Page 3 of 4 1 2 3 4
Re: Twin Turbo [Re: Bishop] #1648597
07/31/14 11:36 PM
07/31/14 11:36 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Not mine
http://detroit.craigslist.org/wyn/pts/4557516567.html
I wish I had a hemi to put it on.
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: How to make 1200-1300 streetable HP? [Re: 65 Hemi] #1648598
08/01/14 02:01 AM
08/01/14 02:01 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I have both combos, I ran a f-2 cog side slinger for the last 5 years making 24lbs no issues. now I have the gear driven chris alston drive.
Hi Bob, since your car is for sale any chance you want to sell your side slinger set up? If so please pm a price and what it includes. I want to try a couple of Josh's races but know I can't get it done NA. My Dart is perfectly set up with a stock fire wall and bolt on strut/k member.
sorry my car is not for sale, that was a joke. The side slinger engine and blower is sitting here in the shop as a spare.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: How to make 1200-1300 streetable HP? [Re: bigtimeauto] #1648599
08/01/14 05:41 PM
08/01/14 05:41 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Well if your not selling your car and you continue to race Josh's races I have less desire to race there. It would be like taking a knife to a gun fight!
Lol
Doug
MOPAR or NO CAR!!!
Re: How to make 1200-1300 streetable HP? [Re: 65 Hemi] #1648600
08/02/14 12:03 AM
08/02/14 12:03 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Lol
that's not true, I have yet to win one of those races. first one I got a flat in the final and the last one I broke a trans on the second qualifier.
remember we race cars not time slips!
Re: How to make 1200-1300 streetable HP? [Re: bigtimeauto] #1648601
08/02/14 12:15 AM
08/02/14 12:15 AM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Lol
That's very true. I have a feeling that you have addressed your weak links and your car will haul the mail!
Doug
MOPAR or NO CAR!!!
Re: How to make 1200-1300 streetable HP? [Re: bigtimeauto] #1648602
08/02/14 12:15 AM
08/02/14 12:15 AM
Arizona
Chris'sBarracuda Offline
Arizona
If there were no issues, can I ask why you changed.??
Just curious, because seems like a lot of work to move the radiator etc..
Chris..
Re: How to make 1200-1300 streetable HP? [Re: Chris'sBarracuda] #1648603
08/02/14 12:38 AM
08/02/14 12:38 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Chris..
Chris was making some new stuff for my gear drive on my Camaro so I figured I would put one on the dart also. I use my cars as learning tools for my customers so I have to always be trying new stuff/methods.
Re: How to make 1200-1300 streetable HP? [Re: bigtimeauto] #1648604
08/04/14 02:27 PM
08/04/14 02:27 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
I am pretty much leaning toward a procharger for the 499. It has the block, crank (Bryant A fuel with 2 1/4" slots), and heads and is 4.470 bore and under 4" stroke. I don't think a crank gear driven unit is a good match for the car but a side mount may work. Where can I get details about mounting the unit, the pulleys and also accessory drive for the vac pump and the alt? Needs to be compatible with a Jesel cam drive, ATI balancer (will get the keyway slots), motor plate, Indy reverse flow and elec water pump. The driver side of the front of the motor is wide open except for the stock oil filter location (but a big pump and cover).
What does the blower mount on?
What would be a good manifold and how much carb? Now there is a tall single plane w/ Dominator and lotsa NOS plumbing. The B1 heads are on a short deck KB block.
Re: How to make 1200-1300 streetable HP? [Re: Airwoofer] #1648605
08/04/14 05:10 PM
08/04/14 05:10 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I am pretty much leaning toward a procharger for the 499. It has the block, crank (Bryant A fuel with 2 1/4" slots), and heads and is 4.470 bore and under 4" stroke. I don't think a crank gear driven unit is a good maych for the car but a side mount may work. Where can I get details about mounting the unit, the pulleys and also accessory drive for the vac pump and the alt? Needs to be compatible with a Jesel cam drive, ATI balancer (will get the keyway slots), motor plate, Indy reverse flow and elec water pump. The driver side of the front of the motor is wide open except for the stock oil filter location (but a big pump and cover).
Big Time is a distributor for Procharger and has a proven car. I will be using him when I am ready. It will cut down on the learning curve which can be very expensive.
Doug
MOPAR or NO CAR!!!
Re: How to make 1200-1300 streetable HP? [Re: 65 Hemi] #1648606
08/04/14 05:52 PM
08/04/14 05:52 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Can you post up some pics of the A body installation? On the cog belt drive F2, what was involved. It is starting to look like that will be the easiest route for me. How do you hang the compressor when the heads have no mounting bosses like my B1s?
I want to get rolling on this build. We are waiting on a plan to mount and drive the blower before we get into the motor and change it over. Bigtime, shoot me a PM if you are interested.
Re: How to make 1200-1300 streetable HP? [Re: Airwoofer] #1648607
08/05/14 04:13 PM
08/05/14 04:13 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Bigtime, can you put some pics of that sidejob?
Re: How to make 1200-1300 streetable HP? [Re: Airwoofer] #1648608
08/06/14 03:08 AM
08/06/14 03:08 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Prochargers are mounted on a thick aluminum plate, some times two thick plates. They bolt on with only a few bolts. The Superchargerstore should have pics or do a search.
When you order from Procharger they build each kit custom. And it can be as complete, or if you decide, it can be a tuner kit.
When I opened my kit it had everything you needed to put it on my SRT Challenger. Including a real nice instruction book. I was really pleased with the install. It was easyer then installing the TTI headers on the same car. I did both.
If you call them they will set you on the right path.
This is my only pic.
Re: How to make 1200-1300 streetable HP? [Re: FastmOp] #1648609
08/06/14 11:31 AM
08/06/14 11:31 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Fastmop, what have you run with that set up? Do you have before blower and after blower times?
Re: How to make 1200-1300 streetable HP? [Re: TheOtherDodge] #1648610
08/06/14 04:24 PM
08/06/14 04:24 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
It's a long way from a 1000HP lol
I picked up about .6 and 10MPH in the 1/8. But that's on a non hooking street tire. It's been some 7.70's babying it off the line.
I was just trying to show a mounting bracket and Procharger set up to let people get an idea of what's involved. My setup uses two belts. One belt is run off the crank to a Jackshaft pully. The other end of the Jackshaft there's a cog belt that goes to the Procharger pully.
That's why my Procharger intake is forward faceing.
Re: How to make 1200-1300 streetable HP? [Re: FastmOp] #1648611
08/07/14 07:59 AM
08/07/14 07:59 AM
pa
572charger Offline
572charger  Offline
pa
mine is a 606 cuin hemi 700 lift roller cam 11.9 to 1 pump gas stage V hemi, makes about 880 - 900 on motor( 9.60s at 142) in a 3910 lb street car drive it any where any time has 2 foggers on it right now runs 8.90s at 156mph on a little 200 hp tune up so its around 1100 hp that combo has been together since 2007 !!!!!!! mabe ill turn it up on some race gas this year !!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: How to make 1200-1300 streetable HP? [Re: 572charger] #1648612
08/07/14 11:39 AM
08/07/14 11:39 AM
Houston, Texas
Houston, Texas
Even on the 200 shot you can run pump 93 with nothing else?
Re: How to make 1200-1300 streetable HP? [Re: TheOtherDodge] #1648613
08/08/14 08:36 AM
08/08/14 08:36 AM
pa
572charger Offline
572charger  Offline
pa
yes all my runs were on pump gas 93 octane never any race gas yet, this year i may put race gas in it and turn it up !!!! my motor on race gas runs 2 tenths slower on motor alone so i never use any race gas !!!! i run my car like i drive it on the street !!!
Re: How to make 1200-1300 streetable HP? [Re: 572charger] #1648614
08/08/14 12:37 PM
08/08/14 12:37 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
I have seen his car in person, its the real deal....And its not a fancy race car on the street...Its a street car on the race track.
Re: How to make 1200-1300 streetable HP? [Re: Dragula] #1648615
08/09/14 07:38 AM
08/09/14 07:38 AM
pa
572charger Offline
572charger  Offline
pa
thanks for the post randy !! ill be at woodward wed - sunday driving in real traffic !!!! lol trying to make the DONUT CUTTER if they still do the mopar cruise !!
Re: How to make 1200-1300 streetable HP? [Re: 65 Hemi] #1648616
08/12/14 03:16 PM
08/12/14 03:16 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Why? He won't answer messages. Strange cause I am wanting a F2 on my BB and have the dough. Is this a Moparts thing or just me? Is the process to just drop off your car many states away and just wait to be told to come and get it when they are done and here is the bill?
Page 3 of 4 1 2 3 4
