]
#1668696
09/08/14 09:21 PM
09/08/14 09:21 PM
goldduster318
Lake Orion, MI
Seems reasonable.
Now with the measuring part. I'd have to measure for the driveshaft with a 7260 yoke installed when I'd really be using a 1350 yoke. Will this throw it off? It's not easy to get under the car at ride height. Guess I'll throw some jackstands under the rear axle.
I just can't believe that there isn't a known measurement for a 108" WB A-body with an A-833 (or 904 for that matter).
[Re: goldduster318]
#1668697
09/08/14 09:26 PM
09/08/14 09:26 PM
Posts: 22,696 Bitopia
jcc
Bitopia
A 340 at 470 hp and an 8.75 and considering 1350's IMO is a good candidate for an ALUM DS.
[Re: goldduster318]
#1668698
09/08/14 10:40 PM
09/08/14 10:40 PM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
Seems reasonable.
There is a known measurement (assuming you mean the original/factory length), the Chrysler parts book as well as the FSM has that info. When I get home I will post the length if nobody else has by then.
There used to be a chart in the tech archives here on Moparts. I took a quick look but did not see it.
[Re: goldduster318]
#1668699
09/08/14 11:37 PM
09/08/14 11:37 PM
RapidRobert
I'd find out if the 1350 and the 7260 front yokes are the same (for distance) & if not then I'd get it in hand (or borrow one) & install it with the front and rear (axle) up on stands (vehicle fairly level) & butt the yoke all the way in the trans & get an exact C to C distance then subtract 3/4-7/8" from that dimention but go with what Doc says, he's the man but (just me) I would not go with a "known A body shaft measurement"
[Re: DoctorDiff]
#1668702
09/09/14 03:00 AM
09/09/14 03:00 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
If I did not have the right yoke I usually borrowed one as I always measured any cars driveshaft I was having made even if I had what the readings were supposed to be. Always do a center to center reading and have the shaft made the right size the first time. Ron
