904 trany revingup before going into 3rd gear #1644594
07/09/14 08:36 PM
07/09/14 08:36 PM
Indiana
dragracer1 Offline OP
Indiana
Hey Moparts transmission guru's, I am having an issue with my drag car going into 3rd gear. I have a 904 with a trans brake with a manual reverse valve body. As I am under full power headed down track, the 1-2 shift is nice and hard but the 2-3 shift is not that good. Once I make the shift with the shifter, the motor revs about 200-300 higher before it shifts. It almost sound like I am power shifting a manual trany. I just had my converter rebuilt and the power is quite a bit better than before, about a 10th better in the 1/8th. It did not seem to do this shifting issue until I had the converter rebuilt. Is this "slip" or "overrev" due to the converter or has the converter being rebuilt changed how the trany acts? Could it need a band adjustment? Btw, even with this shifting issue the car is DEADLY consistant. 7.01 to 7.03 for 15 runs in a row over 2 days. Any help or advise would be GREATLY appreciated!
BP
Re: 904 trany revingup before going into 3rd gear [Re: dragracer1] #1644595
07/09/14 10:53 PM
07/09/14 10:53 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
DragRacer,
Go back and reset you kickdown band like it was when you first started running it. Sounds like it is getting loose unless you are losing the ring seal to drum or the internal lip seal of the direct drum.
Tom
Re: 904 trany revingup before going into 3rd gear [Re: Tom Hand] #1644596
07/09/14 10:57 PM
07/09/14 10:57 PM
DragRacer,
Tom
Re: 904 trany revingup before going into 3rd gear [Re: Cab_Burge] #1644597
07/10/14 12:19 AM
07/10/14 12:19 AM
scratchnfotraction Offline
adjust the front band and then adjust the TPV linkage.
band may need adjusted to hold the HP increase.
Re: 904 trany revingup before going into 3rd gear [Re: Tom Hand] #1644598
07/10/14 11:58 AM
07/10/14 11:58 AM
Indiana
Indiana
Thanks for the info guys! I had someone else build my trany last year, do you any of you know how many turns to back the band adjuster off to get me close to a good starting point once i tighten it back up?
Brad
Re: 904 trany revingup before going into 3rd gear [Re: dragracer1] #1644599
07/10/14 08:37 PM
07/10/14 08:37 PM
Right here
HP2 Offline
HP2  Offline
Right here
Brad
1.5 turns back is usually fine
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: 904 trany revingup before going into 3rd gear [Re: HP2] #1644600
07/11/14 01:30 PM
07/11/14 01:30 PM
Indiana
Indiana
Brad
Great!...I just have one more question and this may be the dumbest of all, but if Im not mistaken, isn't there two bands that can be adjusted, and if so, where is the location on the case for the band I need to adjust?
thanks
Brad
Re: 904 trany revingup before going into 3rd gear [Re: dragracer1] #1644601
07/11/14 03:30 PM
07/11/14 03:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's a pic of the adjuster location...if the lever ratio is unknown I'd set it at 2 turns out.
Re: 904 trany revingup before going into 3rd gear [Re: John_Kunkel] #1644602
07/11/14 08:14 PM
07/11/14 08:14 PM
yes, there are 2 bands to adjust. the low/revs needs the pan dropped to make that adjustment.
the kickdown band can be done without dropping the pan and is in the pic John posted above.
Re: 904 trany revingup before going into 3rd gear [Re: dragracer1] #1644603
07/11/14 10:59 PM
07/11/14 10:59 PM
The factory service manuals on the 727 II've never raced a 904 )calls for tightening the front band to 72 inch lbs and then back out the adjuster screw from 1.5 to 2.0 full turns and then lock the locknut down , depending on which motor and year on how far out try adjsuting the front band and if it still revs between shifts your probally going to need some front clutches
Re: 904 trany revingup before going into 3rd gear [Re: Cab_Burge] #1644604
07/14/14 11:26 PM
07/14/14 11:26 PM
Indiana
Indiana
Thank you all! This should hopefully fix my issue. Again,thanks for all the info. Moparts has the best members around!
Re: 904 trany revingup before going into 3rd gear [Re: Cab_Burge] #1644605
07/22/14 12:10 PM
07/22/14 12:10 PM
Indiana
Indiana
Just an update on this revving issue. I checked the band adjustment and it was WAY past 2 turns. I readjusted it to 2 turns out so hopefully this was the issue. I really hope this cures it, because I have 3 5 granders to go to next weekend. If not, my tranny guy has some explaining to do because he had the tranny apart in November and said the clutches looked new. I will find out on Saturday.
Thanks again moparts friends!
Re: 904 trany revingup before going into 3rd gear [Re: dragracer1] #1644606
07/22/14 02:08 PM
07/22/14 02:08 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Ask him about the band strut , if it's not an aftermarket of or modified stocker it could be bending .
Re: 904 trany revingup before going into 3rd gear [Re: JohnRR] #1644607
07/22/14 03:36 PM
07/22/14 03:36 PM
Indiana
Indiana
The tranny is a TCI built for a a friend's super stocker so Im guessing its an aftermarket band. I only ran it for 1 year before he rebuilt it. And I think all he did was put new clutches in it during the freshening up. If this doesn't work then I will ask him about it. He is one of those guys that is really hard to get hold of.
BP
Re: 904 trany revingup before going into 3rd gear [Re: dragracer1] #1644608
07/22/14 04:26 PM
07/22/14 04:26 PM
JohnRR Offline
JohnRR  Offline
BP
I wouldn't assume that with a TCI build from posts I have seen from the past about their transmissions.
