1971 340 Auto Trans KD Linkage Question #1656091
08/07/14 03:05 PM
08/07/14 03:05 PM
Waterford, MI
JAK Offline OP
JAK  Offline OP
Waterford, MI
Should the trans KD linkage pivot that is part of the throttle cable bracket be engine color or? Trying to determine if that pivot was on the throttle cable bracket when the engine was painted.
Re: 1971 340 Auto Trans KD Linkage Question [Re: JAK] #1656092
08/07/14 03:54 PM
08/07/14 03:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I would think that it was , it's bolted to the engine when the intake is installed , the engine build already nows if it's going to be a 4 speed or an auto , it would make little sense to put it on after paint. The negative cable has paint because it is installed during initial assembly.
Re: 1971 340 Auto Trans KD Linkage Question [Re: JohnRR] #1656093
08/07/14 06:41 PM
08/07/14 06:41 PM
Waterford, MI
JAK Offline OP
JAK  Offline OP
Waterford, MI
Here is a pic of the KD pivot that I think was part of the KD linkage that was added after the engine was painted.
Re: 1971 340 Auto Trans KD Linkage Question [Re: JAK] #1656094
08/07/14 07:24 PM
08/07/14 07:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That part would be added after and I would think the pivot pin was masked off .
Re: 1971 340 Auto Trans KD Linkage Question [Re: JohnRR] #1656095
08/08/14 03:06 PM
08/08/14 03:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I have several unmolested examples in my parts pile; all of the brackets are painted, some have no trace of paint on the pivot shaft some do.
As usual with Ma Mopar, there are no set rules.
Re: 1971 340 Auto Trans KD Linkage Question [Re: John_Kunkel] #1656096
08/08/14 09:26 PM
08/08/14 09:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thanks John
Re: 1971 340 Auto Trans KD Linkage Question [Re: JohnRR] #1656097
08/09/14 10:19 AM
08/09/14 10:19 AM
Waterford, MI
JAK Offline OP
JAK  Offline OP
Waterford, MI
Thanks for the feedback guys. Maybe I will just flip a coin .
