AAR/TA ???? #1646662
07/14/14 11:24 PM
07/14/14 11:24 PM
, PA
sleepyhead416 Offline OP
, PA
Factory pushrods 5/16 or 3/8 ??? factory length?
Re: AAR/TA ???? [Re: sleepyhead416] #1646663
07/16/14 06:34 PM
07/16/14 06:34 PM
Cab_Burge Online work
Cab_Burge  Online Work
5/16 diameter, 5/16 ball and cup , unsure of the proper length
Re: AAR/TA ???? [Re: Cab_Burge] #1646664
07/16/14 06:46 PM
07/16/14 06:46 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
IIRC, when Troy was doing his T/A resto, the plunger on the T/A lifters are different than the replacement lifters you get today.
And 273 push rods are for solid cam motors. IIRC, the 340-6 is the only hydraulic lifter small block to use an adjustable push rod.
Get custom pushrods with the adjusting screw in a good place and check for cup to rocker body cleanance at max and min lift.
Re: AAR/TA ???? [Re: autoxcuda] #1646665
07/17/14 12:39 AM
07/17/14 12:39 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I'll get back with you on some part numbers that will help on this.
Re: AAR/TA ???? [Re: fastmark] #1646666
07/17/14 01:02 AM
07/17/14 01:02 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
