Re: 904 trany revingup before going into 3rd gear
[Re: HP2]
#1644600
07/11/14 01:30 PM
07/11/14 01:30 PM
Posts: 272 Indiana
dragracer1
Indiana
Thanks for the info guys! I had someone else build my trany last year, do you any of you know how many turns to back the band adjuster off to get me close to a good starting point once i tighten it back up?
Thanks Brad
1.5 turns back is usually fine
Great!...I just have one more question and this may be the dumbest of all, but if Im not mistaken, isn't there two bands that can be adjusted, and if so, where is the location on the case for the band I need to adjust?
thanks Brad
[Re: dragracer1]
#1644606
07/22/14 02:08 PM
07/22/14 02:08 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
Just an update on this revving issue. I checked the band adjustment and it was WAY past 2 turns. I readjusted it to 2 turns out so hopefully this was the issue. I really hope this cures it, because I have 3 5 granders to go to next weekend. If not, my tranny guy has some explaining to do because he had the tranny apart in November and said the clutches looked new. I will find out on Saturday.
Thanks again moparts friends!
Ask him about the band strut , if it's not an aftermarket of or modified stocker it could be bending .
[Re: JohnRR]
#1644607
07/22/14 03:36 PM
07/22/14 03:36 PM
Posts: 272 Indiana
dragracer1
Indiana
The tranny is a TCI built for a a friend's super stocker so Im guessing its an aftermarket band. I only ran it for 1 year before he rebuilt it. And I think all he did was put new clutches in it during the freshening up. If this doesn't work then I will ask him about it. He is one of those guys that is really hard to get hold of.
Thanks BP
[Re: dragracer1]
#1644608
07/22/14 04:26 PM
07/22/14 04:26 PM
JohnRR
Thanks BP
I wouldn't assume that with a TCI build from posts I have seen from the past about their transmissions.
