Re: b1 t&d question
[Re: moparx]
#1665292
08/30/14 09:55 AM
08/30/14 09:55 AM
Posts: 52,972 Romeo MI
MR_P_BODY
when something like that is clearanced, i don't like the multiple stepps left, nor the very sharp radius left on the bottom of the step. these imperfections if you will, cause stress rizers, and will ultimately lead to results you will not be happy with. i would much rather see a ballnose endmill used and the retainer side of the clearance gently smoothed outward. the problem is finding a ballnose endmill of the right size. or a standard endmill with a custom [generous] radius grind. just my opinion.
When I was clearing that area I had to get a mill bit made up.. mine is 1.57 dia with a radius on the bottom... its not a cheap tool bit
Re: b1 t&d question
[Re: psycomopar]
#1665294
08/30/14 11:24 AM
08/30/14 11:24 AM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
If I end up not using these and ordering new that's what I am going to get.
I ran those rockers on my B1 and they were clearanced just like our are. They worked fine and I never broke one. That said, I would not run a spring with more pressure than 800 open pressure, and if you don't have a cam that operates in the 8000 rpm zone, you shouldn't need anymore spring than that. I would look at Manley's part number 221425. JMO
Re: b1 t&d question
[Re: psycomopar]
#1665296
09/01/14 12:11 AM
09/01/14 12:11 AM
camastomcat
Salt Lake City
I'm pretty sure I have some where around #800. Can is a touch over 800 lift 330ish duration. But it is 605 so it's made most hp at 6600. So dosent rev real high.
If it peaks HP at 6600, I wouldn't turn it over 7200. I would run those rockers if that's what I had, and did.
