Dominator 1050 Holley, to rich at idle...... #1667047
09/03/14 12:52 AM
09/03/14 12:52 AM
Lebanon ,PA in the Susquehanna...
70Challengerse Offline OP
360 stroked 408 runs high 9's low 10's, I know I am asking alot but slowing it down alittle for street , wanna drive it... but its rich as hell on idle .. eye watering rich...I want to lean it out,just on idle if poss. eng is set to run, timing is at 32 full adv. 13.5 compression , full roller set up..w-5 heads... been playing with the idle bleeds, no luck , any suggestions.....
sorry for the double post, should of put it here first....
Re: Dominator 1050 Holley, to rich at idle...... [Re: 70Challengerse] #1667048
09/03/14 12:57 AM
09/03/14 12:57 AM
Stow,Ohio
RBSat66 Offline
RBSat66  Offline
Stow,Ohio
I had the same problem with my 440, and drilled 1/8 inch holes in the throttle plates and it cleaned up the idle nicely. If you don't want to drill you plates, you came buy plates predrilled. just be careful you don't drill to big a hole. start small and adjust from there.
Re: Dominator 1050 Holley, to rich at idle...... [Re: 70Challengerse] #1667049
09/03/14 01:13 AM
09/03/14 01:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Can you turn the mixture screws in and get the engine
to stall(one at a time)
Re: Dominator 1050 Holley, to rich at idle...... [Re: 70Challengerse] #1667050
09/03/14 01:46 AM
09/03/14 01:46 AM
Cab_Burge Online work
Cab_Burge  Online Work
You will probally need to reduce the idle and part throttle fuel feed passages What list number is it ,if it is a stock type Holley 1050 Dominator carb? I've had to learn how to do that on my old pump gas street Duster with many different list # dominators on it, them rascals be race carbs, not street carbs I ended up buying #6 brass set screws and then drilling and tapping those passages in the main carb. body and then reducing the I.D. on those pasages by around 50% by drillng the set screws. Take your time and make sure what each passage is Good luck, that motor with race gas may be a little harder to get right on the first try, don't give up
Re: Dominator 1050 Holley, to rich at idle...... [Re: Cab_Burge] #1667051
09/03/14 05:10 AM
09/03/14 05:10 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
you running a power valve in the primary side? if so then what size is it and what is your vacuume hot idleing in gear. those dommys can be tricky but with a little work you can get it to idle clean all day long.
Re: Dominator 1050 Holley, to rich at idle...... [Re: dartman366] #1667052
09/03/14 10:41 AM
09/03/14 10:41 AM
P-body -yes they stall the engine one at a time
Dartman- no power valve
idle bleed is aprox .047
Cab ..pm me your # again (the amish love their pulley set up)lol.
Re: Dominator 1050 Holley, to rich at idle...... [Re: 70Challengerse] #1667053
09/03/14 10:44 AM
09/03/14 10:44 AM
another note... I,m only a basic guy when it comes to carbs, so you have to talk down to me...lol
Re: Dominator 1050 Holley, to rich at idle...... [Re: 70Challengerse] #1667054
09/03/14 10:54 AM
09/03/14 10:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The reason I asked that question was to see if your
even on the idle circuit.. how far out are the mixture
screws.. I usually can set them at 1/8 to a 1/4 turn
out from the point where they start to stall the
engine(the RPM drop point)
Re: Dominator 1050 Holley, to rich at idle...... [Re: MR_P_BODY] #1667055
09/03/14 11:50 AM
09/03/14 11:50 AM
I did try putting a larger idle bleed in.. made it worse..even after adjusting it.
Re: Dominator 1050 Holley, to rich at idle...... [Re: 70Challengerse] #1667056
09/03/14 01:19 PM
09/03/14 01:19 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Lean can burn your eyes as well................I ASSume you don`t have a wideband but how do the plugs look?
Re: Dominator 1050 Holley, to rich at idle...... [Re: Thumperdart] #1667057
09/03/14 01:49 PM
09/03/14 01:49 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
one way to tell is with your idle air screws, if you need to turn them out to gain a better idle then the bleed is too large making it lean and by screwing the idle air screws out will richen the circut, just the opposite if they are too small.
Re: Dominator 1050 Holley, to rich at idle...... [Re: Thumperdart] #1667058
09/03/14 01:56 PM
09/03/14 01:56 PM
No wide band, actually is puffing smoke...bluish in color, not oil ....rich fuel plugs are slighty coated black..
Re: Dominator 1050 Holley, to rich at idle...... [Re: 70Challengerse] #1667059
09/03/14 02:22 PM
09/03/14 02:22 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Years ago, when I ran a carb on my 1050, I had the same experience. To solve it, I had to drill and fit the idle feeds to restrict them.
Re: Dominator 1050 Holley, to rich at idle...... [Re: 70Challengerse] #1667060
09/03/14 02:40 PM
09/03/14 02:40 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
what is the largest bleed you have gone to, mine has #55 bleeds in the idle circuit, mine idles clean and the idle screws are out a little over 1.5 turns,, next question is.. does it take forever to warm up? when mine was origionally put on it seemed like hours to get to 170* which meant it was pig rich at idle.
Re: Dominator 1050 Holley, to rich at idle...... [Re: dartman366] #1667061
09/03/14 02:52 PM
09/03/14 02:52 PM
Went as far as .065 still rich, warms right up. Warmer the engine richer the engine, 1.5 turns out.. run like a raped ape just rich idle, what does the intermediate bleed do.
Re: Dominator 1050 Holley, to rich at idle...... [Re: 70Challengerse] #1667062
09/03/14 03:05 PM
09/03/14 03:05 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I run a 8082 2 circuit so I cannot tell you what effect those will have, you may have to do like theotherdodge said and restrict the ifr's, you may try and get ahold of AJ Casini here on the board as he did my dommy, I have also done some reading on the Horsepower Innovations web site, they seem to explain it pretty well,,just google it or google E-85 carb tuning.
Re: Dominator 1050 Holley, to rich at idle...... [Re: 70Challengerse] #1667063
09/03/14 03:37 PM
09/03/14 03:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Blue is generally oil not fuel and it`s possible you compromised ring seal by running a 3-circut w/out a p/v..............
Re: Dominator 1050 Holley, to rich at idle...... [Re: 70Challengerse] #1667064
09/03/14 03:44 PM
09/03/14 03:44 PM
AndyF Offline
AndyF  Offline
If you're going to street drive it then you should put a power valve in it and reduce the jet size. That will help clean things up a bit.
I don't understand the idle issue though. If you can stall the engine by screwing the idle mixture jets in then you have enough adjustability.
Where is the throttle blade set in relationship to the transfer slot? There should only be a small portion of the transfer slot showing under the throttle blade. Start with that and go from there.
You should not need to change the air bleeds at all.
Re: Dominator 1050 Holley, to rich at idle...... [Re: 70Challengerse] #1667065
09/03/14 03:49 PM
09/03/14 03:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Three things; convert to a two circuit, install a primary p/v and get a wideband.............
Re: Dominator 1050 Holley, to rich at idle...... [Re: Thumperdart] #1667066
09/03/14 04:08 PM
09/03/14 04:08 PM
Blue is generally oil not fuel..............
I know this, but it is fuel not oil, I don' understand it either.
