Wilwoods and factory M/C-pushrod question #1644935
07/10/14 04:23 PM
07/10/14 04:23 PM
alberta
Publicbottle Offline OP
alberta
Im running 4 wheel wilwoods on my challenger and finally got out for a short drive and was fairly pleased with how the brakes worked. I am using the factory master cylinder, and was wondering how much adjustment is available on the pushrod? The pedal seems to move about 1/3 of the travel before the brakes actually apply, I was wondering if I could extend the pushrod in the MC to get pedal action sooner....Am I on the right track here?
Thanks for the advice!!
Re: Wilwoods and factory M/C-pushrod question [Re: Publicbottle] #1644936
07/11/14 11:26 AM
07/11/14 11:26 AM
upper So. CA
N
ntsqd Offline
ntsqd  Offline
N
upper So. CA
There may be some adjustment in the push-rod, but be careful about adjusting it too long. Dig out the FSM and look up that spec. You *might* be able to go a little more depending on the mfg tolerances of that particular m/c and you may not.
I used to swerve around my hallucinations, now I drive right thru them.
