Recommendations for hydraulic release bearing #1667510
09/04/14 08:49 AM
09/04/14 08:49 AM
Hertford, England
Dartbloke Offline OP
Hertford, England
Planning on coverting my Valiant to a hydralic clutch bearing system. Tilton seem to have a selection that might work, what did you use? What master cylinder did you use and how did you set it up with the stock A body pedal box? Photo's would be good!I'm assuming hydraulic will release as fast as the mechanical set up?
TIA!
Re: Recommendations for hydraulic release bearing [Re: Dartbloke] #1667511
09/04/14 08:54 AM
09/04/14 08:54 AM
maryland
74yellowduster Offline
maryland
Re: Recommendations for hydraulic release bearing [Re: 74yellowduster] #1667512
09/04/14 09:05 AM
09/04/14 09:05 AM
Hertford, England
Hertford, England
Aha, I've not seen that before. Didn't really want to use a slave, I'd rather ditch the entire linkage including the throwout arm.
