Where can I get a Disc Brake Booster for 69 Coronet R/T #1665574
08/30/14 07:35 PM
08/30/14 07:35 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I've struck out with the local stores and would rather not do Rock Auto if I can help it. I'm tired of them losing my cores I send back. Any other other options anyone knows of? Cardone is the supplier and they are shown as out of stock.
Thanks.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: Where can I get a Disc Brake Booster for 69 Coronet R/T [Re: TimS] #1665575
08/30/14 08:01 PM
08/30/14 08:01 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Thanks.
try Classicindustries.com
I was just looking at them but for a Road Runner....
Re: Where can I get a Disc Brake Booster for 69 Coronet R/T [Re: TimS] #1665576
08/30/14 09:10 PM
08/30/14 09:10 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Booster Dewey?
Re: Where can I get a Disc Brake Booster for 69 Coronet R/T [Re: OzHemi] #1665577
08/30/14 09:29 PM
08/30/14 09:29 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
http://sacramento.craigslist.org/pts/4644517333.html
If your interested, i have these to be used for cores.
But finding a OEM,rebuilt Bendix power brake booster is not an easy task, in this day and age, as you seem to be finding out.
Vendors list them, but in actuality, when you try and buy one, they aren't available.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Where can I get a Disc Brake Booster for 69 Coronet R/T [Re: hemi71x] #1665578
08/30/14 11:07 PM
08/30/14 11:07 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I see I can get the unit for front drums. Would that work with the disc as well that I have?
Re: Where can I get a Disc Brake Booster for 69 Coronet R/T [Re: TimS] #1665579
08/30/14 11:10 PM
08/30/14 11:10 PM
Andrewh Offline
Andrewh  Offline
disc and drum units are different.
they physically bolt up the same, but the amount of assist is different.
you will find you cannot lock up the brakes using a drum booster vs disc.
you can order a newer unit so you can drive while you send your out to be rebuilt. a 74 and up I think. it will be bigger but flatter. if you have cruise or column shift(which I doubt in an rt) it will interfer with stuff, but should still work.
Re: Where can I get a Disc Brake Booster for 69 Coronet R/T [Re: Andrewh] #1665580
08/30/14 11:15 PM
08/30/14 11:15 PM
hemi71x Offline
hemi71x  Offline
If you already have a Bendix booster, just send it out to Booster Dewey, and have him rebuild it.
Re: Where can I get a Disc Brake Booster for 69 Coronet R/T [Re: Andrewh] #1665581
08/31/14 01:34 AM
08/31/14 01:34 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Thanks for the info. I was thinking of trying that but compared the specs and decided against it because of what you already knew. I notice Mancini racing has them but they are not cheap. Around $270. The local O Reilly's is going to take a stab at ordering part # 54-73603 from Cardone.
Re: Where can I get a Disc Brake Booster for 69 Coronet R/T [Re: TimS] #1665582
08/31/14 01:39 AM
08/31/14 01:39 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
What is the difference between '69 B-body (non-HEMI) & '69 C-body both dual diaphragm Bendix booster w/PDB?
Re: Where can I get a Disc Brake Booster for 69 Coronet R/T [Re: 6bblgt] #1665583
08/31/14 01:48 AM
08/31/14 01:48 AM
hemi71x Offline
hemi71x  Offline
The "rod" that comes out the back of the booster, that connects to the brake pedal, and or, brake pedal linkage.
Re: Where can I get a Disc Brake Booster for 69 Coronet R/T [Re: hemi71x] #1665584
08/31/14 02:12 AM
08/31/14 02:12 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
If money isn't an issue, look at "The Ram Man". He seems to have some great stuff. Pirate Jack also has some great Mopar specific equipment.
Re: Where can I get a Disc Brake Booster for 69 Coronet R/T [Re: TimS] #1665585
08/31/14 10:04 AM
08/31/14 10:04 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
NAPA single diaphragm NBB 5473501 With master cylinder NBB 503501
NAPA dual diaphragm NBB 5473606 With master cylinder NBB503603
My experience is NAPA will often have the parts that no one else has. And as a former NAPA supplier I can tell you they are particular about what they buy. Unlike some retailers NAPA's first priority is quality, second is price.
Re: Where can I get a Disc Brake Booster for 69 Coronet R/T [Re: hemi71x] #1665586
08/31/14 12:11 PM
08/31/14 12:11 PM
Andrewh Offline
Andrewh  Offline
not postive, but I also think the bolt pattern is wrong. for some reason I remember trying to use a dual diaphram c body one I have laying around on a b body and it wouldn't line up.
Re: Where can I get a Disc Brake Booster for 69 Coronet R/T [Re: Andrewh] #1665587
08/31/14 12:27 PM
08/31/14 12:27 PM
hemi71x Offline
hemi71x  Offline
B & C Body bolt pattern spacing are all the same.
The HEMI booster bolt pattern spacing is different than the standard, regular, Bendix boosters.
Re: Where can I get a Disc Brake Booster for 69 Coronet R/T [Re: hemi71x] #1665588
08/31/14 12:34 PM
08/31/14 12:34 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Got pics of the difference?
Re: Where can I get a Disc Brake Booster for 69 Coronet R/T [Re: 6bblgt] #1665589
08/31/14 01:28 PM
08/31/14 01:28 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I put a C body 'drum' brake booster on my 69 GTX and the rod on the back was to long
otherwise it bolted right up and looked the same in all other aspects.
So I would assume disc brake booster would fit the same
Re: Where can I get a Disc Brake Booster for 69 Coronet R/T [Re: gtx6970] #1665590
08/31/14 01:29 PM
08/31/14 01:29 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ps,
I have a bendix disc brake booster that I am 99% sure is a B body I can measure the rod it that helps
(and no it's not for sale, it's for a customers car I am working on )
Re: Where can I get a Disc Brake Booster for 69 Coronet R/T [Re: 6bblgt] #1665591
08/31/14 02:26 PM
08/31/14 02:26 PM
hemi71x Offline
hemi71x  Offline
Look at the pitures in my Craigslist ad.
My boosters are C body, and Imperial.
I Don't have any official B body ones.
You can see differences in the rods between the body styes, and the B body one is quite short, along with a "Hemi" booster also.
Re: Where can I get a Disc Brake Booster for 69 Coronet R/T [Re: TooMany62s] #1665592
08/31/14 06:14 PM
08/31/14 06:14 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Thanks for the info. I'll give Napa a try. Cardone has basically said it is no longer available. So as stated before I may indeed have to have this one rebuilt. The guy I bought this car from broke the LH lower front stud off removing the old master cylinder. My understanding is the problem wasn't there before the change. Could that cause my leakage problem? You can hear it leaking from inside the car when applying the brakes.
Anyone ever use Booster Dewey? Going to give him a call tomorrow if I strike out with Napa.
Re: Where can I get a Disc Brake Booster for 69 Coronet R/T [Re: TimS] #1665593
09/01/14 08:45 AM
09/01/14 08:45 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
It appears that Booster Dewey and Mancini Racing are my options if Napa can't get one.
