is there a source for correct leaf spring pn#s? #1663232
08/24/14 07:53 PM
08/24/14 07:53 PM
N of Detroit
DaveDudek Offline OP
N of Detroit
specifically on a 1971 E body?
Dave Dudek
1st Factory Stock legal car in the 10`s!!! [/b]
FAST & Factory Stock Rules: www.fastraces.org
FAST 69 Hemi RR 9.98@139
Re: is there a source for correct leaf spring pn#s? [Re: DaveDudek] #1663233
08/25/14 01:06 AM
08/25/14 01:06 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Are you looking for the parts counter p/n or the number stamped on the springs?
These are the factory over the counter part numbers.
Re: is there a source for correct leaf spring pn#s? [Re: DaveDudek] #1663234
08/25/14 10:46 AM
08/25/14 10:46 AM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
here are the numbers that are on the springs themselves
E-BODY
LEFT SIDE, 6 LEAVES (LOWEST LEAF IS SHORT) #3400034
RIGHT SIDE, 5 FULL + 1 1/2 LEAF 3400024
68-69 B-BODY
68-69 LEFT 2539795 6 LEAVES
68-69 RIGHT 2539965 5 FULL + 2 HALF LEAVES
1970 B-BODY LEAF SPRINGS 2539794 2539964
Re: is there a source for correct leaf spring pn#s? [Re: DaveDudek] #1663235
08/25/14 12:01 PM
08/25/14 12:01 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
No just originals. Tony posted numbers
MLR426
Re: is there a source for correct leaf spring pn#s? [Re: Snoopy] #1663236
08/25/14 03:52 PM
08/25/14 03:52 PM
N of Detroit
N of Detroit
Thanks,
Although I need the numbers on the springs themselves. I'm looking for the numbers on a set of springs that may have came on a 318 powered car.
In FAST the 440/Hemi springs are useless. If you want the car to hook up you need the junk 6cyl/318 weak springs.
Thanks for posting.. Anybody have the numbers for the standard leaf springs?
Dave Dudek
Re: is there a source for correct leaf spring pn#s? [Re: DaveDudek] #1663237
08/25/14 04:47 PM
08/25/14 04:47 PM
N of Detroit
N of Detroit
Actually I need to know what this number is for? 3400014
Picked them up but the guy didn't know what they came off of?
Dave Dudek
Re: is there a source for correct leaf spring pn#s? [Re: DaveDudek] #1663238
08/25/14 04:50 PM
08/25/14 04:50 PM
N of Detroit
N of Detroit
If anyone is interested
3400014 - L&R '70 e-body 318/383 2bbl
3400015 - L&R '70 e-body convertible 318/383 2bbl
3400045 - L&R '71 e-body convertible 340/383
3643594 - L&R '72-'74 e-body 318/340 w/rallye suspension
2539534
2539794 - LH 6-leaf '68-'70 b-body w/440&HEMI (some not all) and '71 b-body w/DANA (or some w/G60-15s not all)
2539964 - RH 7-leaf '68-'70 b-body w/440&HEMI (some not all) and '71 b-body w/DANA (or some w/G60-15s not all)
Dave Dudek
Re: is there a source for correct leaf spring pn#s? [Re: DaveDudek] #1663239
08/25/14 04:54 PM
08/25/14 04:54 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the last three digits are on a b'cast sheet
1970
/6 - 013
318 - 014 = #3400014
1971
/6 - ?
318 - 344
Re: is there a source for correct leaf spring pn#s? [Re: 6bblgt] #1663240
08/25/14 10:34 PM
08/25/14 10:34 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
I did some research and this is what I have observed.
1970
6 - 013
6 conv 014
318 conv 015 = #3400015
340 - 043
340 conv 044 = #4200044
340-6 - 048
383-2 - 043
383-2 conv 044
383-4 - 043
383-4 conv 044
426 - 034(L)/024(R) = #3400034/#3400024
440-4 - 034(L)/024(R) = #3400034/#3400024
440-6 - 034(L)/024(R) = #3400034/#3400024
1971
6 - ?
6 conv 344
318 – 344
318 conv 345
340 – 044
340 conv 045 = #3400045
383-2 – 344
383-2 conv 045
383-4 – 044
383-4 conv 045 = #3400045
426 – 034(L)/024(R) = #3400034/#3400024
440-6 – 034(L)/024(R) = #3400034/#3400024
A lot of Broadcast Sheets have the wrong torsion bar and rear spring part numbers. For example: 318 cars with hemi suspension, 383-2 cars with slant 6 suspension, etc. The system operator probably forgot to change the information from previous cars(?)
Re: is there a source for correct leaf spring pn#s? [Re: cudaized] #1663241
08/25/14 11:13 PM
08/25/14 11:13 PM
N of Detroit
N of Detroit
Dave Dudek
Re: is there a source for correct leaf spring pn#s? [Re: DaveDudek] #1814652
04/29/15 04:47 PM
04/29/15 04:47 PM
mr norms avenue
5571 Offline
5571  Offline
mr norms avenue
I have been looking at this list and have to wonder if the convertibles have a slightly stiffer spring rate more so than a coupe. The wheel housing is actually more shallow at the top due to the convertible top clearance needed. So logically you would think the spring rate would try to counter the wheel from getting even close to bottoming out up at the top of the wheel house. Plus, I would think a convertible is slightly heavier that a coupe?
I had to get my opinion out there. What the real difference is between a convertible spring and the hardtop, I would love to know (except for the explanation Detroit spring said, its a bushing not installed in one vs the other). There is a consistent part number difference between them.
67 hemi GTX silver 4spd, 70 cuda convert 340 4spd, 71 cuda 340 4spd (Curious Yellow, white billboards/interior), 70 Mr Norm's Challenger 440 4spd
Re: is there a source for correct leaf spring pn#s? [Re: DaveDudek] #1814915
04/29/15 10:42 PM
04/29/15 10:42 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
I just pulled 024/034's out of an original 383-4, 4-speed car.
Car came with 15x7's.
Re: is there a source for correct leaf spring pn#s? [Re: RP's R/T's] #1815113
04/30/15 02:00 AM
04/30/15 02:00 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
any '70 340/383 B & E-body with an axle package A31 (3.91s) or A36 (3.55s) will have the STANDARD in 440/HEMI torsion bars 780/781 & rear springs 024/034.
Re: is there a source for correct leaf spring pn#s? [Re: 5571] #1815115
04/30/15 02:02 AM
04/30/15 02:02 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
it could be something they learned in 1970 as the similarly equipped '71 340 convertibles have 3400045 springs
