Intake manifold and carb #1667716
09/05/14 09:34 AM
09/05/14 09:34 AM
Chicago
rocksmopar Offline OP
Chicago
Here's a question, I have a 1971 360 block with an Eagle 408 stroker kit installed. I also have a set of Edelbrock cylinder heads (63cc) pushing compression to about 10.2 to 1. Finally a 480 lift cam. Which intake and carb cfm is the best? Is the cam big enough? It's a street motor so a dual plane will be used but what brand and model?
Looking for affordable 72-74 Cuda parts
Re: Intake manifold and carb [Re: rocksmopar] #1667717
09/05/14 10:50 AM
09/05/14 10:50 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You could use some more cam... maybe try a set of 1.6 rockers... I'd just go w/ an RPM air-gap and call it a day.
Coming soon!!!!
Re: Intake manifold and carb [Re: Mr.Yuck] #1667718
09/05/14 12:57 PM
09/05/14 12:57 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Just switched from a Victor single plane back to a RPM Air-Gap and low end performance picked right up. I'm running a 700cfm Holley on my 360 but would recommend a 750 minimum for your stroker.
I think that the cam is going to be real mild with the added cubes. I'd be looking more to the .510 to .550 range if it were mine and had the valve to piston clearance. Then have to consider new springs possibly.
Re: Intake manifold and carb [Re: Mr.Yuck] #1667719
09/05/14 12:57 PM
09/05/14 12:57 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
going to be real tough to beat an RPM-AirGap and a 750 holley on that combo. A-body with decent gears, I'd try a double pumper. B-Body or anything taller than 3.73's, a vacuum secondary might work better.
Re: Intake manifold and carb [Re: StealthWedge67] #1667720
09/06/14 02:12 PM
09/06/14 02:12 PM
Central NC
gch Offline
gch  Offline
Central NC
Re: Intake manifold and carb [Re: StealthWedge67] #1667721
09/07/14 12:31 PM
09/07/14 12:31 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Another vote for the Air Gap. And 750cfm is probably a good choice, but being a street car, the new Street Demon might be a better carb choice.
Carb preferences for the street has been discussed here several times lately.
Master, again and still
Re: Intake manifold and carb [Re: DaveRS23] #1667722
09/07/14 09:36 PM
09/07/14 09:36 PM
Beavercreek, Ohio
OA5599 Offline
OA5599  Offline
Beavercreek, Ohio
Another vote for Air-Gap. Every dyno article I've read told me it was the one for me. I run mine with a 770 Holley Ultra Street Avenger. Great carb. Switch from a 750 DP. I like the vac secondary on the street, along with the electric choke. Car runs low 11s with an Eddy headed 418 stroker small block and still very street friendly. Nothing wrong with a DP, just telling you what I went with.
Re: Intake manifold and carb [Re: OA5599] #1667723
09/17/14 11:28 AM
09/17/14 11:28 AM
Chicago
Chicago
Air Gap it is!!, I forgot to mention this is going into my 73 Barracuda with 3.73 gears and a column shift 727. Also I'm gonna go with the edelbrock 750cfm electic choke carb and a 500+ lift cam. I will save the .480 lift for something down the road.
Thanks to everyone for the advice.
Re: Intake manifold and carb [Re: rocksmopar] #1667724
09/17/14 01:30 PM
09/17/14 01:30 PM
dogdays Offline
dogdays  Offline
I hope you haven't bought that 750 Ebrock yet. There's about a 4:1 chance it'll never run right. Do a Web search and see.
Instead, buy the 750 Street Demon with the polymer body. Bolts right on, runs awesome and now that Holley owns the Demon brand they are great carbs.
R.
Re: Intake manifold and carb [Re: dogdays] #1667725
09/17/14 02:30 PM
09/17/14 02:30 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i would go with the holley 950hp, especially if you have a higher stall.
Re: Intake manifold and carb [Re: ademon] #1667726
09/17/14 04:19 PM
09/17/14 04:19 PM
dogdays Offline
dogdays  Offline
It's not a race car, no need for a 950 carb on a 408. The 750 will be plenty big and much more streetable. After all, driving a fun car is supposed to be fun and not a chore.
R.
Re: Intake manifold and carb [Re: rocksmopar] #1667727
09/17/14 09:56 PM
09/17/14 09:56 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
There are a lot of posts on here about this subject. As you can see from the respondents on the thread below, the Edelbrocks have more bad reviews than good. That is typical.
For the same money, you can get a carb that has overall good reviews. The Street Demon. With all the negative reviews people here and on other forums give the Edelbrocks, I am very surprised that guys still buy them instead of the much better designed and calibrated Demon.
All you have to do is to read the reviews.
https://board.moparts.org/ubbthreads/show...e=0#Post8271783
Re: Intake manifold and carb [Re: DaveRS23] #1667728
09/17/14 10:24 PM
09/17/14 10:24 PM
Puyallup, WA
Puyallup, WA
I agree about staying away from the Eddy 750. There's a reason they're cheap. Sure, you'll find those that make them work just fine. But there are too many horror stories (mine among them) to ignore. Stick with a Holley based 750 / 770 and you're practically assured to be just fine.
Re: Intake manifold and carb [Re: StealthWedge67] #1667729
09/18/14 10:10 AM
09/18/14 10:10 AM
Chicago
Chicago
Street Demon 750cfm and Air Gap intake will be ordered today.
My cheap build is starting to add up..
Re: Intake manifold and carb [Re: rocksmopar] #1667730
09/18/14 11:15 AM
09/18/14 11:15 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Keep us posted on the progress.
Re: Intake manifold and carb [Re: DaveRS23] #1667731
09/19/14 10:37 AM
09/19/14 10:37 AM
Chicago
Chicago
I'm going with the demon carb but my engine guy is telling me to go with the performer intake for more low end power.It's rated from idle -5500rpm. The airgap RPM is rated from 1500-6500rpm. He's been building engines forever and says this is the way to go cause I won't run it over 5500 anyway.
Any input?
Re: Intake manifold and carb [Re: rocksmopar] #1667732
09/19/14 10:51 AM
09/19/14 10:51 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Stick with the Air-Gap. That intake will work best most any street small block which means it will still be good if you port your heads, bigger cam or converter later on. You see very few for sale used around here for a reason.
Re: Intake manifold and carb [Re: rocksmopar] #1667733
09/19/14 11:08 AM
09/19/14 11:08 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
sounds good but that cam is a little too small, like some one else said just up the lift a little with 1.6 rockers.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Intake manifold and carb [Re: 80fbody] #1667734
09/19/14 11:44 AM
09/19/14 11:44 AM
Chicago
Chicago
I'm gonna agree with everyone here and buy the airgap.
Re: Intake manifold and carb [Re: rocksmopar] #1667735
09/19/14 01:03 PM
09/19/14 01:03 PM
Puyallup, WA
Puyallup, WA
The only place the performer is going to out-perform the Air-Gap is ON idle. How much fun will you be having in the car "on idle"??? Its old technology, the Air-Gap is a newer design that does a great job of landing in the middle of dual plane fuel distribution and single plane velocity. Theres literally no way you'll be dissapointed with it. Whereas the performer will leave you forever short-shifting a small block that wants to rev.
Bottom line: On anything other than a dead-stock rebuild, your machinist is wrong.
