Dominator 1050 Holley, to rich at idle......
#1667047
09/03/14 12:52 AM
09/03/14 12:52 AM
Posts: 7,512 Lebanon ,PA in the Susquehanna...
70Challengerse
360 stroked 408 runs high 9's low 10's, I know I am asking alot but slowing it down alittle for street , wanna drive it... but its rich as hell on idle .. eye watering rich...I want to lean it out,just on idle if poss. eng is set to run, timing is at 32 full adv. 13.5 compression , full roller set up..w-5 heads... been playing with the idle bleeds, no luck , any suggestions..... sorry for the double post, should of put it here first.... ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: Dominator 1050 Holley, to rich at idle......
[Re: 70Challengerse]
#1667054
09/03/14 10:54 AM
09/03/14 10:54 AM
Posts: 52,972 Romeo MI
MR_P_BODY
P-body -yes they stall the engine one at a time Dartman- no power valve idle bleed is aprox .047 Cab ..pm me your # again (the amish love their pulley set up)lol.
The reason I asked that question was to see if your even on the idle circuit.. how far out are the mixture screws.. I usually can set them at 1/8 to a 1/4 turn out from the point where they start to stall the engine(the RPM drop point) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Thumperdart]
#1667057
09/03/14 01:49 PM
09/03/14 01:49 PM
dartman366
Mt. Vernon, Ohio
I did try putting a larger idle bleed in.. made it worse..even after adjusting it.
Lean can burn your eyes as well................I ASSume you don`t have a wideband but how do the plugs look?
one way to tell is with your idle air screws, if you need to turn them out to gain a better idle then the bleed is too large making it lean and by screwing the idle air screws out will richen the circut, just the opposite if they are too small. ![](/ubbthreads/images/graemlins/biggrin.gif)
#1667060
09/03/14 02:40 PM
09/03/14 02:40 PM
dartman366
Mt. Vernon, Ohio
what is the largest bleed you have gone to, mine has #55 bleeds in the idle circuit, mine idles clean and the idle screws are out a little over 1.5 turns,, next question is.. does it take forever to warm up? when mine was origionally put on it seemed like hours to get to 170* which meant it was pig rich at idle. ![](/ubbthreads/images/graemlins/shock.gif)
#1667062
09/03/14 03:05 PM
09/03/14 03:05 PM
dartman366
Mt. Vernon, Ohio
Went as far as .065 still rich, warms right up. Warmer the engine richer the engine, 1.5 turns out.. run like a raped ape just rich idle, what does the intermediate bleed do.
I run a 8082 2 circuit so I cannot tell you what effect those will have, you may have to do like theotherdodge said and restrict the ifr's, you may try and get ahold of AJ Casini here on the board as he did my dommy, I have also done some reading on the Horsepower Innovations web site, they seem to explain it pretty well,,just google it or google E-85 carb tuning. ![](/ubbthreads/images/graemlins/thumbs.gif)
