Any difference in starter relays ? #1648359
07/19/14 10:10 PM
07/19/14 10:10 PM
Buckle of corn belt ,c. lll.
420SIX Offline OP
420SIX  Offline OP
Usually you get what you pay for , but is that true in starter relays ? most are $15-$25 w/no brand mentioned
Have burned out 2 recently on 69 big block. First was old , replaced it and now it is hit & miss. Connections are all good so do I need to shell out for better quality ...if so what ?
Re: Any difference in starter relays ? [Re: 420SIX] #1648360
07/19/14 10:34 PM
07/19/14 10:34 PM
Might just be Mr Murphy. They tend to be pretty reliable. I'd just see what happens with the 3rd one & likely you will be fine
Re: Any difference in starter relays ? [Re: RapidRobert] #1648361
07/20/14 04:14 PM
07/20/14 04:14 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
yes better quality....find a nors made in usa they say it right on them, often made by original supplier to chrysler..do you have an automatic trans or a stick as they are different, i can give you the #s and brands to search for...modern imported replacements from MIC(mexico,India,china ) are CRAP
Re: Any difference in starter relays ? [Re: Joesixpack] #1648362
07/21/14 10:57 AM
07/21/14 10:57 AM
Good point as it ain't no secret that quality has deteriorated on almost everything.
Re: Any difference in starter relays ? [Re: RapidRobert] #1648363
07/21/14 12:19 PM
07/21/14 12:19 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We used BWDs at work and had no problems.Advanced sells them.My 65 still runs the OE one as does the kids 62.Typically they very seldom go bad.Rocky
Chrysler Firepower
Re: Any difference in starter relays ? [Re: 420SIX] #1648364
07/21/14 12:34 PM
07/21/14 12:34 PM
Central Ohio
BMChrysler68 Offline
Smarter than the average bear? I think not.
Central Ohio
It's a simple relay. If they're getting burned up, something is forcing them bad. I'd get out the old multimeter before I started spending $$ on NOS stuff.
1968 Plymouth Fury III
2dr FT, 383-4v, 4 speed
1972 AMC Ambassador SST wagon
360-4v, automatic
2014 Challenger R/T Classic 6-speed
