Blacking the tail panel of a 69 Charger R/T #1667683
09/04/14 10:40 PM
09/04/14 10:40 PM
Canal Fulton, (Akron) Ohio
Q
Quicksmopars Offline OP
Q
I'm blacking the tail panel of my 69 Charger R/T and would like to know the correct way to do so. Does someone have a factory picture they could post? Also, do the "L" shaped chrome pieces (part of the 3 piece tail panel trim) that go above the taillights receive a sliver of black paint?
Re: Blacking the tail panel of a 69 Charger R/T [Re: Quicksmopars] #1667684
09/05/14 03:03 AM
09/05/14 03:03 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: Blacking the tail panel of a 69 Charger R/T [Re: DAYCLONA] #1667685
09/05/14 03:06 AM
09/05/14 03:06 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
just the inside edge gets painted black on each corner mldg and it tapers off towards the top just before the curve, the center trunk piece is left as polished, no black
Re: Blacking the tail panel of a 69 Charger R/T [Re: Quicksmopars] #1667686
09/05/14 09:55 AM
09/05/14 09:55 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Here is a 68 if it helps
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Blacking the tail panel of a 69 Charger R/T [Re: Quicksmopars] #1667687
09/05/14 02:51 PM
09/05/14 02:51 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
It's organosol
And I do believe the L shaped mldgs as well as the mldg across the top also get a sliver of black paint.
FYI, this car I did NOT paint the mldgs in fear of having to deal with paint peeling back off of chrome in a year to make it look like crap. so I left them as plated
Re: Blacking the tail panel of a 69 Charger R/T [Re: gtx6970] #1667688
09/05/14 08:11 PM
09/05/14 08:11 PM
western australia
1cuda Offline
1cuda  Offline
western australia
i need to take a closer look at my 69 r/t about the blackout on the moldings. it`s a st louis build and remember that st louis cars didn`t get organisol-they had low gloss satin black. mine is a tx9 black car so i need to...
thanx for the info.
all the best
frank.
Re: Blacking the tail panel of a 69 Charger R/T [Re: 1cuda] #1667689
09/05/14 08:41 PM
09/05/14 08:41 PM
Q
Q
This was exactly the info I was looking for, thanks fellas.
I'm on the fence on whether to paint the "L" pieces. I know paint doesn't stick to chrome very well. If I do paint the "L" pieces, what color is the screw that mounts them? Plated or black?
Re: Blacking the tail panel of a 69 Charger R/T [Re: Quicksmopars] #1667690
09/06/14 01:46 AM
09/06/14 01:46 AM
If you scuff up the chrome lightly, the paint will stick. Either that or use Bulldog adhesion promoter.
Re: Blacking the tail panel of a 69 Charger R/T [Re: 1cuda] #1667691
09/08/14 10:22 AM
09/08/14 10:22 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
thanx for the info.
all the best
frank.
Interesting Frank. What documentation do you have to prove this? Thanks
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: Blacking the tail panel of a 69 Charger R/T [Re: MOPARMIKE69] #1667692
09/08/14 11:26 AM
09/08/14 11:26 AM
western australia
1cuda Offline
1cuda  Offline
western australia
take a look at the factory drawing posted by dayclona and in the red box it clearly says st louis cars to have sx9 low gloss enamel not organosol -it is also eliminated on dark colors BUT a few original paint cars have surfaced with blackouts which should not have been there.
mine is a very unmolested car and i need to take a closer look at it because i didn`t know that the moldings had black on them-i`m still in e body mode but one day...
all the best
frank.
Re: Blacking the tail panel of a 69 Charger R/T [Re: 1cuda] #1667693
09/08/14 01:05 PM
09/08/14 01:05 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Thanks, good to know.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: Blacking the tail panel of a 69 Charger R/T [Re: MOPARMIKE69] #1667694
09/08/14 01:20 PM
09/08/14 01:20 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
If you are wanting to do it yourself and don't have a lot of painting tools, try the Totally Auto Orgasinol. I used it on my '69 Daytona last month and it came out fairly well if I do say so. I just took off the molding, the "Charger" script, taillamps and key lock cylinder. Then I scuffed it, applied a good metal primer that laid down well and finally applied the paint using continuous spray patterns from one end to the next. Oh, make sure you mask off things..
masked up
Re: Blacking the tail panel of a 69 Charger R/T [Re: hemi68charger] #1667695
09/08/14 01:23 PM
09/08/14 01:23 PM
Houston, Tx
Houston, Tx
done... for the price of the can of Orgasinol...
Troy
Houston Mopar Connection Club
Re: Blacking the tail panel of a 69 Charger R/T [Re: hemi68charger] #1667696
09/23/14 10:29 PM
09/23/14 10:29 PM
Alabama
gold1950 Offline
gold1950  Offline
Alabama
Interesting....
Where did you buy the Organisol in a rattle can ?
Thanks for the info.
