Re: Max wedge manifolds too hot?
[Re: president61]
#1654307
08/03/14 02:15 AM
08/03/14 02:15 AM
Posts: 1,607 Western Washington
Sixgun
Western Washington
I think you fixed it. I have seen (too many times) on initial startup/break in/cam break in the timing so retarded that the header tubes start to glow. It happens so fast you barely have time to get a light on it, and a few times I just reached over and advanced the crud out of it, then got it dialed in.Neever seemed to have any lasting harm,but I do not have x-ray eyes. Now if you wait a moment,there's a good chance someone will contradict me Hope this helps, Bear BTW if memory serves,EGT runs anywhere from 550-700 degrees and goes as high as 1200 when you stand on it.
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
[Re: RapidRobert]
#1654311
08/03/14 12:30 PM
08/03/14 12:30 PM
Overly hot exhaust is always too little timing--simple as that Bracket racers learned ( well Good ones) that locked out timing makes one run cool as a cuke in pits , staging, stc Folks always make this same mistake, this topic comes up all the time When you first fire one up get a handfull of distributor, advance it until it sounds happy ...Then...set the timing
[Re: GODSCOUNTRY340]
#1654314
08/03/14 03:34 PM
08/03/14 03:34 PM
Marsh Performance has super valve cover gaskets that will not "cook" a big help in that application
[Re: RapidRobert]
#1654315
08/03/14 06:19 PM
08/03/14 06:19 PM
Posts: 1,044 minnesota
president61
minnesota
Passenger side was 680 degrees and the drivers side was about 70 degrees less. Is this too hot? would cause this? Thanks
I would say way too hot. jetting/vac leak/timing/stuck heat riser. I'm curious why he had it timed at zero?
That's the way he aquired it. The car only has 482 miles on it and don't think it's been driven at all in the last 15 yeArs. Supposedly it was rebuilt to stock specs at some point. Thanks to all who have responded
[Re: ]
#1654316
08/07/14 02:46 AM
08/07/14 02:46 AM
president61
minnesota
Are they listed as a special gasket?
