Not a best, but a first! #1661024
08/19/14 03:45 AM
08/19/14 03:45 AM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Long story short, the new engine has some grunt compared to the old 451. Went to the local track Saturday to put a couple of hits on it and it ran pretty good for not changing the fuel set up from the last motor. First pass went good except with worrying about everything new in the motor, I forgot to turn the air shifter on and the 1-2 shift was late. Then I pulled the 2-3 shift early. With 26* timing it ran good and went 10.16. Next pass with 30* timing in it left extremely smooth and tripped the 60 ft clock with the rear tires with 1.466. Well the ride wasn't over there. As it continued to reach for the sky it was just starting to lay over in the top of first gear it clicked second and went the rest of the way up. By this time it was starting to cruise pretty good and I hear a VERY distinct scrapping sound of the rear valance on the track. The thing had started to drift towards the guard rail and I had to attempt pedaling it down. Well it didn't come down easy, but it wasn't on the guard rail. About a foot and a half between the car and rail. New diaper and my Charlie's pan are now wall hangers. Hind sight being 20/20, I should have tightened the front shocks up all the way and took some more of the travel away up front. Back to the shop. Beep
Re: Not a best, but a first! [Re: Bigbeep] #1661025
08/19/14 03:46 AM
08/19/14 03:46 AM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
pic #2
Re: Not a best, but a first! [Re: Bigbeep] #1661026
08/19/14 12:36 PM
08/19/14 12:36 PM
Renton Washington
Triple Threat Offline
Renton Washington
Ouch! Sounds like the new engine is making some steam. Good luck getting it figured out. Hopefully someone got some video for you!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Not a best, but a first! [Re: Bigbeep] #1661027
08/19/14 01:41 PM
08/19/14 01:41 PM
If it isn't leaking a good body man, tin knocker, can probally fix that I don't know about the diaper I'm glad you save the rest of the car, take the time to look very closely at all of the front suspenion parts to see if any are damaged or not
Re: Not a best, but a first! [Re: Cab_Burge] #1661028
08/19/14 02:20 PM
08/19/14 02:20 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I hate oil pans. Whats the new combo? I spy aluminum block
Re: Not a best, but a first! [Re: sixpackgut] #1661029
08/19/14 02:39 PM
08/19/14 02:39 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
You can beat that out. I have fixed worse.............Next observation. I see wheelie bar brackets on the housing in the pics........where are they?
Monte
Re: Not a best, but a first! [Re: Bigbeep] #1661030
08/19/14 05:09 PM
08/19/14 05:09 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
Glad it wasn't worse John! Hope there isn't any other damage and you get her all fixed up for Norwalk
Re: Not a best, but a first! [Re: sixpackgut] #1661031
08/19/14 09:05 PM
08/19/14 09:05 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
hey what track did you visit
keep up the good work
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Not a best, but a first! [Re: 67mprfan] #1661032
08/20/14 10:17 AM
08/20/14 10:17 AM
Norwalk Ohio
cudasteve68 Offline
cudasteve68  Offline
Norwalk Ohio
MCIR??? It hooked that hard there?
I would love to see pictures/video of that sweet car on the back bumper! In fact get one blown up for me. I would love to hang it next to my little wheelie picture in the garage.
Hope you get it fixed for Norwalk also. I am working on getting my ready for Norwalk as well.
Re: Not a best, but a first! [Re: cudasteve68] #1661033
08/20/14 09:42 PM
08/20/14 09:42 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
I will try to answer these in order.
The pictures don't show how bad the pan really is. It is worn thru in 2 places and buckled all the way around up at the rail. Pretty much wall art at this point.
Yep, you spy an indy low deck block. 529" to be exact. I have been working on it pretty consistently since winter time. I bought it hurt and went thru it and changed a few things, freshened a few things, and added what I like along the way. haven't even got a chance to do any tuning to it yet. Still have the injection set up for the 451 that was in the car. Smashed the pan on the second pass.
Yeah, I have wheelie bars for it but with the caltracs it unloads the tires at the hit if I have them on.
I went to MCIR. Hook was good. They have been using a reverse rotation tire drag and it is working. They are only running bracket races the weekends of their Q32 races. I was pleasantly surprised. Just a note, they are having another one this weekend. Oh, and I won't be back out yet. Just ordered another pan today.
Steve, I haven't got a soul that took any pics. Place was busy and no one took a picture. Including me, gopro on the cage was turned off. Duh! So if I find someone with a picture, I will burn you a copy.
The track owner and a friend of mine went out Monday evening and measured out to the marks from the landing. 230'
Beep
Re: Not a best, but a first! [Re: Bigbeep] #1661034
08/20/14 10:48 PM
08/20/14 10:48 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Sorry to see the carnage John, I bet it was a heck of a ride
Re: Not a best, but a first! [Re: roadhazard] #1661035
08/21/14 12:49 AM
08/21/14 12:49 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Dang, Jon.. Sorry to hear. Drive it like you stole it is only a saying. Over 200 feet !! Are you trying to beat Hemi Fred's wheelie? Great luck. Hope to see you at Norwalk.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Not a best, but a first! [Re: Bigbeep] #1661036
08/21/14 11:15 AM
08/21/14 11:15 AM
Norwalk Ohio
cudasteve68 Offline
cudasteve68  Offline
Norwalk Ohio
I know they look ugly, but you might have to go with some old school bars that mount to the frame rails & point straight down. I am sure you recall John Brown's wheelie bars before he ditched the leaf springs on his green roadrunner. He went 9.20's on springs & tripped the 60' clocks with the back bumper very pass.
Do I see big back window cuda in the air show at the classic this year????
