1997 5.9 Magnum -- Will a manual trans bolt up? #1655039
08/04/14 06:10 PM
08/04/14 06:10 PM
Southeast Wisconsin
Sunroof_Cuda Offline OP
Southeast Wisconsin
Does the 5.9 magnum have the provision for the pilot bushing and input shaft from a manual transmission? The motor I have chance to get had an automatic originally. Looking to bolt a smallblock bell and an 833 behind this motor.
Re: 1997 5.9 Magnum -- Will a manual trans bolt up? [Re: Sunroof_Cuda] #1655040
08/04/14 06:23 PM
08/04/14 06:23 PM
dogdays Offline
dogdays  Offline
Go to the store and buy a pilot bearing for a 97 5.9 Magnum Ram. It fits in the torque converter ring on the crankshaft. They haven't used the little oilite bushings for years.
R.
Re: 1997 5.9 Magnum -- Will a manual trans bolt up? [Re: dogdays] #1655041
08/05/14 02:43 PM
08/05/14 02:43 PM
Southeast Wisconsin
Southeast Wisconsin
My biggest concern is determining if the register in the crank that is deep enough to accept the transmission input shaft. I know the vintage LA motors are hit and miss --- many but not all automatic cars don't have the register cut deep enough to accept the input shaft. The choice in that case is to bore the hole deeper or cut a portion of your input shaft off. I have never been in that situation and hope to avoid it in the future. So, the punchline, does a 5.9 magnum crank have a crank hole deep enough to fit a manual trans input shaft?
I should be able to answer this question later in the week if I pick up this motor. Just an FYI, keeping the slant in my Challenger. This is a cheap way of getting a running motor back in another car.
Re: 1997 5.9 Magnum -- Will a manual trans bolt up? [Re: Sunroof_Cuda] #1655042
08/05/14 02:54 PM
08/05/14 02:54 PM
Carlisle, AR.
mdwyer Offline
mdwyer  Offline
Carlisle, AR.
I put a 97 5.9 into my 72 satellite with a 4sp od 833 with the register/ crank bearing and DID NOT have to trim input shaft.
Just measure first is my recommendation
1970 Challenger T/A
1970 Roadrunner RM21 Vcode
1971 Gtx
1971 Satellite
1971 Charger 500 GB5 383 A54 car
1972 Satellite
1997 Dodge 1500 hunting rig
2014 Ram 2500 Mega Cab
Re: 1997 5.9 Magnum -- Will a manual trans bolt up? [Re: mdwyer] #1655043
08/05/14 03:13 PM
08/05/14 03:13 PM
Southeast Wisconsin
Southeast Wisconsin
Thanks very much. Gives me the push to drive the 100 miles to pick up that motor. Much appreciated.
Re: 1997 5.9 Magnum -- Will a manual trans bolt up? [Re: Sunroof_Cuda] #1655044
08/05/14 05:55 PM
08/05/14 05:55 PM
dogdays Offline
dogdays  Offline
I didn't have any problem with an 86 318 and my 1964 NP420 manual transmission. There was a plenty deep hole in the crank casting.
R.
