MSD...Crank Trigger.. Part Number.?? 8636..???? #1666449
09/02/14 05:27 AM
09/02/14 05:27 AM
Arizona
Chris'sBarracuda Offline OP
Arizona
Switching to Crank Trigger and not sure what I should use.. Big Block--B1
I have a Fisher Balancer, but it has a Chevy bolt pattern..
Also use the DMI bracket from Doty.. Same as BigCubes..
I have the pick up, but it's a Crane.. Don't know if it will work with MSD..
Does the DMI bracket replace the MSD bracket..
Chris..
Re: MSD...Crank Trigger.. Part Number.?? 8636..???? [Re: Chris'sBarracuda] #1666450
09/02/14 08:01 AM
09/02/14 08:01 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Yes, the DMI bracket will replace the MSD one. There are 2 pick-ups available though MSD, one is 3/4" and the other is 3/8". The smaller one will fit better is you run an alternator. They are different size brackets obviously. You will need a kit for a big block chevy to match your balancer bolt pattern.
Re: MSD...Crank Trigger.. Part Number.?? 8636..???? [Re: Chris'sBarracuda] #1666451
09/02/14 01:10 PM
09/02/14 01:10 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You can use the BBC crank trigger and save some $$$..Oh yeah I know where one is collecting dust. Send me a text
Re: MSD...Crank Trigger.. Part Number.?? 8636..???? [Re: Al_Alguire] #1666452
09/02/14 03:33 PM
09/02/14 03:33 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If you already have a bracket and a balancer with a Chevy front.........you don't need a "kit". Chevy pattern wheels should be a dime a dozen and just order a sensor. Also the Crane sensor you have MAY work. Just depends on whether that sensor is magnetic or is for a "flying magnet" wheel. Some older crank triggers had alum wheels, with steel pickups and the sensor itself was magnetic. They were much more troublesome and the reason everyone has gone to flying magnet now.
Monte
Re: MSD...Crank Trigger.. Part Number.?? 8636..???? [Re: Monte_Smith] #1666453
09/03/14 03:53 AM
09/03/14 03:53 AM
Arizona
Arizona
Thanks guys...
I've got it figured out with some help..
Al to the rescue..
Chris..
Re: MSD...Crank Trigger.. Part Number.?? 8636..???? [Re: Chris'sBarracuda] #1666454
09/03/14 07:59 PM
09/03/14 07:59 PM
Arizona
Arizona
Monte..
The Crane pickup uses the flying magnet style per Crane tech.
Now.. Do I just use the same distributor, but no internals except cap and rotor..??
Chris..
Re: MSD...Crank Trigger.. Part Number.?? 8636..???? [Re: Chris'sBarracuda] #1666455
09/03/14 08:16 PM
09/03/14 08:16 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Monte..
Chris..
yup
Re: MSD...Crank Trigger.. Part Number.?? 8636..???? [Re: Mopar-Al] #1666456
09/03/14 08:19 PM
09/03/14 08:19 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I phase the distributor rotor ,for zero of course, then set the magnet on mine around 36 to start.; Yourt distributor is locked, right Chris?
Re: MSD...Crank Trigger.. Part Number.?? 8636..???? [Re: Chris'sBarracuda] #1666457
09/03/14 08:45 PM
09/03/14 08:45 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Monte..
Chris..
i always leave the distributor trigger intact and use matching connectors on the crank trigger pickup and the distributor pickup. that way if the CT sensor should fail (if it does it will be at the worst time) you can just swap from the CT to the distributor in seconds.
Re: MSD...Crank Trigger.. Part Number.?? 8636..???? [Re: Mopar-Al] #1666458
09/04/14 05:37 AM
09/04/14 05:37 AM
Arizona
Arizona
I phase the distributor rotor ,for zero of course, then set the magnet on mine around 36 to start.; Your distributor is locked, right Chris?
Yes, locked out..
And I still adjust timing through the distributor movement.??
Chris..
Re: MSD...Crank Trigger.. Part Number.?? 8636..???? [Re: jamesc] #1666459
09/04/14 05:41 AM
09/04/14 05:41 AM
Arizona
Arizona
Okay, now I'm really confused..
How would you time the motor through two different pick up points.??
Chris..
Re: MSD...Crank Trigger.. Part Number.?? 8636..???? [Re: Chris'sBarracuda] #1666460
09/04/14 07:13 AM
09/04/14 07:13 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Yes, locked out..
Chris..
A lesson I learned last week.
Timing can only be changed by where the signal is picked up.....you have to move the magnetic pick up around the crank trigger wheel.
The distributor is only , no pun intended , distributing the spark.
But the signal , as far as when to fire , happens at the crank trigger.
If you kept the guts in the distributor as a back up , after you switched away from the crank trigger , then timing would be set in the " normal " way.
Re: MSD...Crank Trigger.. Part Number.?? 8636..???? [Re: tubtar] #1666461
09/04/14 12:03 PM
09/04/14 12:03 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Chris..........since you run your car N/A and I am assuming the timing somewhere around 32 degrees, to phase the rotor simply roll the motor by hand until the timing pointer is resting at 32 degrees. Now pop the cap off the dist, turn the body until the rotor tip is pointing at number 1 terminal. That's it, lock it down. Rotor phased and ready to go. All timing adjustments will be made on the crank and you won't have to move the dist again.
Monte
Re: MSD...Crank Trigger.. Part Number.?? 8636..???? [Re: Chris'sBarracuda] #1666462
09/04/14 12:28 PM
09/04/14 12:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Chris..
Chris.. what he is saying is the CT and the dist
plug is the same type of hook up.. if you run the
CT you would have the wires hooked up to the CT..
BUT if the CT sensor failed you could just unplug
the CT sensor wires and plug them onto the dist and
be back up and running... if you are using the CT
there isnt anything plugged into the dist except the
plug wires and the coil wire
Re: MSD...Crank Trigger.. Part Number.?? 8636..???? [Re: Monte_Smith] #1666463
09/04/14 06:19 PM
09/04/14 06:19 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Monte
That is how I do it also....doing it now on my 572 B1
Re: MSD...Crank Trigger.. Part Number.?? 8636..???? [Re: Mopar-Al] #1666464
09/05/14 05:41 AM
09/05/14 05:41 AM
Arizona
Arizona
Monte
Well, since I have a Crane DEC9500 engine controller, can I set the timing @ 38* and then retard it to what I need through the controller..
Chris..
Re: MSD...Crank Trigger.. Part Number.?? 8636..???? [Re: Chris'sBarracuda] #1666465
09/05/14 08:06 AM
09/05/14 08:06 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
That's how I did it with the MSD 6 AL programmable.
Pull out 23 degrees to start and even threw a curve at it so it is all in by 2200.
I set the crank to 34 degrees before , checked it and only missed by two degrees.
Not bad for a guy who tunes with a stone hammer.
Re: MSD...Crank Trigger.. Part Number.?? 8636..???? [Re: Chris'sBarracuda] #1666466
09/05/14 11:59 PM
09/05/14 11:59 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Monte
Chris..
No idea............not familiar with any Crane ignition products or what they can do
Monte
