How do I remove these knobs? Are they available? #1651497
07/27/14 09:38 AM
07/27/14 09:38 AM
Puttin' on the foil in Charles...
not_a_charger Offline OP
Mr. Big Shot Moparts Moderator
71-74 B-body HVAC chrome plastic knobs. How are they removed without breakage? Are they reproduced?
Earning every penny of that moderator paycheck.
DBAP
Re: How do I remove these knobs? Are they available? [Re: not_a_charger] #1651498
07/27/14 10:02 AM
07/27/14 10:02 AM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
Not real scientific here but it does work. Smooth jaw needle nose pliers that won't leave a mark on the steel, grab about 1/8" from the plastic knobs. 1/4" screwdriver gently twisting / prying off alternating top to bottom. Patience and be gentle - they'll walk right off. I don't know of anyone reproducing them but it's been almost 15 years since I did a '73 Charger and swapped out controls and back then I had good spares.
Old, tired, and sometimes broke down. Me, not my car...
Re: How do I remove these knobs? Are they available? [Re: not_a_charger] #1651499
07/27/14 10:04 AM
07/27/14 10:04 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
on some there was a small allen screw on the underside...if not...yank them off as they are pressure mounted...(best term I could come up with)
Re: How do I remove these knobs? Are they available? [Re: terzmo] #1651500
07/27/14 10:39 AM
07/27/14 10:39 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
if no set screw then soak them down in WD-40 first then YANK.....
Re: How do I remove these knobs? Are they available? [Re: mikemee1331] #1651501
07/29/14 04:27 PM
07/29/14 04:27 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
NO!
WD-40 is known to eat plastic.
- Stu Harmon
Re: How do I remove these knobs? Are they available? [Re: feets] #1651502
07/29/14 04:33 PM
07/29/14 04:33 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The ones on my Dart are metal and have a set screw. If you damage the original plastic ones, you could install the metal ones.
Re: How do I remove these knobs? Are they available? [Re: Shoozy] #1651503
07/29/14 04:56 PM
07/29/14 04:56 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
AND PB BLASTER works ok
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: How do I remove these knobs? Are they available? [Re: burdar] #1651504
07/29/14 08:16 PM
07/29/14 08:16 PM
Does anyone repop those?
DBAP
Re: How do I remove these knobs? Are they available? [Re: not_a_charger] #1651505
08/01/14 11:46 PM
08/01/14 11:46 PM
Motown, Mi
P
PAULS_340 Offline
PAULS_340  Offline
P
Motown, Mi
Those look darn close to the Abody ones and those have a small Allen head screw on the under side...but you probably looked under already?
Still looking for LM29H1B415501, '71 Demon 340
Re: How do I remove these knobs? Are they available? [Re: PAULS_340] #1651506
08/01/14 11:50 PM
08/01/14 11:50 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Hey Paul, is that your original dash radio face plate bezel or did you add it?
Re: How do I remove these knobs? Are they available? [Re: PAULS_340] #1651507
08/02/14 05:19 AM
08/02/14 05:19 AM
I did. These do not have a set screw.
DBAP
Re: How do I remove these knobs? Are they available? [Re: not_a_charger] #1651508
08/02/14 01:55 PM
08/02/14 01:55 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
no screws= pulling them off....tiny wiggle at first....then.....pull!!
Re: How do I remove these knobs? Are they available? [Re: terzmo] #1651509
08/02/14 02:21 PM
08/02/14 02:21 PM
Jacksonville, FL
burnt_o_matic Offline
Jacksonville, FL
If those are like the E-body ones, they're held onto the control lever by a devious little metal clip. The control lever has a small hole in the end, and the clip has a semi-circular depression that clips into the lever hole. It's not just a force fit. I think I ended up using a tiny screwdriver or blade to get mine off, but it was a fight.
