Page 2 of 4 1 2 3 4
Re: My new racecar..... racetruck [Re: tboomer] #1652478
07/29/14 04:39 PM
07/29/14 04:39 PM
Renton Washington
Triple Threat Offline OP
Renton Washington
Not sure on weight. The truck hasn't been on the scales in recent times but 3200# ish from what I was told.
Interior is basically non exsistent, the shell of the stock dash, Lexan and other lightening tricks, full blown race truck. So while not a feather weight, its lighter than most. It has a Carbon Fiber hood that was made by mopar and i'm told is one of very few in exsistence.
It will probably be a little more than 3200 with my R3 block compared to when it had a stock block. My dart is probably the heaviest A body in exsistence, so its still a step in the right direction.
Ted, My motor thinks its a big block because it's the size of one, just needs some W9's and it should go deep into the 9's.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: My new racecar..... racetruck [Re: Triple Threat] #1652479
07/29/14 04:42 PM
07/29/14 04:42 PM
tboomer Online content
tboomer  Online Content
I think my 512 would put your truck into the nines! My old B is a tad over 3600# with the driver and has gone 10.15 @ 131 on a mild tune! That still is a sharp truck! Would be an awesome street machine!
Re: My new racecar..... racetruck [Re: tboomer] #1652480
07/29/14 06:42 PM
07/29/14 06:42 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Nice Truck!
"Not sure on weight. The truck hasn't been on the scales in recent times but 3200# ish from what I was told."
It would have to be a stripped down Dakota to be that light because a stock one is around 3,800 lbs.
Did I miss where you posted the combo?
Re: My new racecar..... racetruck [Re: TheOtherDodge] #1652481
07/29/14 07:00 PM
07/29/14 07:00 PM
Renton Washington
Renton Washington
It is stripped.
Engine and trans is whats in my Dart now 454" small block and 727, has pushed that 3500# car to 10.28@129
-Dustin
Re: My new racecar..... racetruck [Re: TheOtherDodge] #1652482
07/29/14 07:01 PM
07/29/14 07:01 PM
Southern California
BIG DRAG Offline
BIG DRAG  Offline
Southern California
Congrats on the new ride. Are your plans for Super Stock GT or modified? I spent a lot of time with a GT/TB Dakota...
Re: My new racecar..... racetruck [Re: BIG DRAG] #1652483
07/29/14 07:05 PM
07/29/14 07:05 PM
Renton Washington
Renton Washington
Thank you! I assuming given your location you're referring to Shane Studley's old truck?
I haven't explored the available combos much but I doubt I have the bankroll to play in Modified. Will likely be a GT combo if I ever make that leap.
Re: My new racecar..... racetruck [Re: Triple Threat] #1652484
07/29/14 07:11 PM
07/29/14 07:11 PM
Southern California
BIG DRAG Offline
BIG DRAG  Offline
Southern California
Yes, Shane still has the truck. Shane is my cousin. I helped him and his Dad Don build the truck. When it was new we set the record so many times we joked that we were just going to put a zipper on it to make tear down easier...
Re: My new racecar..... racetruck [Re: BIG DRAG] #1652485
07/29/14 07:18 PM
07/29/14 07:18 PM
Renton Washington
Renton Washington
Very cool! I was wondering if he still had it or not. I know he tried to sell it a few different times. I wouldn't be looking to build anything to set a record, just fast enough to qualify, reliable and competitive.
That would be one of the benefits of the truck, very few heads up races to avoid here in D6.
-Dustin
Re: My new racecar..... racetruck [Re: Triple Threat] #1652486
07/29/14 07:27 PM
07/29/14 07:27 PM
Southern California
BIG DRAG Offline
BIG DRAG  Offline
Southern California
Yes, the trucks are great class cars.. er trucks.... you really are the master of your own destiny... not alot of heads up races, you can really lean on it if you need to but be careful because you will get hit with horsepower for all of your hard work... but that's class racing.. The trucks are really cool though. Another option is to run it in SS/TA, B, C, D...
If you have a W? Head you certainly can, alot faster, better parts, just spend money. Oh and never have to tear down... lots of advantages to those combos too...
Re: My new racecar..... racetruck [Re: Triple Threat] #1652487
07/29/14 07:27 PM
07/29/14 07:27 PM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
454" smallblock? Wow. I haven't been on this board much in the last 5 years since my second son was born. Car parts took a backseat for awhile.
But I remember your car from back at pinks all out when we were there, loved that car.
Good luck with the truck. Should fly with your power train.
Don.
Re: My new racecar..... racetruck [Re: MoparDonny] #1652488
07/29/14 07:36 PM
07/29/14 07:36 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Cool truck for sure Good luck with it
Re: My new racecar..... racetruck [Re: MoparDonny] #1652489
07/29/14 07:36 PM
07/29/14 07:36 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
On the Wallace Racing web sight calculators it said going from 3500 lbs , 10.28 @ 129 to 3200 lbs would run 9.98 @ 132.91 mph. I do not know how accurate that is.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: My new racecar..... racetruck [Re: D-50] #1652490
07/29/14 09:11 PM
07/29/14 09:11 PM
Johnstown
69dart Online content
69dart  Online Content
Johnstown
Very cool truck!!
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: My new racecar..... racetruck [Re: 69dart] #1652491
07/29/14 09:58 PM
07/29/14 09:58 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Very nice. I passed up a truck one of our members sold a few years ago and could still kick myself in the butt.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: My new racecar..... racetruck [Re: pittsburghracer] #1652492
07/29/14 10:02 PM
07/29/14 10:02 PM
S.E. South Dakota !
bigdad Online content
Still Posting A Lot
bigdad  Online Content
Still Posting A Lot
S.E. South Dakota !
cool truck
Like the Dart too though
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: My new racecar..... racetruck [Re: bigdad] #1652493
07/29/14 10:13 PM
07/29/14 10:13 PM
Renton Washington
Renton Washington
Thanks everyone, Dart might not be going anywhere... we'll see. Might have to put a small motor in it again and drive it more often. It works too well to give it away, won $1100 in it this weekend alone!
-Dustin
Re: My new racecar..... racetruck [Re: Triple Threat] #1652494
07/29/14 10:23 PM
07/29/14 10:23 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Sweet truck
Good luck with it and look forward to some results
Re: My new racecar..... racetruck [Re: roadhazard] #1652495
07/30/14 01:49 AM
07/30/14 01:49 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
That's a good looking ride!
Re: My new racecar..... racetruck [Re: BIG DRAG] #1652496
07/30/14 02:26 AM
07/30/14 02:26 AM
Arizona
Chris'sBarracuda Offline
Arizona
I talked to Shane out here at the races @ Wild Horse/Firebird earlier this year..
He had the truck there.. Always loved it when Don rolled down the windows to talk to us in the staging lanes..
That's right Power Windows..
I miss Don, as he did much of my work for me..
Glad Shane still races the truck..
Congrats on the new truck Dustin..
And Happy Birthday..
Chris..
Re: My new racecar..... racetruck [Re: Triple Threat] #1652497
07/30/14 02:33 AM
07/30/14 02:33 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I've always loved the look of that body style Dakota a a race truck.
Page 2 of 4 1 2 3 4
