Re: 650 hp low 10s high 9s fuel systems what's in your car
[Re: RAY1969CARS]
#1656232
08/07/14 10:52 PM
08/07/14 10:52 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
BG400 pump,BG two port regulator, #10AN Teflon inlet line to pump , 100 micron fuel filter before pump, 10 Micron fuel filter between punp and regulator with #8 AN Teflon lines to reg, #6 AN teflon lines to the E85 carb. Works good, last a long time so far Not cheap though IHTHs My aluminum(black )fuel cell is mounted in the front of the car, the pump is mounted directly behind the cell and the fuel lines are all very short No problems in almost two years of use with this system I do use a 25 amp relay to activate the fuel pump off of its switch This motor(505 C.I. 400 stroker) made 676 HP and 686 Ft lbs on a DTS dyno in Klamath (4300 ft above sea level),OR on E85. 9.12 ET at 146.76 MPH weighing 2750 lbs in my Cuda
[Re: Wedgeman]
#1656235
08/08/14 01:34 AM
08/08/14 01:34 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Holley blue pump 3/8 aluminum fuel line 6 an line to each fuel bowl 950 cfm carb proform main body 3/8 standard fuel filter dynoed 606 hp
1.30 sec 60ft 6.40 sec 1/8 mile
67 Barracuda
I am curious if you have weighed your 67 Cuda ? Thanks , Ron
[Re: 383man]
#1656237
08/08/14 05:13 AM
08/08/14 05:13 AM
Posts: 3,210 robin hood country
deaks
robin hood country
67 Barracuda
So am I, that's a great 60ft time, what is your suspension, motor set up ?
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#1656238
08/08/14 05:16 AM
08/08/14 05:16 AM
deaks
robin hood country
To the op #12 to 100 micron robb mc filter before mallory 250 pump with #8 return, #10 to larger holley reg, 2 x #8 to 950 holley. Mick
[Re: RAY1969CARS]
#1656240
08/08/14 10:55 AM
08/08/14 10:55 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I was running a pair of Holley 150s in parallel.. #10 to the inlets, #8 forward to a Mallory 4 port reg, and #8s to a 1050 dom on E-85... #8 return to the 5 gal plastic cell but it was running high 8s
[Re: MR_P_BODY]
#1656241
08/08/14 11:21 AM
08/08/14 11:21 AM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
Pro comp 140 pump (same as holley black) aeromotive filter to aluminum 1/2" line deadhead to professional products regulator, dual 8 an lines to 1050 Dominator. 3800lb 67 Charger, 10.50's @125 mph, 1.47 60'.
67' charger 499 RB
10.57 at 127
[Re: Crizila]
#1656244
08/08/14 12:33 PM
08/08/14 12:33 PM
Posts: 12,395 Taxes & Virus's R-US, NY
Dragula
Best combo I have found so far is, Aeromotive A1000 and AN10 from pump to retrun lines. AN12 feeding it. Fuel is cooler, pump runs quiet, uses barely 8 amps, and very little fuel pressure fluctuation.
Now I recently buoght a Magnafuel 275 for my Duster, and I do not like it. Its very loud even mounted on eurathane, the pressure fluctuates a lot, and it hits the regulator so hard on start-up, its ringing in the car. Very dissapointed. I was told they are the best, I doubt I will ever buy another.
[Re: Dragula]
#1656245
08/08/14 12:45 PM
08/08/14 12:45 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
love my Mallory 140 with return regulator. Been as fast as 140 mph with 2 edelbrock carbs that everyone said would run out of fuel. 8an to the front. 10an back to the tank. regulater after the carb or carbs
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1656246
08/08/14 05:06 PM
08/08/14 05:06 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Pro Comp 140 gph pump with #8 braided line, holley regulator with 2 #6 lines to QFT 950 running on E85.
Same pump for 7 yrs now.
Best of 10.33 @ 128....
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: deaks]
#1656247
08/08/14 05:41 PM
08/08/14 05:41 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
67 Barracuda
I'm running a Indy 360-1 headed 408 ci 10.8 cr 950carb proform main body car weights about 3100 with me in it LAdder bar suspension Dana 60 4.56 gear
I have 29 in tires, I figure it handicaps my et because time is only 6.40. I should run lower than that. I'll be trying 30 in tires tonight just to see...
Dan
[Re: Dap]
#1656249
08/08/14 11:09 PM
08/08/14 11:09 PM
Posts: 1,404 Chesterfield Twp. Mi.
John Burdine
The biggest pump you can afford. You can't have too much fuel, too much horsepower or too much traction
-12 from the fuel cell to a Magnafuel prostar 500 pump,-10 from the pump to a fuel log. I have a Magnafuel 2 port regulator on the fuel log with -6 lines to a dominator.
mine is the same. pump gas n/a high 9's. didn't need that much pump, but sick of upgrading stuff down the road.
[Re: Dap]
#1656250
08/08/14 11:26 PM
08/08/14 11:26 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Dap, What is your fuel pressure set at with the motor idling? I just installed the same fuel system you have and mine is trying to quit at the mph lights and I am only running 1/8 mile.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
