X275 Build crank needed #1644002
07/08/14 02:06 PM
07/08/14 02:06 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Chad needs 4" crank ASAP
Chad wants to do this but parts are hard to find for SBM and it will be much less of a headach to put FORD or Chevy back in the dart.
I am doing all I can to help as I think his car with mopar in it would be bad a$$
Would like a callies crank.(Indy just sold last one they had)
I know this is not parts needed but I think more pople will see this .
Thanks MOPARTS
Brett
Re: X275 Build crank needed [Re: W5DART66] #1644003
07/08/14 02:18 PM
07/08/14 02:18 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
MRL had a rotating assy with a dragonslayer crank for sale a while back (2012?) that was pretty cheap. Mike may still have the crank or know where to get one. Shake the SBM builder tree. I see Callies does not show one available on their website.
Re: X275 Build crank needed [Re: W5DART66] #1644004
07/08/14 02:50 PM
07/08/14 02:50 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Free bump for good cause. Brett if you have time, you've got a pm thanks
Re: X275 Build crank needed [Re: W5DART66] #1644005
07/08/14 04:21 PM
07/08/14 04:21 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Thanks MOPARTS
Brett
Brett try CrankShaft Specialties in Memphis. He had a couple a few months back.
Re: X275 Build crank needed [Re: rt66jim] #1644006
07/08/14 04:26 PM
07/08/14 04:26 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
HOW about Molinar or Rod Bloomer? I just talked to Tom at Molinar yesterday, I know he had a 4.125.
Re: X275 Build crank needed [Re: W5DART66] #1644007
07/08/14 04:38 PM
07/08/14 04:38 PM
Minnesota
Coldart Offline
Coldart  Offline
Minnesota
Bryant
Re: X275 Build crank needed [Re: rt66jim] #1644008
07/08/14 05:04 PM
07/08/14 05:04 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Thanks MOPARTS
Brett
Is Floyd Doug Rowe treating customers right now? He had a bad spell for a while.
http://www.ripoffreport.com/r/Crankshaft...d-openly-267378
Re: X275 Build crank needed [Re: DavidDean] #1644009
07/08/14 06:39 PM
07/08/14 06:39 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
If this is a 360 based build so does bryant. 4.000 and 4.125
http://bryantracing.com/2014/inventory/
Re: X275 Build crank needed [Re: Airwoofer] #1644010
07/08/14 08:06 PM
07/08/14 08:06 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
this would be my first choich..I got mine in two or three weeks ... http://www.bing.com/search?q=King%27s+Crankshaft+Co&FORM=QSRE6 LATE MODLE STOCK"
PART#802/CHRY
This crankshaft is made from a raw E4340 forging with 2.100 rod journals and 2.499 main's. Crankshaft comes with 1/8 radius and nitride bearing surface, OD turned maxim round for low inertia and windge .Crank has bull nose "counterweights weights 50.5 lbs.
*Hp range 900+
*STROKE 3.580
340/ CHRY LIGHT "REV" CRANKSHAFT
PART#809/CHRY
Machined from E4340 USA comes with CNC profiled counterweights,scalloped and bull nose for low inertia weight and improved acceleration.Crank weight 42 to 45lbs
*Hp range 650
*stroke range 2.900 3.750
*not gun drilled
◦ Chevy oiling
340/ CHRY "CUP LITE"
PART# 810/CHRY
Machined from E4340 USA and intended for higher Hp application. More meat left in needed areas bull nose counterweights weighs in at 50 to 54lbs
*Hp range 900+
*Stroke range 2.500 to 4.250
*not gun drilled
PART#803/CHRY
Machined from E4340 USA comes with CNC profiled counterweights,scalloped and bull nose for low inertia weight and improved acceleration.Note crankshaft weight 37lbs
*Hp range 600
*stroke range 2.500 3.750
*not gun drilled
*Rod journal size
1.889. or 1.850 or 1.771
◦ 302 FORD MAINS
340/ CHRY GOLD SREIS LIGHT "REV" CRANKSHAFT
PART#803/CHRY/GS
Machined from E4340 USA comes with CNC profiled counterweights,scalloped and bull nose for low inertia weight and improved acceleration.Note crankshaft weight 34lbs
*Hp range 600
*Rod journal size
*Gun drill mains
*302 FORD MAINS
Re: X275 Build crank needed [Re: WHITEDART] #1644011
07/08/14 08:18 PM
07/08/14 08:18 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
King is 12 -16 weeks out same for Bryant and the "360" cranks listed on Bryant's website are r5p7 stuff and the list is not up to date as far as what they have on shelf.
Re: X275 Build crank needed [Re: W5DART66] #1644012
07/08/14 08:21 PM
07/08/14 08:21 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
The k1and BPE are good but I don't know if I want to put 1800-2000. HP at one.
Re: X275 Build crank needed [Re: W5DART66] #1644013
07/08/14 08:34 PM
07/08/14 08:34 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I saw a 4.250 Bryant on racinjunk the other day
Re: X275 Build crank needed [Re: Leon441] #1644014
07/08/14 08:38 PM
07/08/14 08:38 PM
Renton Washington
Triple Threat Offline
Renton Washington
One was just listed in Race parts for sale here. Could be offset ground to reduce stroke?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: X275 Build crank needed [Re: W5DART66] #1644015
07/08/14 08:48 PM
07/08/14 08:48 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I bought two K1 chevy journal 4 inch stock 360 cranks off Dan (performance only) during one of his sales YEARS ago and i don't think i would want to put 1800-2000 HP to it. Nice stuff but I've never seen testing with that much HP.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: X275 Build crank needed [Re: pittsburghracer] #1644016
07/08/14 09:52 PM
07/08/14 09:52 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
K1 = Chinese
Re: X275 Build crank needed [Re: fishy340] #1644017
07/08/14 11:04 PM
07/08/14 11:04 PM
Q
Quicktree Offline
Quicktree  Offline
Q
K1 = Chinese
top of the line China not scat china
Re: X275 Build crank needed [Re: Quicktree] #1644018
07/08/14 11:21 PM
07/08/14 11:21 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
K1 = Chinese
Boy Quicktree....... I keep reading your posts, thinking maybe even one of them once in a while might be revelant....
But alas, no such luck
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: X275 Build crank needed [Re: B3422W5] #1644019
07/08/14 11:24 PM
07/08/14 11:24 PM
Q
Quicktree Offline
Quicktree  Offline
Q
K1 = Chinese
well good for you, need to get a little sense of humor and you may understand.
Re: X275 Build crank needed [Re: Quicktree] #1644020
07/08/14 11:30 PM
07/08/14 11:30 PM
Portage,michigan
Portage,michigan
K1 = Chinese
I have a great sense of humor. That is why I posted that. You gotta remember I have been reading your posts 10 or 15 years now
1.41 best 60 foot
6.56 at 104.17
Re: X275 Build crank needed [Re: B3422W5] #1644021
07/08/14 11:35 PM
07/08/14 11:35 PM
Q
Quicktree Offline
Quicktree  Offline
Q
K1 = Chinese
and the statement was not only funny but true!
