Re: best performance 340 or 360?
[Re: dirt]
#1656367
08/08/14 01:08 PM
08/08/14 01:08 PM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
340 = 3.31 stroke 360 = 3.58 stroke Although the stroke in the 360 is longer the lack of compression would make it run slower than the 340. If you used both short blocks in stock form the 340 would be better. If your going to tweak it a little the aftermarket really supports the 360. I would use the 340 but its your call...
...FAFO...
[Re: Cab_Burge]
#1656369
08/08/14 03:04 PM
08/08/14 03:04 PM
dogdays
[Re: dirt]
#1656373
08/08/14 05:17 PM
08/08/14 05:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Depends on what heads... I'll take the bore any day and make up for the stroke in RPMs... being its a Dart I'd run the 340 but I also want some other factors also... conv and a gear.. I also want to turn it higher than 6000(stock rpm).. valve springs were the weak link in stock 340s... if you have decent heads with over size valves.. I want bore
[Re: MR_P_BODY]
#1656374
08/08/14 05:36 PM
08/08/14 05:36 PM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
I have done both with identical parts and spec's except of course for the bore and stroke. This was my race car though so it had W5 heads and a large flat tappet.
I revved the 340 to 8000 and used a converter that was about 500 rpm more stall speed and a 5.13 gear.
The 360 used a 4.88 gear and revved to 7200.
They ran identical ET's but the 360 left a little harder but wasn't as strong on the top end. The 340 had a great top end charge and I loved that for racing the slower cars.
The drawback was the 340 required more valvetrain maintenance from the higher RPMs.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#1656375
08/08/14 08:36 PM
08/08/14 08:36 PM
Posts: 108 Socal
littleVAL
Socal
340 is nice because the extra bore size helps the heads flow better. The shorter stroke can allow for more rpm. The 360 I like the extra cubes and torque off the line. Less maintenance because you don't have to beat on it to get the power. The other advantage is if you scatter it there are thousands more everywhere to replace it. One option would be some light aftermarket rods and pistons in 360 and you could give it some r's when you need it. I would build a stroker the costs have come down so much (such as a kit from BPE) it isn't that much more.
[Re: Crizila]
#1656379
08/09/14 12:18 PM
08/09/14 12:18 PM
MR_P_BODY
This
Save the 340 and build the 360.
Yes do that... but sell me the 340 block... which engine made more HP... seems most everyone on this site isnt into RPM.. hp is measured in rpm and if you put more rpms in that minute you make more hp... I'll buy the 340 block.. I'm starting to run low on them
[Re: MR_P_BODY]
#1656380
08/09/14 02:06 PM
08/09/14 02:06 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
This
when they were stock we would spin the 340's to 6'000 +. With all the nice parts these 340/360's make power and should be reliable past 7k
[Re: ademon]
#1656381
08/09/14 03:05 PM
08/09/14 03:05 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
I like the idea where you can take a 340 and punch and stroke it to 426 C.I. then fit it in a little Dodge Colt or Plymouth arrow from the 70s and that thing would just rip up the street or strip.
Worked for Bob Glidden.
Snap your neck, mega G-force launch, is all I want!
[Re: littleVAL]
#1656383
08/09/14 04:06 PM
08/09/14 04:06 PM
MR_P_BODY
It is a street car that is why I think a less aggressive approach is better. Keep the rpms down and the need for repairs down as well. With the added benefit of better (lower) gearing and mileage on the street
On my W-9 I spun it to 8200 every pass and it was higher at times... I checked the lash twice a year but never changed it in 5 years.. if he use quality parts he wont touch things for years.. JMO on his set up... he can do what ever floats his boat.. I gave my opinion and the reasons why
