There may be some adjustment in the push-rod, but be careful about adjusting it too long. Dig out the FSM and look up that spec. You *might* be able to go a little more depending on the mfg tolerances of that particular m/c and you may not.
I used to swerve around my hallucinations, now I drive right thru them.
