is there a source for correct leaf spring pn#s?
#1663232
08/24/14 07:53 PM
08/24/14 07:53 PM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
specifically on a 1971 E body?
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
Re: is there a source for correct leaf spring pn#s?
[Re: DaveDudek]
#1663235
08/25/14 12:01 PM
08/25/14 12:01 PM
Posts: 4,799 ILL
MLR426
ILL
No just originals. Tony posted numbers
MLR426
[Re: Snoopy]
#1663236
08/25/14 03:52 PM
08/25/14 03:52 PM
DaveDudek
N of Detroit
Thanks,
Although I need the numbers on the springs themselves. I'm looking for the numbers on a set of springs that may have came on a 318 powered car.
In FAST the 440/Hemi springs are useless. If you want the car to hook up you need the junk 6cyl/318 weak springs.
Thanks for posting.. Anybody have the numbers for the standard leaf springs?
[Re: DaveDudek]
#1663237
08/25/14 04:47 PM
08/25/14 04:47 PM
DaveDudek
N of Detroit
Actually I need to know what this number is for? 3400014 Picked them up but the guy didn't know what they came off of?
[Re: DaveDudek]
#1663238
08/25/14 04:50 PM
08/25/14 04:50 PM
DaveDudek
N of Detroit
If anyone is interested
3400014 - L&R '70 e-body 318/383 2bbl 3400015 - L&R '70 e-body convertible 318/383 2bbl 3400045 - L&R '71 e-body convertible 340/383 3643594 - L&R '72-'74 e-body 318/340 w/rallye suspension 2539534 2539794 - LH 6-leaf '68-'70 b-body w/440&HEMI (some not all) and '71 b-body w/DANA (or some w/G60-15s not all) 2539964 - RH 7-leaf '68-'70 b-body w/440&HEMI (some not all) and '71 b-body w/DANA (or some w/G60-15s not all)
[Re: cudaized]
#1663241
08/25/14 11:13 PM
08/25/14 11:13 PM
DaveDudek
N of Detroit
[Re: DaveDudek]
#1814652
04/29/15 04:47 PM
04/29/15 04:47 PM
Posts: 477 mr norms avenue
5571
mr norms avenue
I have been looking at this list and have to wonder if the convertibles have a slightly stiffer spring rate more so than a coupe. The wheel housing is actually more shallow at the top due to the convertible top clearance needed. So logically you would think the spring rate would try to counter the wheel from getting even close to bottoming out up at the top of the wheel house. Plus, I would think a convertible is slightly heavier that a coupe?
I had to get my opinion out there. What the real difference is between a convertible spring and the hardtop, I would love to know (except for the explanation Detroit spring said, its a bushing not installed in one vs the other). There is a consistent part number difference between them.
67 hemi GTX silver 4spd, 70 cuda convert 340 4spd, 71 cuda 340 4spd (Curious Yellow, white billboards/interior), 70 Mr Norm's Challenger 440 4spd
[Re: RP's R/T's]
#1815113
04/30/15 02:00 AM
04/30/15 02:00 AM
Posts: 17,519 Las Vegas, NV
6bblgt
Las Vegas, NV
I just pulled 024/034's out of an original 383-4, 4-speed car. Car came with 15x7's. any '70 340/383 B & E-body with an axle package A31 (3.91s) or A36 (3.55s) will have the STANDARD in 440/HEMI torsion bars 780/781 & rear springs 024/034.
[Re: 5571]
#1815115
04/30/15 02:02 AM
04/30/15 02:02 AM
6bblgt
Las Vegas, NV
I had to get my opinion out there. What the real difference is between a convertible spring and the hardtop, I would love to know (except for the explanation Detroit spring said, its a bushing not installed in one vs the other). There is a consistent part number difference between them. it could be something they learned in 1970 as the similarly equipped '71 340 convertibles have 3400045 springs
