Milodon S/S drag link through center oil pan issues #1659451
08/15/14 08:35 PM
08/15/14 08:35 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Drag link isn't able to be bolted up on my A body. Put the nut on drivers side on, and the link is about 1.5 inches to high on passengers side from being in place.... Aargg
No way to turn the drag link down that much.... And thought about cutting it on each end and welding in a straight piece to replace how the factory bar is made ..... But an outstanding welder who could do it doesn't want the liability( understand his point).... So looks like this trick pan is unusable to me for this 318 mighty mite project
Unless somebody here has an idea....
71 Duster with slant 6 K and Shumacher conversion mounts.... Can't imagine it working with V8 K and different mounts either.... But who knows
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Milodon S/S drag link through center oil pan issues [Re: B3422W5] #1659452
08/15/14 08:50 PM
08/15/14 08:50 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Got pics? Motor sitting lower than stock? Modify pan to clear?
Re: Milodon S/S drag link through center oil pan issues [Re: B3422W5] #1659453
08/15/14 08:51 PM
08/15/14 08:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Don.. why not rework the pan.. put in a tube large
enough to work and if needed put in wings on the pan
for the volume
Re: Milodon S/S drag link through center oil pan issues [Re: MR_P_BODY] #1659454
08/15/14 09:13 PM
08/15/14 09:13 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
I guess the former version of this pan, the hole was round, now in this newer version it's rectangular. With a round draglink that isn't straight( kinda shaped like a very shallow U) it seems to me unless the alignment was perfect, it's going to rub, restrict steering, or not be even close to fitting like I am dealing with.
Straightening out the bend in the draglink seemed easiest.... But....
Would have to swap out K members, get different mounts to even know if that's a fix.
And a guy I know with an E body used this type pan years ago and reworked the bar like I wanted to, to make it work on his Cuda.
May just stick the stock pan that was on the motor we just yanked on the new mill
As if that isn't all, the built 904 I bought( and is installed behind the new mill in the car now) was shaved for CSR shield clearance, so I can't used my column shift linkage.... So withh retain bench seat with quarter stick on the floor
One thing I have learned...... One day drivetrain swaps never work out that way, this one sure isn't either.
And I still don't know yet if the stacked 4 hole and open spacers used together will clear the flat hood..... Haven't gotten carb and hoses and such finished yet
1.41 best 60 foot
6.56 at 104.17
Re: Milodon S/S drag link through center oil pan issues [Re: B3422W5] #1659455
08/15/14 09:24 PM
08/15/14 09:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its never as easy as we think.. just putting on the
injection on my 416 I had to get a air cleaner spacer
1.3" taller to clear the injector rails and the throttle
linkage... it should clear the hood.. but its close
Re: Milodon S/S drag link through center oil pan issues [Re: B3422W5] #1659456
08/15/14 09:26 PM
08/15/14 09:26 PM
Socal
littleVAL Offline
littleVAL  Offline
Socal
I have an early a body and the /6 and v8 center links are different. The /6 have less clearance/ dip in them. I am unsure on your set up but maybe it just needs a v8 center link. unless they are the same for your year or you already have v8 one. The other option is shimming the steering box and notching the hole for the drag link to rotate the center link if it will give you enough without hurting your steering geometry.
Re: Milodon S/S drag link through center oil pan issues [Re: littleVAL] #1659457
08/15/14 09:35 PM
08/15/14 09:35 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
I have an early a body and the /6 and v8 center links are different. The /6 have less clearance/ dip in them. I am unsure on your set up but maybe it just needs a /6 center link. unless they are the same for your year or you already have /6 one. The other option is shimming the steering box and notching the hole for the drag link to rotate the center link up if it will give you enough.
I had heard the slant draglink is straighter, but called a guy today who is a swap meet guru and he said they are the same. IF he is wrong, that would be a great fix.
Mine is a 71 A body. If yours is for a 63-66 early A body maybe they are different and later A bodies aren't. I don't know. What year is your car ?
Anybody out and out positive if the slant 6 draglink is straighter than a V8 draglink?
1.41 best 60 foot
6.56 at 104.17
Re: Milodon S/S drag link through center oil pan issues [Re: B3422W5] #1659458
08/15/14 09:52 PM
08/15/14 09:52 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Why in the world would you have that pan on a street car???
We had a round tube version on a Duster and the drag link fit fine. Car was originally a /6 and had a V* K member transplant. Used solid (Moroso?) mounts.
Stock front end height, 27" tall tires = 3.25" ground clearance. We changed to a Kevko as the car is going back on the street.
Sooooo, I have a round tube version for sale...lol...if you really want to run one.
Re: Milodon S/S drag link through center oil pan issues [Re: B3422W5] #1659459
08/15/14 09:54 PM
08/15/14 09:54 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Find another welding shop. I had the same problem, and overcame it with the idea you mentioned.
http://hemiduster.com/draglink.htm
It isn't a big deal. I know its a rare thing to do on a car, but in the off-road world, its done all the time. I just welded a tie rod and drag link for my Jeep project.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Milodon S/S drag link through center oil pan issues [Re: B3422W5] #1659460
08/15/14 09:57 PM
08/15/14 09:57 PM
Socal
littleVAL Offline
littleVAL  Offline
Socal
the car is a 64 v8 valiant and it has a noticeably different center link than /6 cars
Re: Milodon S/S drag link through center oil pan issues [Re: cudadoug] #1659461
08/15/14 09:59 PM
08/15/14 09:59 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
I bought the motor complete. It was an enginemaster's build and the pan was on it. Believe it or not, it actually doesn't hang as low as I thought it would.
Anyhow, that why it's on there. And I know those are great pans, but if I can't get it to work in my chassis, it's gonna be an ashtray probably.
1.41 best 60 foot
6.56 at 104.17
Re: Milodon S/S drag link through center oil pan issues [Re: B3422W5] #1659462
08/15/14 10:08 PM
08/15/14 10:08 PM
MI
68shifter Offline
68shifter  Offline
MI
Did you try Johnson Welding on south sprinkle road. Talk to Scott, the younger guy. He's great and will do whatever you need, I wouldn't question his work for an instant.
Re: Milodon S/S drag link through center oil pan issues [Re: 68shifter] #1659463
08/15/14 10:27 PM
08/15/14 10:27 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
That is exactly the guy we tried who didn't want to because of liability. My business is just a block up Sprinkle at the corner of Centre. And yes, he is extremely good.
1.41 best 60 foot
6.56 at 104.17
Re: Milodon S/S drag link through center oil pan issues [Re: B3422W5] #1659464
08/15/14 10:40 PM
08/15/14 10:40 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Check this website:
http://www.bobsprofab.com
Don't know if he is still in business, but he did/does all sorts of fab work
Re: Milodon S/S drag link through center oil pan issues [Re: actionange] #1659465
08/15/14 11:02 PM
08/15/14 11:02 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
i had clearance issue with my Milodon pan with the tube and center link so i put a motor plate and moved the motor around to fit the tube to the link
Re: Milodon S/S drag link through center oil pan issues [Re: actionange] #1659466
08/15/14 11:23 PM
08/15/14 11:23 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Put a Kevko pan on it they hold 6 qts. and they are reasonably priced. That is what I am using and I am happy with it so far. Been 6.20's in the 1/8.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Milodon S/S drag link through center oil pan issues [Re: B3422W5] #1659467
08/15/14 11:39 PM
08/15/14 11:39 PM
MI
68shifter Offline
68shifter  Offline
MI
That's odd, but I get his point. I've cut/bent/sleeved all sorts of stuff to mine to fit my pans over the years. That and getting rid of the ends to make disassembly faster.
I know there's a couple guys at Soule's that do fab stuff on the side but don't recall their names. You could check there too.
Re: Milodon S/S drag link through center oil pan issues [Re: B3422W5] #1659468
08/16/14 12:50 AM
08/16/14 12:50 AM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Mine came w/a straight drag link that is solid. Kinda heavy but doesn't rub anything.
[img] [/img]
Re: Milodon S/S drag link through center oil pan issues [Re: B3422W5] #1659469
08/16/14 01:40 AM
08/16/14 01:40 AM
Woodbury, CT.
mcduff Offline
mcduff  Offline
Woodbury, CT.
No Problem! I had had same problem with my Dart.
Take your current draglink and flip it so the "u" shape is in the other direction. Weld the tie rod ends, pitman arm and idler arm large taper ends smaller & ream the openings from the other side with a tapered reamer. Fits perfect......cost me $20.00 at the welding shop and the price of the reamer....which I forget how much it costs...not much.
Brett Miller 447 W9
Re: Milodon S/S drag link through center oil pan issues [Re: DusterDave] #1659470
08/16/14 03:04 AM
08/16/14 03:04 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
We (Gregsdart) welded a straight piece of solid material, same diameter, then cut the original drop off. Same pan as yours. No problems.
