Re: My new racecar..... racetruck
[Re: tboomer]
#1652478
07/29/14 04:39 PM
07/29/14 04:39 PM
Triple Threat
Renton Washington
Not sure on weight. The truck hasn't been on the scales in recent times but 3200# ish from what I was told.
Interior is basically non exsistent, the shell of the stock dash, Lexan and other lightening tricks, full blown race truck. So while not a feather weight, its lighter than most. It has a Carbon Fiber hood that was made by mopar and i'm told is one of very few in exsistence.
It will probably be a little more than 3200 with my R3 block compared to when it had a stock block. My dart is probably the heaviest A body in exsistence, so its still a step in the right direction.
Ted, My motor thinks its a big block because it's the size of one, just needs some W9's and it should go deep into the 9's.
[Re: Triple Threat]
#1652479
07/29/14 04:42 PM
07/29/14 04:42 PM
Posts: 26,429 United Socialist States of Ame...
tboomer
I think my 512 would put your truck into the nines! My old B is a tad over 3600# with the driver and has gone 10.15 @ 131 on a mild tune! That still is a sharp truck! Would be an awesome street machine!
[Re: tboomer]
#1652480
07/29/14 06:42 PM
07/29/14 06:42 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Nice Truck! "Not sure on weight. The truck hasn't been on the scales in recent times but 3200# ish from what I was told." It would have to be a stripped down Dakota to be that light because a stock one is around 3,800 lbs. Did I miss where you posted the combo?
[Re: TheOtherDodge]
#1652481
07/29/14 07:00 PM
07/29/14 07:00 PM
Triple Threat
Renton Washington
It is stripped. Engine and trans is whats in my Dart now 454" small block and 727, has pushed that 3500# car to 10.28@129
[Re: BIG DRAG]
#1652483
07/29/14 07:05 PM
07/29/14 07:05 PM
Triple Threat
Renton Washington
Congrats on the new ride. Are your plans for Super Stock GT or modified? I spent a lot of time with a GT/TB Dakota...
Thank you! I assuming given your location you're referring to Shane Studley's old truck?
I haven't explored the available combos much but I doubt I have the bankroll to play in Modified. Will likely be a GT combo if I ever make that leap.
[Re: BIG DRAG]
#1652485
07/29/14 07:18 PM
07/29/14 07:18 PM
Triple Threat
Renton Washington
Very cool! I was wondering if he still had it or not. I know he tried to sell it a few different times. I wouldn't be looking to build anything to set a record, just fast enough to qualify, reliable and competitive.
That would be one of the benefits of the truck, very few heads up races to avoid here in D6.
[Re: MoparDonny]
#1652489
07/29/14 07:36 PM
07/29/14 07:36 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
On the Wallace Racing web sight calculators it said going from 3500 lbs , 10.28 @ 129 to 3200 lbs would run 9.98 @ 132.91 mph. I do not know how accurate that is.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: pittsburghracer]
#1652492
07/29/14 10:02 PM
07/29/14 10:02 PM
Posts: 35,162 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
cool truck Like the Dart too though
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#1652493
07/29/14 10:13 PM
07/29/14 10:13 PM
Triple Threat
Renton Washington
Thanks everyone, Dart might not be going anywhere... we'll see. Might have to put a small motor in it again and drive it more often. It works too well to give it away, won $1100 in it this weekend alone!
[Re: BIG DRAG]
#1652496
07/30/14 02:26 AM
07/30/14 02:26 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Yes, Shane still has the truck. Shane is my cousin. I helped him and his Dad Don build the truck. When it was new we set the record so many times we joked that we were just going to put a zipper on it to make tear down easier...
I talked to Shane out here at the races @ Wild Horse/Firebird earlier this year..
He had the truck there.. Always loved it when Don rolled down the windows to talk to us in the staging lanes..
That's right Power Windows..
I miss Don, as he did much of my work for me..
Glad Shane still races the truck..
Congrats on the new truck Dustin..
And Happy Birthday..
Chris..
