Planning on coverting my Valiant to a hydralic clutch bearing system. Tilton seem to have a selection that might work, what did you use? What master cylinder did you use and how did you set it up with the stock A body pedal box? Photo's would be good!I'm assuming hydraulic will release as fast as the mechanical set up?
TIA!
