MSD...Crank Trigger.. Part Number.?? 8636..????
#1666449
09/02/14 05:27 AM
09/02/14 05:27 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Switching to Crank Trigger and not sure what I should use.. Big Block--B1 I have a Fisher Balancer, but it has a Chevy bolt pattern.. Also use the DMI bracket from Doty.. Same as BigCubes.. I have the pick up, but it's a Crane.. Don't know if it will work with MSD.. Does the DMI bracket replace the MSD bracket.. Chris..
Re: MSD...Crank Trigger.. Part Number.?? 8636..????
[Re: Chris'sBarracuda]
#1666450
09/02/14 08:01 AM
09/02/14 08:01 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Yes, the DMI bracket will replace the MSD one. There are 2 pick-ups available though MSD, one is 3/4" and the other is 3/8". The smaller one will fit better is you run an alternator. They are different size brackets obviously. You will need a kit for a big block chevy to match your balancer bolt pattern.
[Re: Monte_Smith]
#1666453
09/03/14 03:53 AM
09/03/14 03:53 AM
Chris'sBarracuda
Arizona
Thanks guys... I've got it figured out with some help.. Al to the rescue.. Chris..
#1666454
09/03/14 07:59 PM
09/03/14 07:59 PM
Chris'sBarracuda
Arizona
Monte.. The Crane pickup uses the flying magnet style per Crane tech. Now.. Do I just use the same distributor, but no internals except cap and rotor..?? Chris..
#1666455
09/03/14 08:16 PM
09/03/14 08:16 PM
Posts: 6,780 Alabama
Mopar-Al
Alabama
Monte..
Chris..
yup
#1666457
09/03/14 08:45 PM
09/03/14 08:45 PM
Posts: 5,875 communist bloc of new jersey
jamesc
Monte..
Chris..
i always leave the distributor trigger intact and use matching connectors on the crank trigger pickup and the distributor pickup. that way if the CT sensor should fail (if it does it will be at the worst time) you can just swap from the CT to the distributor in seconds.
[Re: Mopar-Al]
#1666458
09/04/14 05:37 AM
09/04/14 05:37 AM
Chris'sBarracuda
Arizona
I phase the distributor rotor ,for zero of course, then set the magnet on mine around 36 to start.; Your distributor is locked, right Chris?
Yes, locked out..
And I still adjust timing through the distributor movement.??
Chris..
[Re: jamesc]
#1666459
09/04/14 05:41 AM
09/04/14 05:41 AM
Chris'sBarracuda
Arizona
Okay, now I'm really confused..
How would you time the motor through two different pick up points.??
Chris..
#1666460
09/04/14 07:13 AM
09/04/14 07:13 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Yes, locked out..
Chris..
A lesson I learned last week. Timing can only be changed by where the signal is picked up.....you have to move the magnetic pick up around the crank trigger wheel. The distributor is only , no pun intended , distributing the spark. But the signal , as far as when to fire , happens at the crank trigger. If you kept the guts in the distributor as a back up , after you switched away from the crank trigger , then timing would be set in the " normal " way.
#1666462
09/04/14 12:28 PM
09/04/14 12:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Chris..
Chris.. what he is saying is the CT and the dist plug is the same type of hook up.. if you run the CT you would have the wires hooked up to the CT.. BUT if the CT sensor failed you could just unplug the CT sensor wires and plug them onto the dist and be back up and running... if you are using the CT there isnt anything plugged into the dist except the plug wires and the coil wire
[Re: Monte_Smith]
#1666463
09/04/14 06:19 PM
09/04/14 06:19 PM
Mopar-Al
Alabama
Chris..........since you run your car N/A and I am assuming the timing somewhere around 32 degrees, to phase the rotor simply roll the motor by hand until the timing pointer is resting at 32 degrees. Now pop the cap off the dist, turn the body until the rotor tip is pointing at number 1 terminal. That's it, lock it down. Rotor phased and ready to go. All timing adjustments will be made on the crank and you won't have to move the dist again.
Monte
That is how I do it also....doing it now on my 572 B1
[Re: Mopar-Al]
#1666464
09/05/14 05:41 AM
09/05/14 05:41 AM
Chris'sBarracuda
Arizona
Monte
Well, since I have a Crane DEC9500 engine controller, can I set the timing @ 38* and then retard it to what I need through the controller..
Chris..
#1666465
09/05/14 08:06 AM
09/05/14 08:06 AM
tubtar
St. Paul , Mn.
That's how I did it with the MSD 6 AL programmable. Pull out 23 degrees to start and even threw a curve at it so it is all in by 2200. I set the crank to 34 degrees before , checked it and only missed by two degrees. Not bad for a guy who tunes with a stone hammer.
#1666466
09/05/14 11:59 PM
09/05/14 11:59 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Monte
Chris..
No idea............not familiar with any Crane ignition products or what they can do
Monte
