Re: piston pin question
[Re: robnbird]
#1655168
08/05/14 01:14 AM
08/05/14 01:14 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a small amount...maybe .010 ..but the pin isnt tight in there EDIT mine are a different brand but my CP and Diamond both have a little movement
[Re: MR_P_BODY]
#1655169
08/05/14 01:21 AM
08/05/14 01:21 AM
Posts: 914 tn
robnbird
tn
well I am a little surprised that I have that much .
[Re: Cab_Burge]
#1655171
08/05/14 02:17 AM
08/05/14 02:17 AM
Posts: 914 tn
robnbird
tn
It is way better to have movement on wrist pins cold than it is to not have any movement cold I've seen duoble Tru Arcs kicked out of the retaining grooves due to to little end clearances on them It ruined the cylinder it happen to The engine asembler, a freind of mine, didn't know to check for end play on every pin back then As far as wire reatiners on Mahle brand piston I have no personel experiences with them, sorry The old Hemi and (I think) early Mopar V8 motors all used round 3/4 circumference wire retainers back when They had lots of end play on some of them also Contact Mahle tech. and ask them the minimums and maximum end play before telling them how much yours have
thanks cab I will call them tomorrow .. and maybe at running temp some of the clearance will be taken up . here is a pic of the piston .
[Re: robnbird]
#1655172
08/05/14 02:20 AM
08/05/14 02:20 AM
Posts: 914 tn
robnbird
tn
[Re: robnbird]
#1655173
08/05/14 02:36 AM
08/05/14 02:36 AM
Posts: 914 tn
robnbird
tn
[Re: Sport440]
#1655175
08/05/14 12:22 PM
08/05/14 12:22 PM
Posts: 914 tn
robnbird
tn
Gotta have some clearence IMO, Your .015/.020 is about right. Shouldnt Ever be .00000 The pin will expand with heat.
well it not .00000 but the point is the Hemi has very little compared to this much but I am calling mahle today to see what they say and from opinion on here I will use them and be Ok with it . thanks
[Re: Sport440]
#1655176
08/05/14 12:27 PM
08/05/14 12:27 PM
Posts: 2,654 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Stock 426 Hemi spec is .006"-.012". I assume your engine would want similar. If you are using wire keepers make sure you have the proper pins for that. That are different from all others. Instead of being flat on the ends the are chamfered. When the pin slides to one side the chamfer touches the wire and pushes it down against the groove instead of a flat end trying to push it out.
2011 Drag Pak Challenger
[Re: rickseeman]
#1655177
08/05/14 12:52 PM
08/05/14 12:52 PM
Posts: 914 tn
robnbird
tn
just hung up the phone and Mahle said .020 to .025 and did not have the pin expansion answer . But said all of their piston pin had wire locks and the clearance was .020 to .025 on all their applications . So I good with this piston and Mahle was very helpful in giving me information
[Re: robnbird]
#1655178
08/05/14 01:16 PM
08/05/14 01:16 PM
Posts: 1,505 TN
SCATPACK 1
TN
WOW, that is a really short piston. What is the weight on each one?
Old Geezer Racing
[Re: dogdays]
#1655181
08/05/14 10:23 PM
08/05/14 10:23 PM
Posts: 914 tn
robnbird
tn
NASCAR pistons that are coming up used on the 'bay all have the wire locks. The Spirolocks are going away. Double Tru-Arcs went away before them.
r.
well I ok with the wire lock after wrestling with these wire to get them in place . I think the wire should be just a tad larger and the grove a tad deeper .
[Re: robnbird]
#1655182
08/05/14 11:16 PM
08/05/14 11:16 PM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
r.
Difficult to install also means difficult to get out too, a good thing. I'll use oversize locks in some high piston speed cases, put the gaps at 6 o'clock.
[Re: LSP]
#1655183
08/06/14 08:54 PM
08/06/14 08:54 PM
Posts: 914 tn
robnbird
tn
r.
I have already installed the wire keepers and I put them just past the notch that is used to remove the wire if necessary .. thanks for the info .
