Re: 650 hp low 10s high 9s fuel systems what's in your car
[Re: RAY1969CARS]
#1656232
08/07/14 10:52 PM
08/07/14 10:52 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
BG400 pump,BG two port regulator, #10AN Teflon inlet line to pump , 100 micron fuel filter before pump, 10 Micron fuel filter between punp and regulator with #8 AN Teflon lines to reg, #6 AN teflon lines to the E85 carb. ![](/ubbthreads/images/graemlins/thumbs.gif) Works good, last a long time so far ![](/ubbthreads/images/graemlins/grin.gif) Not cheap though ![](/ubbthreads/images/graemlins/shruggy.gif) IHTHs ![](/ubbthreads/images/graemlins/thumbs.gif) My aluminum(black ![](/ubbthreads/images/graemlins/scope.gif) )fuel cell is mounted in the front of the car, the pump is mounted directly behind the cell and the fuel lines are all very short ![](/ubbthreads/images/graemlins/thumbs.gif) No problems in almost two years of use with this system ![](/ubbthreads/images/graemlins/scope.gif) I do use a 25 amp relay to activate the fuel pump off of its switch ![](/ubbthreads/images/graemlins/thumbs.gif) This motor(505 C.I. 400 stroker) made 676 HP and 686 Ft lbs on a DTS dyno in Klamath (4300 ft above sea level),OR on E85. 9.12 ET at 146.76 MPH weighing 2750 lbs in my Cuda
[Re: Wedgeman]
#1656235
08/08/14 01:34 AM
08/08/14 01:34 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Holley blue pump 3/8 aluminum fuel line 6 an line to each fuel bowl 950 cfm carb proform main body 3/8 standard fuel filter dynoed 606 hp
1.30 sec 60ft 6.40 sec 1/8 mile
67 Barracuda
I am curious if you have weighed your 67 Cuda ? Thanks , Ron
[Re: 383man]
#1656237
08/08/14 05:13 AM
08/08/14 05:13 AM
Posts: 3,210 robin hood country
deaks
robin hood country
67 Barracuda
So am I, that's a great 60ft time, what is your suspension, motor set up ?
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#1656238
08/08/14 05:16 AM
08/08/14 05:16 AM
deaks
robin hood country
To the op #12 to 100 micron robb mc filter before mallory 250 pump with #8 return, #10 to larger holley reg, 2 x #8 to 950 holley. Mick
[Re: RAY1969CARS]
#1656240
08/08/14 10:55 AM
08/08/14 10:55 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I was running a pair of Holley 150s in parallel.. #10 to the inlets, #8 forward to a Mallory 4 port reg, and #8s to a 1050 dom on E-85... #8 return to the 5 gal plastic cell but it was running high 8s ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1656241
08/08/14 11:21 AM
08/08/14 11:21 AM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
Pro comp 140 pump (same as holley black) aeromotive filter to aluminum 1/2" line deadhead to professional products regulator, dual 8 an lines to 1050 Dominator. 3800lb 67 Charger, 10.50's @125 mph, 1.47 60'.
67' charger 499 RB
10.57 at 127
[Re: Crizila]
#1656244
08/08/14 12:33 PM
08/08/14 12:33 PM
Posts: 12,422 Taxes & Virus's R-US, NY
Dragula
Best combo I have found so far is, Aeromotive A1000 and AN10 from pump to retrun lines. AN12 feeding it. Fuel is cooler, pump runs quiet, uses barely 8 amps, and very little fuel pressure fluctuation.
Now I recently buoght a Magnafuel 275 for my Duster, and I do not like it. Its very loud even mounted on eurathane, the pressure fluctuates a lot, and it hits the regulator so hard on start-up, its ringing in the car. Very dissapointed. I was told they are the best, I doubt I will ever buy another.
[Re: Dragula]
#1656245
08/08/14 12:45 PM
08/08/14 12:45 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
love my Mallory 140 with return regulator. Been as fast as 140 mph with 2 edelbrock carbs that everyone said would run out of fuel. 8an to the front. 10an back to the tank. regulater after the carb or carbs
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1656246
08/08/14 05:06 PM
08/08/14 05:06 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Pro Comp 140 gph pump with #8 braided line, holley regulator with 2 #6 lines to QFT 950 running on E85.
Same pump for 7 yrs now.
Best of 10.33 @ 128....
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: deaks]
#1656247
08/08/14 05:41 PM
08/08/14 05:41 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
67 Barracuda
I'm running a Indy 360-1 headed 408 ci 10.8 cr 950carb proform main body car weights about 3100 with me in it LAdder bar suspension Dana 60 4.56 gear
I have 29 in tires, I figure it handicaps my et because time is only 6.40. I should run lower than that. I'll be trying 30 in tires tonight just to see...
Dan
[Re: Dap]
#1656249
08/08/14 11:09 PM
08/08/14 11:09 PM
Posts: 1,404 Chesterfield Twp. Mi.
John Burdine
The biggest pump you can afford. You can't have too much fuel, too much horsepower or too much traction
-12 from the fuel cell to a Magnafuel prostar 500 pump,-10 from the pump to a fuel log. I have a Magnafuel 2 port regulator on the fuel log with -6 lines to a dominator.
mine is the same. pump gas n/a high 9's. didn't need that much pump, but sick of upgrading stuff down the road.
[Re: Dap]
#1656250
08/08/14 11:26 PM
08/08/14 11:26 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Dap, What is your fuel pressure set at with the motor idling? I just installed the same fuel system you have and mine is trying to quit at the mph lights and I am only running 1/8 mile.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
