650 hp low 10s high 9s fuel systems what's in your car #1656231
08/07/14 10:32 PM
08/07/14 10:32 PM
CA.
RAY1969CARS Offline OP
CA.
Please post race gas and E85 systems complete Pump size filter size line size regulator size and carburetor line size thanks guys Mopar or no car
Re: 650 hp low 10s high 9s fuel systems what's in your car [Re: RAY1969CARS] #1656232
08/07/14 10:52 PM
08/07/14 10:52 PM
BG400 pump,BG two port regulator, #10AN Teflon inlet line to pump , 100 micron fuel filter before pump, 10 Micron fuel filter between punp and regulator with #8 AN Teflon lines to reg, #6 AN teflon lines to the E85 carb. Works good, last a long time so far Not cheap though IHTHs My aluminum(black )fuel cell is mounted in the front of the car, the pump is mounted directly behind the cell and the fuel lines are all very short No problems in almost two years of use with this system I do use a 25 amp relay to activate the fuel pump off of its switch This motor(505 C.I. 400 stroker) made 676 HP and 686 Ft lbs on a DTS dyno in Klamath (4300 ft above sea level),OR on E85. 9.12 ET at 146.76 MPH weighing 2750 lbs in my Cuda
Re: 650 hp low 10s high 9s fuel systems what's in your car [Re: Cab_Burge] #1656233
08/07/14 10:57 PM
08/07/14 10:57 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
The biggest pump you can afford. You can't have too much fuel, too much horsepower or too much traction
Re: 650 hp low 10s high 9s fuel systems what's in your car [Re: Bigcube] #1656234
08/07/14 11:17 PM
08/07/14 11:17 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Holley blue pump
3/8 aluminum fuel line
6 an line to each fuel bowl
950 cfm carb proform main body
3/8 standard fuel filter
dynoed 606 hp
1.30 sec 60ft
6.40 sec 1/8 mile
67 Barracuda
Re: 650 hp low 10s high 9s fuel systems what's in your car [Re: Wedgeman] #1656235
08/08/14 01:34 AM
08/08/14 01:34 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Holley blue pump
dynoed 606 hp
1.30 sec 60ft
6.40 sec 1/8 mile
67 Barracuda
I am curious if you have weighed your 67 Cuda ? Thanks , Ron
Re: 650 hp low 10s high 9s fuel systems what's in your car [Re: RAY1969CARS] #1656236
08/08/14 04:09 AM
08/08/14 04:09 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
we ran the Holley Volumax 250gph pumps on both of our cars and the volumax regulator. Think we installed them both in the mid 90's. Both still going strong. Holley blue pump.... I've lost how many people have been roaming the pits looking for parts and spares to borrow.
Re: 650 hp low 10s high 9s fuel systems what's in your car [Re: 383man] #1656237
08/08/14 05:13 AM
08/08/14 05:13 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Holley blue pump
dynoed 606 hp
1.30 sec 60ft
6.40 sec 1/8 mile
67 Barracuda
So am I, that's a great 60ft time, what is your suspension, motor set up ?
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: 650 hp low 10s high 9s fuel systems what's in your car [Re: deaks] #1656238
08/08/14 05:16 AM
08/08/14 05:16 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
To the op
#12 to 100 micron robb mc filter before mallory 250 pump with #8 return, #10 to larger holley reg, 2 x #8 to 950 holley.
Mick
best 60ft 1.36
Re: 650 hp low 10s high 9s fuel systems what's in your car [Re: J_BODY] #1656239
08/08/14 09:51 AM
08/08/14 09:51 AM
gregsdart Offline
gregsdart  Offline
I have a large box full of blue pump parts! I think it was pump # four that finally sent me elsewhere!
Re: 650 hp low 10s high 9s fuel systems what's in your car [Re: RAY1969CARS] #1656240
08/08/14 10:55 AM
08/08/14 10:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I was running a pair of Holley 150s in parallel..
#10 to the inlets, #8 forward to a Mallory 4 port
reg, and #8s to a 1050 dom on E-85... #8 return to
the 5 gal plastic cell but it was running high 8s
Re: 650 hp low 10s high 9s fuel systems what's in your car [Re: MR_P_BODY] #1656241
08/08/14 11:21 AM
08/08/14 11:21 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
Pro comp 140 pump (same as holley black) aeromotive filter to aluminum 1/2" line deadhead to professional products regulator, dual 8 an lines to 1050 Dominator. 3800lb 67 Charger, 10.50's @125 mph, 1.47 60'.
67' charger 499 RB 10.57 at 127
Re: 650 hp low 10s high 9s fuel systems what's in your car [Re: dragram440] #1656242
08/08/14 11:44 AM
08/08/14 11:44 AM
tboomer Online work
tboomer  Online Work
Gorski Firecore 140 1/2" aluminum feed line Holley filter deadheaded Holley regulator #6 feed lines into an 1150 Dominator. 512 RB 3600# plus race ready. 1.385 60' 10.15 @ 131 mph..
Re: 650 hp low 10s high 9s fuel systems what's in your car [Re: RAY1969CARS] #1656243
08/08/14 12:01 PM
08/08/14 12:01 PM
Az
Crizila Offline
Crizila  Offline
Az
One of the best things you can do is contact Magnafuel. Tell them all your particulars, and they will put together a system for you. Not cheap, but it will be right - the first time.
Fastest 300
Re: 650 hp low 10s high 9s fuel systems what's in your car [Re: Crizila] #1656244
08/08/14 12:33 PM
08/08/14 12:33 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Best combo I have found so far is, Aeromotive A1000 and AN10 from pump to retrun lines. AN12 feeding it. Fuel is cooler, pump runs quiet, uses barely 8 amps, and very little fuel pressure fluctuation.
Now I recently buoght a Magnafuel 275 for my Duster, and I do not like it. Its very loud even mounted on eurathane, the pressure fluctuates a lot, and it hits the regulator so hard on start-up, its ringing in the car. Very dissapointed. I was told they are the best, I doubt I will ever buy another.
Re: 650 hp low 10s high 9s fuel systems what's in your car [Re: Dragula] #1656245
08/08/14 12:45 PM
08/08/14 12:45 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
love my Mallory 140 with return regulator. Been as fast as 140 mph with 2 edelbrock carbs that everyone said would run out of fuel. 8an to the front. 10an back to the tank. regulater after the carb or carbs
Re: 650 hp low 10s high 9s fuel systems what's in your car [Re: sixpackgut] #1656246
08/08/14 05:06 PM
08/08/14 05:06 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Pro Comp 140 gph pump with #8 braided line, holley regulator with 2 #6 lines to QFT 950 running on E85.
Same pump for 7 yrs now.
Best of 10.33 @ 128....
Tony
70 AARCuda Vitamin C
Re: 650 hp low 10s high 9s fuel systems what's in your car [Re: deaks] #1656247
08/08/14 05:41 PM
08/08/14 05:41 PM
W
Wedgeman Offline
Wedgeman  Offline
W
Holley blue pump
dynoed 606 hp
1.30 sec 60ft
6.40 sec 1/8 mile
67 Barracuda
I'm running a Indy 360-1 headed 408 ci
10.8 cr 950carb proform main body
car weights about 3100 with me in it
LAdder bar suspension
Dana 60 4.56 gear
I have 29 in tires, I figure it handicaps my et because time is only 6.40. I should run lower than that.
I'll be trying 30 in tires tonight just to see...
Dan
Re: 650 hp low 10s high 9s fuel systems what's in your car [Re: Bigcube] #1656248
08/08/14 06:54 PM
08/08/14 06:54 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
-12 from the fuel cell to a Magnafuel prostar 500 pump,-10 from the pump to a fuel log. I have a Magnafuel 2 port regulator on the fuel log with -6 lines to a dominator.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: 650 hp low 10s high 9s fuel systems what's in your car [Re: Dap] #1656249
08/08/14 11:09 PM
08/08/14 11:09 PM
Chesterfield Twp. Mi.
John Burdine Offline
mine is the same. pump gas n/a high 9's. didn't need that much pump, but sick of upgrading stuff down the road.
Re: 650 hp low 10s high 9s fuel systems what's in your car [Re: Dap] #1656250
08/08/14 11:26 PM
08/08/14 11:26 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Dap, What is your fuel pressure set at with the motor idling?
I just installed the same fuel system you have and mine is trying to quit at the mph lights and I am only running 1/8 mile.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
