THE BEST CHOICE IN SPARKPLUG WIRES??? #1647656
07/17/14 10:12 PM
07/17/14 10:12 PM
Brooklyn NY
magic1 Offline OP
magic1  Offline OP
Brooklyn NY
LOOKING TO REPLACE THE SPARKPLUG WIRES, MSD CAP, AND ROTOR ON MY REBUILT 440....its a real Sunday driver....I bought 8.5mm MSD SUPER CONDUCTOR WIRES.....not yet installed...Then I read abut the FIRECORE 50 WIRES...WHICH WILL MAKE ME AND MY REBUILT 440 THE HAPPIEST???
Re: THE BEST CHOICE IN SPARKPLUG WIRES??? [Re: magic1] #1647657
07/17/14 10:19 PM
07/17/14 10:19 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
this is another of those topics that gets beat to death month after month. the wire you have (MSD) are good wires. I have used several sets over the years (8mm) without complaint.
Re: THE BEST CHOICE IN SPARKPLUG WIRES??? [Re: magic1] #1647658
07/17/14 10:28 PM
07/17/14 10:28 PM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
Run the wires you already bought .
They are plenty good enough.
There will always be New latest / greatest jonny come lately products that come out claiming to be SO much better than whats already out there and Usually it,s all mostly just a CATCHY MARKETING AD.
Not that there,s anything wrong with the firecores but there,s nothing wrong with new already paid for MSD,s
Re: THE BEST CHOICE IN SPARKPLUG WIRES??? [Re: ChinooK440] #1647659
07/17/14 10:42 PM
07/17/14 10:42 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I've had the MSD wires on my car for 7 years or more they work great, the plug ends are top notch they release the plug without a fight and snap on positively.
Re: THE BEST CHOICE IN SPARKPLUG WIRES??? [Re: ChinooK440] #1647660
07/17/14 10:43 PM
07/17/14 10:43 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I bought the firecores. Nice wire but stick with the ones you already bought. You will see zero difference between them.
Re: THE BEST CHOICE IN SPARKPLUG WIRES??? [Re: DaytonaTurbo] #1647661
07/17/14 11:15 PM
07/17/14 11:15 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
be still my heart, a Moparts first! 4 replies in a row that all say the same thing!!
Re: THE BEST CHOICE IN SPARKPLUG WIRES??? [Re: mikemee1331] #1647662
07/17/14 11:58 PM
07/17/14 11:58 PM
Enfield, Ct
Moe Offline
Moe  Offline
Enfield, Ct
Spend the time. Get the MSD Universal kit. Get some 'multi angle' boots, some 90°boots. The wire looms I have but can't remember the p/n. Some wire seperators, End result will be nice!
Re: THE BEST CHOICE IN SPARKPLUG WIRES??? [Re: Moe] #1647663
07/18/14 08:47 PM
07/18/14 08:47 PM
People's Republic of Mass.
Belvedere2 Offline
Belvedere2  Offline
MSD. Red is nice.
Re: THE BEST CHOICE IN SPARKPLUG WIRES??? [Re: Belvedere2] #1647664
07/18/14 10:56 PM
07/18/14 10:56 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I'm partial to the Firecore50 wires myself but if you already have the MSD wires I would sell the MSD wires and get a good set of Firecore50 wires with a cap and rotor as well
Gus
64 Plymouth Savoy
Dana 60
Re: THE BEST CHOICE IN SPARKPLUG WIRES??? [Re: magic1] #1647665
07/19/14 02:38 AM
07/19/14 02:38 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Run the MSD wires, you will see zero benefit from changing to Firecore.
Re: THE BEST CHOICE IN SPARKPLUG WIRES??? [Re: magic1] #1647666
07/19/14 05:27 AM
07/19/14 05:27 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The MSD wires are one of the best spark plug wires, but they are normally longer than they need to be.
I just put a set on my 505" stroked 440, and after sorting them by length, The two longest wires were set aside so I could cut them to the length I wanted. Then start routing the remaining wires. The two longest wires ended up being cut down for the two shortest wires (#2 & #4) cylinder. This was not a big deal because I have extra MSD crimp terminals, boots, and the MDS crimping tool.
The MSD Vari-Angle spark plug ends are pretty nice, except when you need a tight 90-degree bend for clearance. I think the FireCore wires are cut to length better and have the different plug boots where required? I'm not sure as I have not tried them yet.
Re: THE BEST CHOICE IN SPARKPLUG WIRES??? [Re: justinp61] #1647667
07/19/14 08:28 AM
07/19/14 08:28 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Opinions like this are amusing but lack any technical data or real world experience.
So I have installed more than several sets of firecore wires on well tuned - good running cars.
All vehicle had msd wires that were less than 2 yrs old.
Using a digital ohm meter every wire was checked for it's electrical resistance which is measured in ohms. Both sets [msd-firecore] always ohmed out the same.
However...every time the firecore wires were installed the idle rpm picked up between 50 and 75 rpm and the cars ran even better across the board. You can see the idle change using digital readout tachometer.
So argue with the data and the results.
My thanks to sparky for bringing firecore wires to the marketplace.
Re: THE BEST CHOICE IN SPARKPLUG WIRES??? [Re: ThermoQuad] #1647668
07/19/14 09:45 AM
07/19/14 09:45 AM
BDW Offline
BDW  Offline
Talk about amusing,
The wires deliver spark and don't affect timing/rpm, or do these wire break the laws of physics?
Re: THE BEST CHOICE IN SPARKPLUG WIRES??? [Re: ThermoQuad] #1647669
07/19/14 11:51 AM
07/19/14 11:51 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
No real world experience? How would you know that? Because you picked up 50 rpms at idle that makes them better. I take it you have a digital tach to be able to read 50 rpms and it must be pretty mild combo. I have a digital tach in my LM-2 and it'll move 50 rpms at idle on my 408. Show me some real world data from a dyno or ETs then thump your chest about experience. Do some research, it's not all about ohms. Go ahead, keep drinking the kool aid.
Re: THE BEST CHOICE IN SPARKPLUG WIRES??? [Re: justinp61] #1647670
07/19/14 11:55 AM
07/19/14 11:55 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I like my Firecore wires alot but would not hesitate to run the MSD wires if I already had them. Ron
Re: THE BEST CHOICE IN SPARKPLUG WIRES??? [Re: 383man] #1647671
07/19/14 12:03 PM
07/19/14 12:03 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We run Taylor Spiro Pros.Mine are at least 15 years old with big tune headers.Still work great but are looking shabby.Have them on all our rides even the new ones.I even ran them on my 57 Chrysler.Rocky
Chrysler Firepower
Re: THE BEST CHOICE IN SPARKPLUG WIRES??? [Re: therocks] #1647672
07/19/14 03:36 PM
07/19/14 03:36 PM
fullmetaljacket Offline
Firecore here and running nice.
I've had the MSD's before and they were nice as well. I like the custom length and boots of the Firecores much better, plus you can make them look stock for that covert activity called $+==+ racing.
Re: THE BEST CHOICE IN SPARKPLUG WIRES??? [Re: fullmetaljacket] #1647673
07/19/14 03:46 PM
07/19/14 03:46 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
running firecore wires and their distributor here
Re: THE BEST CHOICE IN SPARKPLUG WIRES??? [Re: dangina] #1647674
07/19/14 04:34 PM
07/19/14 04:34 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
does anybody run regular auto parts store wires?
Re: THE BEST CHOICE IN SPARKPLUG WIRES??? [Re: can.al] #1647675
07/19/14 05:14 PM
07/19/14 05:14 PM
montana
P
pjc360 Offline
pjc360  Offline
P
montana
I'm running taylor thundervolt 8.2mm wires and they ohm out at 40 ohms of resistance per foot, the length on them were a tad longer then they needed to be, and the boots are thin. I have torn a hole into a coupleof the boots when removing the wires with my plug wire removing pliers. The next time I spend money on wires I will be purchasing the firecore 50's.
