ampmeter and tach not registering right #1650504
07/24/14 05:07 PM
07/24/14 05:07 PM
70GTXer Offline OP
70GTXer  Offline OP
I just replace all the engine wiring harnesses with new from M&H, had the cluster redone with current electronics from Bob's speedo. also installed MSD 5 ignition. now when fired up the tach registers about double and when the engine is revved the ampmeter sweeps to full right. Also in case this helps I have also replaced ALL wiring front to back with new. any ideas would be helpful.
Re: ampmeter and tach not registering right [Re: 70GTXer] #1650505
07/24/14 05:49 PM
07/24/14 05:49 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The ampmeter could be because the battery isn't charged yet.
Re: ampmeter and tach not registering right [Re: stumpy] #1650506
07/24/14 06:47 PM
07/24/14 06:47 PM
(1) what Stump said make sure the batt is up (if not then charge it on a charger seperate from the vehicle not in the vehicle from the alt). (2) with the batt squared away set the idle speed up to where it pegs (if it still pegs) & check the charging voltage. Do NOT run it like this for more than 3 seconds as this full fielding will fry wires and components. It is FAR better to let the batt be ran down till you solve it than for the system to be overcharging till you solve it. Wouldn't hurt to run a 8ga or smaller jumper from the alt batt terminal to the batt positive terminal till you get it sorted out & have all components/lights OFF. Likely the reg is bad. 2nd choice would be the alt (or alt brushes).
Re: ampmeter and tach not registering right [Re: 70GTXer] #1650507
07/25/14 12:50 AM
07/25/14 12:50 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
What kind of tach..
OE or aftermarket..
Most likely U need a tach adapter to work with the MSD box..
Just my $0.03...
Re: ampmeter and tach not registering right [Re: Sinitro] #1650508
07/25/14 07:05 PM
07/25/14 07:05 PM
70GTXer Offline OP
70GTXer  Offline OP
it's an original tic-toc that was redone with the cluster
Re: ampmeter and tach not registering right [Re: Sinitro] #1650509
07/25/14 07:55 PM
07/25/14 07:55 PM
70GTXer Offline OP
70GTXer  Offline OP
Sinitro,
checked with msd and you are right-the original tic-toc needs a single fire signal and the msd fires dual. I ordered the adapter # 8920 that Vic at msd says will fix all issues for mopar original tic-tocs
Thanks again for the info
