best performance 340 or 360? #1656366
08/08/14 12:55 PM
08/08/14 12:55 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
i am trying to decide on what motor to install in a dart that will really only get driven on the weekeds for fun. it is an original 340 car and i am leaning to putting a 340 back in but i but i also plan to drive and possibly make a few passes on street night at the strip with it so i want it to run good. i have two motors i am thinking about using.
the first is a 1970 , 340 with forged 10.25-1 pistons
the second is a 1978 360 with Hypereutectic stock compression pistons.
i plan on getting a new cam no matter what motor i build but will keep the pistons that are in them now. i have a set of edelbrock closed chamber heads that i ran on a 360 that i will use . so that would help compression on the 360 and if i used on the 340 i would need to get a thicker head gasket since the pistons pop up .016 out of the block .
i have heard people talk about the 360 having more torque because of the stroke being longer and i dont want to build the 340 if it will not at least run as good as the 360. i fugure at this point either motor will cost about the same to build so i may as well build the best one.
any advice on this?
Re: best performance 340 or 360? [Re: dirt] #1656367
08/08/14 01:08 PM
08/08/14 01:08 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
340 = 3.31 stroke
360 = 3.58 stroke
Although the stroke in the 360 is longer the lack of compression would make it run slower than the 340.
If you used both short blocks in stock form the 340 would be better. If your going to tweak it a little the aftermarket really supports the 360.
I would use the 340 but its your call...
...FAFO...
Re: best performance 340 or 360? [Re: dirt] #1656368
08/08/14 01:56 PM
08/08/14 01:56 PM
First thing you need to do is to figure the true mechanical compression ratio on both motors and go from there If the 340 is anywhere near blueprint specs, 11.56 to 1 and the 360 is under that, and above 8.75 to 1, I would use the 360
Re: best performance 340 or 360? [Re: Cab_Burge] #1656369
08/08/14 03:04 PM
08/08/14 03:04 PM
dogdays Offline
dogdays  Offline
Oh no, not again!
R.
Re: best performance 340 or 360? [Re: Cab_Burge] #1656370
08/08/14 03:18 PM
08/08/14 03:18 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
No replacement for displacement.
Kevin
Re: best performance 340 or 360? [Re: Twostick] #1656371
08/08/14 03:35 PM
08/08/14 03:35 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
i guess if its debateable as to what motor is the better one , then i probably would be happy with either one if they both make similar power, a couple horse power difference is not going to bother me. if they are within 15 horse power of each outher then i may as well build the 340. since it has a forged crank and forged pistons, seems like it would take more of a beating if i ever decided to hammer on it.
would there really be a difference you could feel on the street or see at the drag strip?
Re: best performance 340 or 360? [Re: dirt] #1656372
08/08/14 04:50 PM
08/08/14 04:50 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
The 340 and 360 are two different animals. I've been playing with 360's for years and you can make them run.
matt
[img] [/img]
Re: best performance 340 or 360? [Re: dirt] #1656373
08/08/14 05:17 PM
08/08/14 05:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Depends on what heads... I'll take the bore any day
and make up for the stroke in RPMs... being its a Dart
I'd run the 340 but I also want some other factors
also... conv and a gear.. I also want to turn it higher
than 6000(stock rpm).. valve springs were the weak
link in stock 340s... if you have decent heads with
over size valves.. I want bore
Re: best performance 340 or 360? [Re: MR_P_BODY] #1656374
08/08/14 05:36 PM
08/08/14 05:36 PM
Guitar Jones Offline
I have done both with identical parts and spec's except of course for the bore and stroke. This was my race car though so it had W5 heads and a large flat tappet.
I revved the 340 to 8000 and used a converter that was about 500 rpm more stall speed and a 5.13 gear.
The 360 used a 4.88 gear and revved to 7200.
They ran identical ET's but the 360 left a little harder but wasn't as strong on the top end. The 340 had a great top end charge and I loved that for racing the slower cars.
The drawback was the 340 required more valvetrain maintenance from the higher RPMs.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: best performance 340 or 360? [Re: Guitar Jones] #1656375
08/08/14 08:36 PM
08/08/14 08:36 PM
Socal
littleVAL Offline
littleVAL  Offline
Socal
340 is nice because the extra bore size helps the heads flow better. The shorter stroke can allow for more rpm. The 360 I like the extra cubes and torque off the line. Less maintenance because you don't have to beat on it to get the power. The other advantage is if you scatter it there are thousands more everywhere to replace it. One option would be some light aftermarket rods and pistons in 360 and you could give it some r's when you need it. I would build a stroker the costs have come down so much (such as a kit from BPE) it isn't that much more.
Re: best performance 340 or 360? [Re: littleVAL] #1656376
08/08/14 09:21 PM
08/08/14 09:21 PM
Emmett, Idaho
SuperStockWagon Offline
Emmett, Idaho
This
NHRA Stock/SuperStock Class Racing..Engineered Muscle In Motion!
Re: best performance 340 or 360? [Re: SuperStockWagon] #1656377
08/09/14 12:00 PM
08/09/14 12:00 PM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
I would not worry about the 360 taking a beating. The 360 in my Dart was built 19 years ago. The only thing replaced internally since then was new valve springs either 2 or 3 years ago. The engine never turns over 5,800 r.p.m., but it has held up well as a bracket racer.
Re: best performance 340 or 360? [Re: SuperStockWagon] #1656378
08/09/14 12:08 PM
08/09/14 12:08 PM
Az
Crizila Offline
Crizila  Offline
Az
This
Save the 340 and build the 360.
Fastest 300
Re: best performance 340 or 360? [Re: Crizila] #1656379
08/09/14 12:18 PM
08/09/14 12:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This
Yes do that... but sell me the 340 block... which
engine made more HP... seems most everyone on this
site isnt into RPM.. hp is measured in rpm and if you
put more rpms in that minute you make more hp...
I'll buy the 340 block.. I'm starting to run low on them
Re: best performance 340 or 360? [Re: MR_P_BODY] #1656380
08/09/14 02:06 PM
08/09/14 02:06 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
This
when they were stock we would spin the 340's to 6'000 +. With all the nice parts these 340/360's make power and should be reliable past 7k
Re: best performance 340 or 360? [Re: ademon] #1656381
08/09/14 03:05 PM
08/09/14 03:05 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
I like the idea where you can take a 340 and punch
and stroke it to 426 C.I. then fit it in a little
Dodge Colt or Plymouth arrow from the 70s and
that thing would just rip up the street or strip.
Worked for Bob Glidden.
Snap your neck, mega G-force launch, is all I want!
Re: best performance 340 or 360? [Re: MR_P_BODY] #1656382
08/09/14 03:39 PM
08/09/14 03:39 PM
Socal
littleVAL Offline
littleVAL  Offline
Socal
It is a street car that is why I think a less aggressive approach is better. Keep the rpms down and the need for repairs down as well. With the added benefit of better (lower) gearing and mileage on the street
Re: best performance 340 or 360? [Re: littleVAL] #1656383
08/09/14 04:06 PM
08/09/14 04:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On my W-9 I spun it to 8200 every pass and it was
higher at times... I checked the lash twice a year
but never changed it in 5 years.. if he use quality
parts he wont touch things for years.. JMO on his
set up... he can do what ever floats his boat.. I
gave my opinion and the reasons why
Re: best performance 340 or 360? [Re: MR_P_BODY] #1656384
08/09/14 07:33 PM
08/09/14 07:33 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Mouthball the 340, build the 360. If its a original 340 car someday you may want to go back stock. That way you can beat the heck outta the 360. JMO
Re: best performance 340 or 360? [Re: Cudajon] #1656385
08/10/14 11:15 PM
08/10/14 11:15 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
thanks everyone for the advice. I know the 340 is worth more money but I don't plan to sell it anyway and if the performance of the 360 and 340 is similar, I think I will go with the 340. partly because that's what the car came with and also because I think it will handle more hammering since it has a better crank and forged pistons in it now,
. I have a 4 speed and I know that can be hard on stuff. I used to have a 360 in one of my cars with a 4 speed and never had any problems with it either.
